Amazfish AGPS script
I have got the Huami token script working. Just as matter of getting all the required files installed, some of which I had missed to start with. It runs from the command line and has downloaded the AGPS data packets. I can see the files in the Home folder.
I have been unable to get the harbour-amazfish-script.sh script to run from the command line. Perhaps I’m doing something wrong?
I even copied the text from the Huami token script into the harbour-amazfish-script.sh file since I knew it worked.
When ever I run the script from the watch the watch disconnects from the phone and then reconnects.
Any ideas? Thanks
