REPRODUCIBILITY: 100%
OS VERSION: 4.6.12
HARDWARE: Sony Xperia 10 II
UI LANGUAGE: English
REGRESSION: No
Starting ANWB Onderweg & Wegenwacht Android app gets stuck on splash screen, and then exits after a minute or so
Android Support installed and running
- Download the app, e.g. at https://www.apkmirror.com/apk/anwb/anwb-onderweg-wegenwacht/anwb-onderweg-wegenwacht-5-8-1-release/anwb-onderweg-wegenwacht-5-8-1-android-apk-download/
- Install the app
- Try to start it
The app starts
The splash screen is shown for a while, and then exits. The app itself never opens.
N/A
It neither works on 4.5. When monitoring logcat when starting the app this rolls by:
06-07 20:09:45.329 13740 13740 W GooglePlayServicesUtil: com.themobilecompany.Onderweg requires the Google Play Store, but it is missing.
06-07 20:09:45.329 13740 13740 W Notificare: No platform dependencies have been detected. Please include one of the platform-specific packages.
06-07 20:09:45.329 13740 13740 D AndroidRuntime: Shutting down VM
06-07 20:09:45.330 13740 13740 E AndroidRuntime: FATAL EXCEPTION: main
06-07 20:09:45.330 13740 13740 E AndroidRuntime: Process: com.themobilecompany.Onderweg, PID: 13740
Seems the apps simply depends on google-schijt to run. So unless you install google-schijt (or perhaps MicroG) it probably can’t work. You can try complaining at their email address, listed on the store page.
Well that’s a shame. I sent them a message in the faint hope they are able to do something about this.
I tested on 10 III running Sauna and XA2 and 10 II running Struven ketju.
Searching (I tested Groningen) works but routing from Tampere 13 km from Rajaportin sauna doesn’t.
I have MicroG with the settings needed by Lidl Plus.
Edit: freshly updated 10 II Sauna: OK
