sfos 4.0.1.48
All of a sudden android apps are not starting any more.
I can see the following message in journalctl over an over again:
kernel: binder: 4572:4572 --> 0:0 transaction failed 29189/0, size 0-0 line 2149
Any clue what this means?
systemd service aliendalvik won’t start.
how can i debug this further.?
EDIT: I went into recovery and did a file system check, there were a few errors which have been corrected. But aliendalvik still does not start, same message in systemd journal
EDIT2: Apparently when looking at systemctl status -l -a aliendalvik
output it is /usr/sbin/alien-post-startup.sh
which is failing (code=exited, status=20)
EDIT3: appending a more detailed systemd journal:
Please expand Summary:
Summary
Mär 24 15:22:14 hostname systemd[1]: Starting Alien Dalvik...
Mär 24 15:22:14 hostname systemd[9264]: aliendalvik.service: Executable /usr/bin/start-aliendalvik-preinit.sh missing, skipping: No such file or directory
Mär 24 15:22:14 hostname apkd[4774]: Alien Dalvik is activating (start-pre)
Mär 24 15:22:14 hostname systemd[9268]: aliendalvik.service: Executable /usr/sbin/start-aliendalvik-preinit.sh missing, skipping: No such file or directory
Mär 24 15:22:14 hostname apkd[4774]: Alien Dalvik is activating (start)
Mär 24 15:22:14 hostname kernel: EXT4-fs (loop0): VFS: Can't find ext4 filesystem
Mär 24 15:22:14 hostname kernel: ISOFS: Unable to identify CD-ROM format.
Mär 24 15:22:14 hostname kernel: FAT-fs (loop0): bogus number of FAT structure
Mär 24 15:22:14 hostname kernel: FAT-fs (loop0): Can't find a valid FAT filesystem
Mär 24 15:22:14 hostname init: init first stage started!
Mär 24 15:22:14 hostname init: Using Android DT directory /proc/device-tree/firmware/android/
Mär 24 15:22:14 hostname init: [libfs_mgr]fs_mgr_read_fstab_dt(): failed to read fstab from dt
Mär 24 15:22:14 hostname init: Failed to read fstab from device tree
Mär 24 15:22:14 hostname init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
Mär 24 15:22:14 hostname init: Loading SELinux policy
Mär 24 15:22:14 hostname selinux: SELinux: Could not load policy: No such file or directory
Mär 24 15:22:14 hostname kernel: binder: 4774:4774 --> 0:0 transaction failed 29189/0, size 0-0 line 2149
Mär 24 15:22:14 hostname init: Failed to load monolithic SELinux policy: No such file or directory
Mär 24 15:22:14 hostname init: Unable to load SELinux policy
Mär 24 15:22:14 hostname init: Unable to write to /sys/fs/selinux/checkreqprot: open() failed: No such file or directory
Mär 24 15:22:14 hostname selinux: SELinux: Loaded file_contexts
Mär 24 15:22:14 hostname init: init second stage started!
Mär 24 15:22:14 hostname init: Running restorecon...
Mär 24 15:22:14 hostname init: waitid failed: No child processes
Mär 24 15:22:14 hostname init: Couldn't load property file '/system/etc/prop.default': open() failed: No such file or directory: No such file or directory
Mär 24 15:22:14 hostname init: Couldn't load property file '/prop.default': open() failed: No such file or directory: No such file or directory
Mär 24 15:22:14 hostname init: Couldn't load property file '/odm/default.prop': open() failed: No such file or directory: No such file or directory
Mär 24 15:22:14 hostname init: Couldn't load property file '/vendor/default.prop': open() failed: No such file or directory: No such file or directory
Mär 24 15:22:14 hostname init: Created socket '/dev/socket/property_service', mode 666, user 0, group 0
Mär 24 15:22:14 hostname init: Forked subcontext for 'u:r:vendor_init:s0' with pid 2
Mär 24 15:22:14 hostname init: Forked subcontext for 'u:r:vendor_init:s0' with pid 3
Mär 24 15:22:14 hostname init: Parsing file /init.rc...
