From my experience, removing /home/.android
triggers the Play Protect message (“this device isn’t Play Protect certified”), but reusing an installation that worked with SFOS 3.4 also works after upgrade to SFOS 4. the only issue I have now is that Google Play does not see installed applications, so cannot upgrade them.
I registered the device code and everything is OK except the permissions dialog is not working. I need to go and enable requested permissions for each app in the setting menu.
Google play store is working.
Screen rotation is some kind buggy.
Wrong is to run “some random downloaded script” without having taken a look into it?
You symlinked /home/nemo to the new /home/defaultuser (not only once, it seems, you may remove the obsolete symlink /home/defaultuser/nemo).
But the real problem seems that this script expects the user nemo to exist?
Maybe have a look into it and replace nemo (if found) with defaultuser.
hope this helps someone. I flashed 4.01 today, after a long hiatus from Sailfish. Had to flash down my xperia XA2 ultra to android 9 from lineage 18.1. The old procedure for getting fully functional gplay didn’t work out of the box, so I went with the opengapps script. Little modification and it should work fine once you install unzip manually (pkcon install unzip). you’ll also need to download opengapps 9 pico arm and put it in defaultuser Downloads folder before running the script.
Here’s the modified script:
#!/bin/sh
Install Open GApps to the Alien Dalvik squashfs system.img.
set -e
WORKDIR=/home/.aliendalvik_systemimg_patch
TMPWORKDIR="$WORKDIR/tmp"
SQUASHFS_ROOT="$TMPWORKDIR/squashfs-root"
MOUNT_ROOT="$TMPWORKDIR/systemimg_mount"
SYSTEM_IMG=/opt/alien/system.img
ORIG_IMG_FILE=orig_img_path.txt
FEDORA22_REPO=https://archives.fedoraproject.org/pub/archive/fedora/linux/releases/22/Everything/armhfp/os/Packages
OPENGAPPS_ARCH=arm
OPENGAPPS_API=9.0
OPENGAPPS_VARIANT=pico
GOOGLE_APPS_REMOVE=‘carriersetup extservicesgoogle extsharedgoogle googlebackuptransport googlecontactssync googlefeedback googlepartnersetup’
log() {
printf ‘%s\n’ “$1” > /dev/stderr
install_fedora22_rpm() {
pkgname="$1"
pkgversion="$2"
if ! rpm -q "$pkgname" > /dev/null; then
pkgfile="$pkgname-$pkgversion.fc22.armv7hl.rpm"
firstletter="$(printf '%s' "$pkgfile" | cut -c 1)"
mkdir "$TMPWORKDIR/rpms"
curl "$FEDORA22_REPO/$firstletter/$pkgfile" > "$TMPWORKDIR/rpms/$pkgfile"
pkcon -y install-local "$TMPWORKDIR/rpms/$pkgfile"
rm "$TMPWORKDIR/rpms/$pkgfile"
rmdir "$TMPWORKDIR/rpms"
fi
install_deps() {
if ! rpm -q squashfs-tools > /dev/null; then
pkcon -y install squashfs-tools
fi
install_fedora22_rpm lzip 1.16-1
extract_image() {
mkdir “$MOUNT_ROOT”
mount -o loop,ro “$SYSTEM_IMG” “$MOUNT_ROOT”
if [ -f "$MOUNT_ROOT/$ORIG_IMG_FILE" ]; then
orig_image="$(cat "$MOUNT_ROOT/$ORIG_IMG_FILE")"
log "$SYSTEM_IMG already patched, using original from $orig_image"
else
orig_image="$WORKDIR/system.img.orig.$(date +%Y%m%dT%H%M%S)"
cp "$SYSTEM_IMG" "$orig_image"
log "Copying original image $SYSTEM_IMG to $orig_image"
fi
umount "$MOUNT_ROOT"
if [ ! -f "$orig_image" ]; then
log "$orig_image not found"
return 1
fi
mount -o loop,ro "$orig_image" "$MOUNT_ROOT"
rmdir "$MOUNT_ROOT"
log "$orig_image already patched, please restore original image to $SYSTEM_IMG"
return 1
fi
mkdir "$SQUASHFS_ROOT"
