I’m also experiencing this same issue.
After upgrading my XA2 to 3.4.0.24 it stopped syncing to my personal radicale server. I also have a Jolla1 running 3.1.0.11 and it still syncs without any issues.
I did several “remove and reconfigure the CalDAV account” operations on the XA2 but to no avail.
After setting up the credentials, server address, correct paths and clicking “Accept”, my radicale (web)server logs the following:
RE.DA.CT.ED - - [25/Oct/2020:14:13:12 +0200] "HEAD /radicale/ HTTP/1.1" 302 0 "-" "Mozilla/5.0"
RE.DA.CT.ED - - [25/Oct/2020:14:13:12 +0200] "PROPFIND /radicale/CALENDAR_ROOT/ HTTP/1.1" 401 61 "-" "Mozilla/5.0"
RE.DA.CT.ED - USERNAME [25/Oct/2020:14:13:13 +0200] "PROPFIND /radicale/CALENDAR_ROOT/ HTTP/1.1" 207 467 "-" "Mozilla/5.0"
XA2 fetches the available calendars successfully and displays them in the UI:
After the last “Accept” I try to sync, see the following in the server logs and nothing gets synced:
RE.DA.CT.ED - - [25/Oct/2020:14:24:39 +0200] "PROPFIND / HTTP/1.1" 403 1889 "-" "Mozilla/5.0"
RE.DA.CT.ED - - [25/Oct/2020:14:24:39 +0200] "PROPFIND /radicale/CALENDAR_ROOT/ HTTP/1.1" 401 61 "-" "Mozilla/5.0"
RE.DA.CT.ED - USERNAME [25/Oct/2020:14:24:40 +0200] "PROPFIND /radicale/CALENDAR_ROOT/ HTTP/1.1" 403 61 "-" "Mozilla/5.0"
A successfull sync with the Jolla1 and 3.1.0.11 looks like this:
RE.DA.CT.ED - - [25/Oct/2020:15:08:20 +0200] "REPORT /radicale/CALENDAR_ROOT/CALENDAR/ HTTP/1.1" 401 61 "-" "Mozilla/5.0"
RE.DA.CT.ED - USERNAME [25/Oct/2020:15:08:21 +0200] "REPORT /radicale/CALENDAR_ROOT/CALENDAR/ HTTP/1.1" 207 3577 "-" "Mozilla/5.0"
RE.DA.CT.ED - USERNAME [25/Oct/2020:15:08:22 +0200] "REPORT /radicale/CALENDAR_ROOT/CALENDAR/ HTTP/1.1" 207 8197 "-" "Mozilla/5.0"
As outlined in the wiki page, I logged the output of msyncd on both devices and tried to figure out what is going wrong, but maybe someone more knowledgeable could figure out what am I seeing here; I just have a vague hunch that login credentials to the CalDAV server are lost / not provided correctly:
Failed sync with 3.4.0.24
[D] unknown:0 - Starting Log At : QDateTime(2020-10-25 17:54:26.813 EET Qt::TimeSpec(LocalTime))
[D] unknown:0 - Primary profile path set to "/home/nemo/.cache/msyncd"
[D] unknown:0 - Secondary profile path set to "/etc/buteo/profiles"
[D] unknown:0 - Starting msyncd
[D] unknown:0 - Registered to D-Bus
[D] unknown:0 - New network state: true New type: "LTE" ( 10 )
[D] unknown:0 - Network status:
[D] unknown:0 - Online:: true
[D] unknown:0 - Connection:: 10
[D] unknown:0 - Starting/Resuming server plug-ins
[D] unknown:0 - "No carrier"
[D] unknown:0 - Registered sync backup to D-Bus
[D] unknown:0 - Synchronizer::getBackUpRestoreState
[D] unknown:0 - Sync externally is off for profile: "caldav-sync-37"
[D] unknown:0 - Sync externally is off for profile: "carddav.Contacts-37"
[D] unknown:0 - lastSync: QDateTime(2020-10-25 17:01:16.000 EET Qt::TimeSpec(LocalTime))
[D] unknown:0 - aPrevSync "Sun Oct 25 17:01:16 2020" Last Configured Time "" CurrentDateTime QDateTime(2020-10-25 17:54:26.913 EET Qt::TimeSpec(LocalTime))
[D] unknown:0 - Sync interval defined as 60
[D] unknown:0 - numberOfInterval: 1 interval time 60
[D] unknown:0 - next non rush hour sync is at:: QDateTime(2020-10-25 18:01:16.000 EET Qt::TimeSpec(LocalTime))
[D] unknown:0 - nextSync "Sun Oct 25 18:01:16 2020"
[D] unknown:0 - BackgroundSync::set() profile name = "syncemail-4" with frequency 6 minutes, waiting.
