In each case it would be a tremendous help to see the name and remaining time of an alarm / timer on the lock screen. If I’m not mistaken, this kind of feature is pretty standard in other mobile OSes. Here is a picture to illustrate how much unused screen space there is in the lock screen currently. With playback control buttons there is still a lot of space for showing other useful information to the user.
I do understand this is a low priority for Jolla, so I would be curious to know, if this is something that community could help with. And more importantly, I would like to know if other users would find this kind of feature useful.
NAME TYPE SIGNATURE RESULT/VALUE FLAGS
com.nokia.time interface - - -
.add_event method (iuuuuus(a{ss})ua((a{ss})u)a(u(a{ss})a(sb))a(tuuuuu)iia(sb)) u -
.add_events method (a(iuuuuus(a{ss})ua((a{ss})u)a(u(a{ss})a(sb))a(tuuuuu)iia(sb))) av -
.alarms_enabled method - b -
.cancel method u b -
.cancel_events method au au -
.dialog_response method ui b -
.dismiss method u b -
.enable_alarms method b - -
.fake_csd_time_signal method sssiiiii b -
.fake_csd_time_signal_now method sssiii b -
.fake_nitz_signal method iiii b -
.fake_operator_signal method sss b -
.get_alarm_present method - b -
.get_alarm_triggers method - a{uu} -
.get_app_snooze method s i -
.get_attributes_by_cookie method u a{ss} -
.get_attributes_by_cookies method au a{ua{ss}} -
.get_cookies_by_attributes method a{ss} au -
.get_default_snooze method - i -
.get_event method u (iuuuuus(a{ss})ua((a{ss})u)a(u(a{ss})a(sb))a(tuuuuu)iia(sb)) -
.get_events method au (a(iuuuuus(a{ss})ua((a{ss})u)a(u(a{ss})a(sb))a(tuuuuu)iia(sb))) -
.get_wall_clock_info method - (bbbba(iu)asaiai(iu)ssisbs) -
.halt method s - -
.mode method s b -
.parse method s s -
.pid method - i -
.ping method - s -
.query method a{sv} av -
.query_attributes method u a{sv} -
.remove_app_snooze method s - -
.replace_event method (iuuuuus(a{ss})ua((a{ss})u)a(u(a{ss})a(sb))a(tuuuuu)iia(sb))u u -
.set_app_snooze method si b -
.set_default_snooze method i b -
.wall_clock_settings method (u(iu)is) b -
.alarm_present_changed signal b - -
.alarm_triggers_changed signal a{uu} - -
.next_bootup_event signal ii - -
.settings_changed signal (bbbba(iu)asaiai(iu)ssisbs)b - -
.settings_changed_1 signal b - -
org.freedesktop.DBus.Introspectable interface - - -
.Introspect method - s -
org.freedesktop.DBus.Peer interface - - -
.GetMachineId method - s -
.Ping method - - -
org.freedesktop.DBus.Properties interface - - -
.Get method ss v -
.GetAll method s a{sv} -
.Set method ssv - -
.PropertiesChanged signal sa{sv}as - -
