Android crash while normal usage scenario / maybe a memory management issue
REPRODUCIBILITY: ALWAYS
OS VERSION: 4.5.0.25
HARDWARE: Xperia 10 II
UI LANGUAGE: DE
REGRESSION: SOMEHOW
Start Android application : Wire app
Result: Complete Android runtime crash
See also: Wire 4.x crashes Android environment
Wire app has messages to receive.
  1. Install version 4 of Wire - GitHub - wireapp/wire-android: 🤖 The new Wire client for Android
  2. Send a message to your wire account
  3. Open Wire: Starting and updating message history results into a crash of the runtime
  • Application runs after starting it
  • Or at least only the application crashes.
  • but the runtime should not crash entirely
The AOSP runtime crashes entirely. Only manually restartable / it does not (re)start when trying
to open an arbitrary android app.
No
Wire app directly installed via apk
Check device memory, is your storage full in any of your partitions?
It seems that the update to SFOS 4.6 resolved this issue. A couple of times the mentioned condition didn’t triggered a crash … (JFI @rtr2001)
I will do some extra testing, but so far the worst part of it seems fixed, meaning that Wire issues are no longer tearing down the whole android container.
I still think Wire app is killed upon receipt of a new message from a 3rd pty. New messages I sent from a different platform (Linux desktop for instance ) appear on the phone app instantly without problems, this has always worked fine.
I will edit here with my findings the coming days.