Mär 24 15:22:14 hostname init: Added '/init.environ.rc' to import list
Mär 24 15:22:14 hostname init: Added '/init.unknown.rc' to import list
Mär 24 15:22:14 hostname init: Added '/vendor/etc/init/hw/init.unknown.rc' to import list
Mär 24 15:22:14 hostname init: Added '/init.zygote32.rc' to import list
Mär 24 15:22:14 hostname init: Parsing file /init.environ.rc...
Mär 24 15:22:14 hostname init: Parsing file /init.unknown.rc...
Mär 24 15:22:14 hostname init: Unable to read config file '/init.unknown.rc': open() failed: No such file or directory
Mär 24 15:22:14 hostname init: /init.rc: 13: Could not import file '/init.unknown.rc': No such file or directory
Mär 24 15:22:14 hostname init: Parsing file /vendor/etc/init/hw/init.unknown.rc...
Mär 24 15:22:14 hostname init: Unable to read config file '/vendor/etc/init/hw/init.unknown.rc': open() failed: No such file or directory
Mär 24 15:22:14 hostname init: /init.rc: 14: Could not import file '/vendor/etc/init/hw/init.unknown.rc': No such file or directory
Mär 24 15:22:14 hostname init: Parsing file /init.zygote32.rc...
Mär 24 15:22:14 hostname init: Parsing directory /system/etc/init...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/android.hardware.audio@2.0-service.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/android.hardware.cas@1.0-service.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/android.hardware.configstore@1.1-service.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/android.hardware.graphics.composer@2.1-service.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/android.hardware.keymaster@4.0-service.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/android.hardware.media.omx@1.0-service.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/android.hidl.allocator@1.0-service.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/atrace.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/audioserver.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/blank_screen.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/bootstat.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/cameraserver.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/drmserver.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/dumpstate.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/gatekeeperd.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/healthd.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/hwservicemanager.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/incidentd.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/installd.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/keystore.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/lmkd.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/logd.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/mdnsd.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/mediadrmserver.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/mediaextractor.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/mediametrics.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/mediaserver.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/mtpd.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/netd.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/perfetto.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/racoon.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/servicemanager.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/statsd.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/storaged.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/surfaceflinger.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/thermalservice.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/tombstoned.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/uncrypt.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/usbd.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/vdc.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/vold.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/wait_for_keymaster.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/wifi-events.rc...
Mär 24 15:22:14 hostname init: Parsing file /system/etc/init/wificond.rc...
Mär 24 15:22:14 hostname init: Parsing file /product/etc/init...
Mär 24 15:22:14 hostname init: Unable to read config file '/product/etc/init': open() failed: No such file or directory
Mär 24 15:22:14 hostname init: Parsing file /odm/etc/init...
Mär 24 15:22:14 hostname init: Unable to read config file '/odm/etc/init': open() failed: No such file or directory
Mär 24 15:22:14 hostname init: Parsing directory /vendor/etc/init...
Mär 24 15:22:14 hostname init: Parsing file /vendor/etc/init/android.hardware.keymaster@3.0-service.rc...
Mär 24 15:22:14 hostname init: Parsing file /vendor/etc/init/init.alien.rc...
Mär 24 15:22:14 hostname init: Parsing file /vendor/etc/init/rild.legacy.rc...
Mär 24 15:22:14 hostname init: Parsing file /vendor/etc/init/vndservicemanager.rc...
Mär 24 15:22:14 hostname init: processing action (early-init) from (/init.rc:20)
Mär 24 15:22:14 hostname init: Command 'mount cgroup none /acct nodev noexec nosuid cpuacct' action=early-init (/init.rc:34) took 0ms and failed: mount() failed: Device or resource busy
Mär 24 15:22:14 hostname init: Command 'mkdir /acct/uid' action=early-init (/init.rc:35) took 0ms and failed: mkdir() failed: Read-only file system
Mär 24 15:22:14 hostname init: processing action (wait_for_coldboot_done) from (<Builtin Action>:0)
Mär 24 15:22:14 hostname init: processing action (MixHwrngIntoLinuxRng) from (<Builtin Action>:0)
Mär 24 15:22:14 hostname init: /dev/hw_random not found
Mär 24 15:22:14 hostname init: processing action (SetMmapRndBits) from (<Builtin Action>:0)
Mär 24 15:22:14 hostname init: processing action (SetKptrRestrict) from (<Builtin Action>:0)
Mär 24 15:22:14 hostname init: processing action (keychord_init) from (<Builtin Action>:0)
Mär 24 15:22:14 hostname init: processing action (console_init) from (<Builtin Action>:0)
Mär 24 15:22:14 hostname init: processing action (init) from (/init.rc:47)
Mär 24 15:22:14 hostname systemd[5146]: Started Alien Audio Service.
