Android apps like songsterr and tidal do not work on mobile data
OSVERSION: 5.0.0.55
HARDWARE: Reeder S19 Max Pro S - s19mps - s19mps - 1.0.0.40 - aarch64
UI LANGUAGE: English (US) (user: en_US, os: en_US.utf8)
REGRESSION: yes (since: 4.6.0.11 - n/a)
Tidal and Songsterr do report no mobile data when wifi is off.
While whatsapp and signal do work
Restart, toggle airplane , appsupport restart do not solve the issue
  1. Be on mobile network
    2.start tidal or songsterr
  2. Try to operate, see notifications of apps
  3. Verify connection with other android apps
EXPECTED RESULTS:
Mobile connection woks
ACTUAL RESULTS:
Mobile does not
  • Patchmanager: yes
  • OpenRepos: yes
  • Chum: yes
  • Other: none specified
Installed from aurora store. Home caroussel is the only patch
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.9.13+git2
Duplicate. See this topic.