# rsync needs to be run twice to copy all xattrs. Probably a bug in rsync.
rsync -aSHAX "$MOUNT_ROOT/" "$SQUASHFS_ROOT/"
rmdir "$MOUNT_ROOT"
printf '%s' "$orig_image" > "$SQUASHFS_ROOT/$ORIG_IMG_FILE"
build_image() {
cp “$SYSTEM_IMG” “$TMPWORKDIR/system.img.backup”
mksquashfs “$SQUASHFS_ROOT” “$SYSTEM_IMG” -noappend -no-exports -no-duplicates -no-fragments
rm “$TMPWORKDIR/system.img.backup”
rm -r “$SQUASHFS_ROOT”
_find_opengapps() {
downloads="$(runuser -l defaultuser – /usr/bin/xdg-user-dir DOWNLOAD)"
name_pattern=“open_gapps-$OPENGAPPS_ARCH-$OPENGAPPS_API-$OPENGAPPS_VARIANT-*.zip”
if [ “$1” != quiet ]; then
log “Searching for Open GApps zip at $downloads/$name_pattern”
fi
find “$downloads” -maxdepth 1 -name “$name_pattern” | sort | tail -n 1
get_opengapps_zip() {
opengapps_zip="$(_find_opengapps)"
if [ -z “$opengapps_zip” ]; then
# Show the Open GApps download page to the user instead of automating
# the download of the latest version.
# https://opengapps.org/blog/post/2016/03/18/the-no-mirror-policy/
log “Opening Open GApps download page”
runuser -l defaultuser – xdg-open “https://opengapps.org/?download=true&arch=$OPENGAPPS_ARCH&api=$OPENGAPPS_API&variant=$OPENGAPPS_VARIANT”
log “Waiting for download to start”
while [ -z “opengapps_zip" ]; do
sleep 1
opengapps_zip="(_find_opengapps quiet)”
done
log “Detected new download at $opengapps_zip”
log “Waiting for download to finish”
while [ -f “$opengapps_zip” ] && [ -f “$opengapps_zip.part” ]; do
sleep 1
done
sleep 1
if [ ! -f “$opengapps_zip” ]; then
log “Download failed”
return 1
fi
else
log “Found Open GApps zip $opengapps_zip”
fi
printf ‘%s’ “$opengapps_zip”
install_opengapps() {
unzip “$(get_opengapps_zip)” -d “$TMPWORKDIR/opengapps/”
for p in $GOOGLE_APPS_REMOVE; do
rm "$TMPWORKDIR/opengapps/Core/$p-all.tar.lz"
done
if [ -f "$TMPWORKDIR/opengapps/Core/extservicesgoogle-all.tar.lz" ]; then
rm -r "$SQUASHFS_ROOT/system/priv-app/ExtServices"
fi
if [ -f "$TMPWORKDIR/opengapps/Core/extsharedgoogle-all.tar.lz" ]; then
rm -r "$SQUASHFS_ROOT/system/app/ExtShared"
fi
rm "$TMPWORKDIR/opengapps/Core/setupwizardtablet-all.tar.lz"
mkdir "$TMPWORKDIR/opengapps_2"
for f in "$TMPWORKDIR"/opengapps/Core/*.tar.lz; do
lzip -c -d "$f" | tar -x -C "$TMPWORKDIR/opengapps_2"
done
rm -r "$TMPWORKDIR/opengapps/"
cp -r "$TMPWORKDIR"/opengapps_2/*/*/* "$SQUASHFS_ROOT/system/"
rm -r "$TMPWORKDIR/opengapps_2/"
set_traps() {
# shellcheck disable=SC2064
trap “$*” EXIT HUP INT QUIT PIPE TERM
cleanup() {
if [ ! -f “$SYSTEM_IMG” ] && [ -f “$TMPWORKDIR/system.img.backup” ]; then
mv “$TMPWORKDIR/system.img.backup” “$SYSTEM_IMG” || :
fi
umount “$MOUNT_ROOT” || :
rm -r “$TMPWORKDIR” || :
set_traps -
exit 1
set_traps cleanup
systemctl stop aliendalvik
mkdir -p “$WORKDIR”
mkdir -p “$TMPWORKDIR”
install_deps
extract_image
install_opengapps
build_image
rmdir “$TMPWORKDIR”
set_traps -
exit 0
After running the script successfully, you’ll probably need to register your GCM framework device ID to your google account to bypass the annoying uncertified device error, unless this has been done before, or you just get lucky. The instructions are readily available online, and i believe in the error dialog there’s a questionare that you can use to guide you directly to the dialog box. Just pick this is a custom firmware, and you should get to the prompt. Restart the dalvik engine after this is done and the next version of setup will let you log into gapps. You should be able to download right from the play store. I’ve been pulling apps from the store without issue so far, including a couple of paid apps.
good luck, I hope this helps some people!
hey sorry im now using 4.1 will this work? im
currently currently getting errors