Mär 24 15:22:14 hostname init: Command 'mount cgroup none /dev/cpuctl nodev noexec nosuid cpu' action=init (/init.rc:158) took 0ms and failed: mount() failed: Device or resource busy
Mär 24 15:22:14 hostname kernel: cgroup: new mount options do not match the existing superblock, will be ignored
Mär 24 15:22:14 hostname init: processing action (init) from (/init.environ.rc:2)
Mär 24 15:22:14 hostname init: processing action (late-init) from (/init.rc:284)
Mär 24 15:22:14 hostname init: processing action (late-init) from (/system/etc/init/atrace.rc:3)
Mär 24 15:22:14 hostname init: processing action (queue_property_triggers) from (<Builtin Action>:0)
Mär 24 15:22:14 hostname init: processing action (fs) from (/system/etc/init/logd.rc:18)
Mär 24 15:22:14 hostname init: processing action (fs) from (/system/etc/init/wifi-events.rc:17)
Mär 24 15:22:14 hostname init: processing action (fs) from (/vendor/etc/init/init.alien.rc:17)
Mär 24 15:22:14 hostname init: Skipping mount_all fstab: Invalid argument
Mär 24 15:22:14 hostname init: processing action (post-fs) from (/init.rc:317)
Mär 24 15:22:14 hostname init: Unable to set property 'ro.build.flavor' to 'jolla_alien-user' in property file '/system/build.prop': Read-only property was already set
Mär 24 15:22:14 hostname init: Unable to set property 'ro.product.model' to 'AlienDalvik on Jolla Devices' in property file '/system/build.prop': Read-only property was already set
Mär 24 15:22:14 hostname init: Unable to set property 'ro.product.brand' to 'Android' in property file '/system/build.prop': Read-only property was already set
Mär 24 15:22:14 hostname init: Unable to set property 'ro.product.name' to 'jolla_alien' in property file '/system/build.prop': Read-only property was already set
Mär 24 15:22:14 hostname init: Unable to set property 'ro.product.device' to 'alien' in property file '/system/build.prop': Read-only property was already set
Mär 24 15:22:14 hostname init: Unable to set property 'ro.product.manufacturer' to 'jolla' in property file '/system/build.prop': Read-only property was already set
Mär 24 15:22:14 hostname init: Unable to set property 'ro.build.product' to 'alien' in property file '/system/build.prop': Read-only property was already set
Mär 24 15:22:14 hostname init: Unable to set property 'ro.build.description' to 'jolla_alien-user 9 PI eng.abuild.20201201.220851 test-keys' in property file '/system/build.prop': Read-only property was already set
Mär 24 15:22:14 hostname init: Unable to set property 'ro.config.low_ram' to 'true' in property file '/system/build.prop': Read-only property was already set
Mär 24 15:22:14 hostname init: Couldn't load property file '/odm/build.prop': open() failed: No such file or directory: No such file or directory
Mär 24 15:22:14 hostname init: Unable to set property 'ro.product.board' to '' in property file '/vendor/build.prop': Read-only property was already set
Mär 24 15:22:14 hostname init: Unable to set property 'ro.board.platform' to 'alien' in property file '/vendor/build.prop': Read-only property was already set
Mär 24 15:22:14 hostname init: Couldn't load property file '/factory/factory.prop': open() failed: No such file or directory: No such file or directory
Mär 24 15:22:14 hostname init: [libfs_mgr]fs_mgr_read_fstab_default(): failed to find device default fstab
Mär 24 15:22:14 hostname init: unable to read default fstab: No such file or directory
Mär 24 15:22:14 hostname init: starting service 'logd'...
