REPRODUCIBILITY: 25% ? (sometimes)
OSVERSION: 4.4.0.72
HARDWARE: Sony Xperia 10 III - xqbt52 - xqbt52 - 1.0.0.176 - aarch64
UI LANGUAGE: Deutsch (user: de_DE, os: de_DE.utf8)
REGRESSION: perhaps (?)
Using native Android-apps, the camera field keeps black, doesn’t dhow the QR-code.
All apps had the necessary privileges for camera, the scanning sometimes worked before.
- Open an Android-app like Covid Cert, CovPass or Signal.
- Try to scan QR-code.
EXPECTED RESULTS:
Code is scanned in the app.
ACTUAL RESULTS:
Nothing happens, the field stays black.
- Patchmanager: no
- OpenRepos: yes
- Chum: yes
- Other: yes:
Advanced camera app is installed.
After a reboot, scanning worked with the three mentioned apps directly. Can’t remember, if I had problems to scan with “Cov Cert”-App before, several certificates were already scanned (before 4.4.0.72); this time I had these problems.
Home Encryption: enabled