Mär 24 15:22:14 hostname libprocessgroup: Failed to make and chown /acct/uid_1036: Read-only file system
Mär 24 15:22:14 hostname init: createProcessGroup(1036, 4) failed for service 'logd': Read-only file system
Mär 24 15:22:14 hostname init: Created socket '/dev/socket/logd', mode 666, user 1036, group 1036
Mär 24 15:22:14 hostname init: Created socket '/dev/socket/logdr', mode 666, user 1036, group 1036
Mär 24 15:22:14 hostname init: Created socket '/dev/socket/logdw', mode 222, user 1036, group 1036
Mär 24 15:22:14 hostname init: Opened file '/proc/kmsg', flags 0
Mär 24 15:22:14 hostname init: Opened file '/dev/kmsg', flags 1
Mär 24 15:22:14 hostname init: starting service 'servicemanager'...
Mär 24 15:22:14 hostname libprocessgroup: Failed to make and chown /acct/uid_1000: Read-only file system
Mär 24 15:22:14 hostname init: createProcessGroup(1000, 5) failed for service 'servicemanager': Read-only file system
Mär 24 15:22:14 hostname init: starting service 'vndservicemanager'...
Mär 24 15:22:14 hostname init: createProcessGroup(1000, 6) failed for service 'vndservicemanager': Read-only file system
Mär 24 15:22:14 hostname init: Command 'chown system cache /cache' action=post-fs (/init.rc:344) took 0ms and failed: lchown() failed: Read-only file system
Mär 24 15:22:14 hostname init: Command 'chmod 0770 /cache' action=post-fs (/init.rc:345) took 0ms and failed: fchmodat() failed: Read-only file system
Mär 24 15:22:14 hostname init: Command 'mkdir /cache/recovery 0770 system cache' action=post-fs (/init.rc:351) took 0ms and failed: mkdir() failed: Read-only file system
Mär 24 15:22:14 hostname init: Command 'mkdir /cache/backup_stage 0700 system system' action=post-fs (/init.rc:354) took 0ms and failed: mkdir() failed: Read-only file system
Mär 24 15:22:14 hostname init: Command 'mkdir /cache/backup 0700 system system' action=post-fs (/init.rc:355) took 0ms and failed: mkdir() failed: Read-only file system
Mär 24 15:22:14 hostname init: Command 'mkdir /cache/lost+found 0770 root root' action=post-fs (/init.rc:376) took 0ms and failed: mkdir() failed: Read-only file system
Mär 24 15:22:14 hostname init: processing action (late-fs) from (/init.rc:382)
Mär 24 15:22:14 hostname init: Could not start service 'vendor.keymaster-4-0' as part of class 'early_hal': Cannot find '/system/bin/hw/android.hardware.keymaster@4.0-service_ALIEN_DISABLED': No such file or directory
Mär 24 15:22:14 hostname init: Could not start service 'vendor.keymaster-3-0' as part of class 'early_hal': Cannot find '/system/bin/hw/android.hardware.keymaster@3.0-service_ALIEN_DISABLED': No such file or directory
Mär 24 15:22:14 hostname init: processing action (post-fs-data) from (/init.rc:390)
Mär 24 15:22:14 hostname init: starting service 'vold'...
Mär 24 15:22:14 hostname libprocessgroup: Failed to make and chown /acct/uid_0: Read-only file system
Mär 24 15:22:14 hostname init: createProcessGroup(0, 7) failed for service 'vold': Read-only file system
Mär 24 15:22:14 hostname kernel: binder: 9383:9383 --> 0:0 transaction failed 29189/0, size 0-0 line 2149
Mär 24 15:22:14 hostname alienaudioservice[9383]: [AlienAudioService] ERROR: Failed to add AlienAudioService (-394423815)
Mär 24 15:22:14 hostname systemd[5146]: alienaudio.service: Main process exited, code=exited, status=1/FAILURE
Mär 24 15:22:14 hostname systemd[5146]: alienaudio.service: Failed with result 'exit-code'.
Mär 24 15:22:14 hostname init: starting service 'exec 1 (/system/bin/vdc --wait cryptfs init_user0)'...
Mär 24 15:22:14 hostname init: createProcessGroup(0, 8) failed for service 'exec 1 (/system/bin/vdc --wait cryptfs init_user0)': Read-only file system
Mär 24 15:22:14 hostname init: SVC_EXEC pid 8 (uid 0 gid 0+0 context default) started; waiting...
Mär 24 15:22:15 hostname logd.auditd: start
Mär 24 15:22:15 hostname systemd[5146]: Started Alien Keyboard Service.
Mär 24 15:22:15 hostname vdc: Waited 50ms for vold
Mär 24 15:22:15 hostname systemd[5146]: Started Bridge native data to Alien Dalvik.
Mär 24 15:22:15 hostname vdc: Failed: Status(-8): '0: '
Mär 24 15:22:15 hostname init: Service 'exec 1 (/system/bin/vdc --wait cryptfs init_user0)' (pid 8) exited with status 25 waiting took 0.168000 seconds
Mär 24 15:22:15 hostname init: Failure (reboot suppressed): init_user0_failed
Mär 24 15:22:15 hostname init: starting service 'exec 2 (/system/bin/tzdatacheck /system/usr/share/zoneinfo /data/misc/zoneinfo)'...
Mär 24 15:22:15 hostname libprocessgroup: Failed to make and chown /acct/uid_1000: Read-only file system
Mär 24 15:22:15 hostname init: createProcessGroup(1000, 16) failed for service 'exec 2 (/system/bin/tzdatacheck /system/usr/share/zoneinfo /data/misc/zoneinfo)': Read-only file system
Mär 24 15:22:15 hostname init: SVC_EXEC pid 16 (uid 1000 gid 1000+0 context default) started; waiting...
Mär 24 15:22:15 hostname init: Service 'exec 2 (/system/bin/tzdatacheck /system/usr/share/zoneinfo /data/misc/zoneinfo)' (pid 16) exited with status 0 waiting took 0.016000 seconds
Mär 24 15:22:15 hostname init: processing action (post-fs-data) from (/system/etc/init/bootstat.rc:7)
Mär 24 15:22:15 hostname init: processing action (post-fs-data) from (/system/etc/init/incidentd.rc:21)
Mär 24 15:22:15 hostname init: processing action (post-fs-data) from (/system/etc/init/statsd.rc:25)
Mär 24 15:22:15 hostname init: processing action (ro.crypto.state=unsupported && zygote-start) from (/init.rc:573)
Mär 24 15:22:15 hostname init: Command 'exec_start update_verifier_nonencrypted' action=ro.crypto.state=unsupported && zygote-start (/init.rc:575) took 0ms and failed: Service not found
Mär 24 15:22:15 hostname init: starting service 'netd'...
Mär 24 15:22:15 hostname libprocessgroup: Failed to make and chown /acct/uid_0: Read-only file system
Mär 24 15:22:15 hostname init: createProcessGroup(0, 18) failed for service 'netd': Read-only file system
Mär 24 15:22:15 hostname init: Created socket '/dev/socket/netd', mode 660, user 0, group 1000
Mär 24 15:22:15 hostname init: starting service 'zygote'...
Mär 24 15:22:15 hostname init: createProcessGroup(0, 19) failed for service 'zygote': Read-only file system
Mär 24 15:22:15 hostname init: Command 'start zygote_secondary' action=ro.crypto.state=unsupported && zygote-start (/init.rc:578) took 0ms and failed: service zygote_secondary not found
Mär 24 15:22:15 hostname init: processing action (load_persist_props_action) from (/init.rc:274)
Mär 24 15:22:15 hostname init: starting service 'logd-reinit'...
Mär 24 15:22:15 hostname libprocessgroup: Failed to make and chown /acct/uid_1036: Read-only file system
Mär 24 15:22:15 hostname init: createProcessGroup(1036, 20) failed for service 'logd-reinit': Read-only file system
Mär 24 15:22:15 hostname init: processing action (firmware_mounts_complete) from (/init.rc:280)
Mär 24 15:22:15 hostname init: processing action (early-boot) from (/system/etc/init/installd.rc:5)
Mär 24 15:22:15 hostname init: Created socket '/dev/socket/dnsproxyd', mode 660, user 0, group 3003
Mär 24 15:22:15 hostname init: Created socket '/dev/socket/mdns', mode 660, user 0, group 1000
Mär 24 15:22:15 hostname init: Created socket '/dev/socket/fwmarkd', mode 660, user 0, group 3003
Mär 24 15:22:15 hostname init: Created socket '/dev/socket/zygote', mode 660, user 0, group 1000
Mär 24 15:22:15 hostname init: processing action (boot) from (/init.rc:587)
Mär 24 15:22:15 hostname init: Command 'chown root system /sys/module/lowmemorykiller/parameters/adj' action=boot (/init.rc:601) took 0ms and failed: lchown() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chmod 0664 /sys/module/lowmemorykiller/parameters/adj' action=boot (/init.rc:602) took 0ms and failed: fchmodat() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chown root system /sys/module/lowmemorykiller/parameters/minfree' action=boot (/init.rc:603) took 0ms and failed: lchown() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chmod 0664 /sys/module/lowmemorykiller/parameters/minfree' action=boot (/init.rc:604) took 0ms and failed: fchmodat() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chown system system /sys/power/autosleep' action=boot (/init.rc:616) took 0ms and failed: lchown() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chown system system /sys/power/state' action=boot (/init.rc:617) took 0ms and failed: lchown() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chown system system /sys/power/wakeup_count' action=boot (/init.rc:618) took 0ms and failed: lchown() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chown radio wakelock /sys/power/wake_lock' action=boot (/init.rc:619) took 0ms and failed: lchown() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chown radio wakelock /sys/power/wake_unlock' action=boot (/init.rc:620) took 0ms and failed: lchown() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chmod 0660 /sys/power/state' action=boot (/init.rc:621) took 0ms and failed: fchmodat() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chmod 0660 /sys/power/wake_lock' action=boot (/init.rc:622) took 0ms and failed: fchmodat() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chmod 0660 /sys/power/wake_unlock' action=boot (/init.rc:623) took 0ms and failed: fchmodat() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chown system system /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq' action=boot (/init.rc:650) took 0ms and failed: lchown() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chmod 0660 /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq' action=boot (/init.rc:651) took 0ms and failed: fchmodat() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chown system system /sys/class/timed_output/vibrator/enable' action=boot (/init.rc:658) took 0ms and failed: lchown() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chown system system /sys/class/leds/lcd-backlight/brightness' action=boot (/init.rc:660) took 0ms and failed: lchown() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chown system system /sys/kernel/ipv4/tcp_wmem_min' action=boot (/init.rc:670) took 0ms and failed: lchown() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chown system system /sys/kernel/ipv4/tcp_wmem_def' action=boot (/init.rc:671) took 0ms and failed: lchown() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chown system system /sys/kernel/ipv4/tcp_wmem_max' action=boot (/init.rc:672) took 0ms and failed: lchown() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chown system system /sys/kernel/ipv4/tcp_rmem_min' action=boot (/init.rc:673) took 0ms and failed: lchown() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chown system system /sys/kernel/ipv4/tcp_rmem_def' action=boot (/init.rc:674) took 0ms and failed: lchown() failed: Read-only file system
Mär 24 15:22:15 hostname init: Command 'chown system system /sys/kernel/ipv4/tcp_rmem_max' action=boot (/init.rc:675) took 0ms and failed: lchown() failed: Read-only file system
Mär 24 15:22:15 hostname init: starting service 'vendor.audio-hal-2-0'...
Mär 24 15:22:15 hostname libprocessgroup: Failed to make and chown /acct/uid_1041: Read-only file system
Mär 24 15:22:15 hostname init: createProcessGroup(1041, 21) failed for service 'vendor.audio-hal-2-0': Read-only file system
Mär 24 15:22:15 hostname init: Could not start service 'vendor.cas-hal-1-0' as part of class 'hal': Cannot find '/system/bin/hw/android.hardware.cas@1.0-service_ALIEN_DISABLED': No such file or directory
Mär 24 15:22:15 hostname init: starting service 'vendor.configstore-hal'...
Mär 24 15:22:15 hostname init: createProcessGroup(1000, 22) failed for service 'vendor.configstore-hal': Read-only file system
Mär 24 15:22:15 hostname init: starting service 'vendor.hwcomposer-2-1'...
Mär 24 15:22:15 hostname logd.daemon: reinit
Mär 24 15:22:15 hostname init: createProcessGroup(1000, 23) failed for service 'vendor.hwcomposer-2-1': Read-only file system
Mär 24 15:22:15 hostname init: starting service 'hidl_memory'...