[D] unknown:0 - Sync externally is off for profile: "syncemail-4"
[D] unknown:0 - lastSync: QDateTime(2020-10-25 17:01:19.000 EET Qt::TimeSpec(LocalTime))
[D] unknown:0 - aPrevSync "Sun Oct 25 17:01:19 2020" Last Configured Time "" CurrentDateTime QDateTime(2020-10-25 17:54:26.915 EET Qt::TimeSpec(LocalTime))
[D] unknown:0 - next non rush hour sync is at:: QDateTime(2020-10-25 18:01:19.000 EET Qt::TimeSpec(LocalTime))
[D] unknown:0 - nextSync "Sun Oct 25 18:01:19 2020"
[D] unknown:0 - BackgroundSync::set() profile name = "syncemail-5" with frequency 6 minutes, waiting.
[D] unknown:0 - Sync externally is off for profile: "syncemail-5"
[D] unknown:0 - No profiles interested in SOC
[D] unknown:0 - Entering event loop
[D] unknown:0 - AccountsHelper::registerAccountListener() is disabled! Not listening to change signals for account: 37
[D] unknown:0 - AccountsHelper::registerAccountListener() is disabled! Not listening to change signals for account: 17
[D] unknown:0 - AccountsHelper::registerAccountListener() is disabled! Not listening to change signals for account: 5
[D] unknown:0 - AccountsHelper::registerAccountListener() is disabled! Not listening to change signals for account: 4
[D] unknown:0 - Start sync requested for profile: "caldav-sync-37"
[D] unknown:0 - Starting sync with profile "caldav-sync-37"
[D] unknown:0 - Disable sync on change: false false
[D] unknown:0 - Starting oop plugin "caldav-sync-37"
[D] unknown:0 - Starting process "/usr/lib/buteo-plugins-qt5//oopp/caldav-client" with plugin name "caldav" and profile name "caldav-sync-37"
[D] unknown:0 - attempting to register dbus service: "com.buteo.msyncd.plugin.caldav-sync-37"
[D] unknown:0 - Plugin "caldav" with profile "caldav-sync-37" registered at dbus "com.buteo.msyncd.plugin.caldav-sync-37" and path /
[D] unknown:0 - Process "/usr/lib/buteo-plugins-qt5//oopp/caldav-client" started with pid 12240
[D] unknown:0 - Client plug-in runner initialized
[D] unknown:0 - sync-ui dbus interface is getting called
[D] unknown:0 - Sync session started
[D] unknown:0 - ClientPluginRunner started thread for plugin: "caldav-sync-37" , returning: true
[D] unknown:0 - attempt to start sync session due to network session opened succeeded.
[D] unknown:0 - Sync status changed for account "37"
[D] unknown:0 - Initiating config...
[D] unknown:0 - Sync running for 37
[D] unknown:0 - Init done. Continuing with sync
[D] unknown:0 - Authenticated!
[D] unknown:0 - "---------------------------------------------------------------------"
[D] unknown:0 - "Depth : 1"
[D] unknown:0 - "Prefer : return-minimal"
[D] unknown:0 - "Content-Length : 93"
[D] unknown:0 - "Content-Type : application/xml; charset=utf-8"
[D] unknown:0 - "URL = https://user:pass@REDACTED/"
[D] unknown:0 - "Request : PROPFIND"
[D] unknown:0 - "<d:propfind xmlns:d=\"DAV:\"> <d:prop> <d:current-user-principal /> </d:prop></d:propfind>"
[D] unknown:0 - Process PROPFIND response.
[D] unknown:0 - The "PROPFIND" operation requested on the remote content is not permitted
[W] unknown:0 - Cannot find the calendar root for this user, guess it from account.
[D] unknown:0 - "Content-Length : 220"
[D] unknown:0 - "URL = https://user:pass@REDACTED/radicale/CALENDAR_ROOT/"
[D] unknown:0 - "<d:propfind xmlns:d=\"DAV:\" xmlns:a=\"http://apple.com/ns/ical/\"> <d:prop> <d:resourcetype /> <d:current-user-principal /> <d:current-user-privilege-set /> <d:displayname /> <a:calendar-color /> </d:prop></d:propfind>"
[D] unknown:0 - CalDAV sync succeeded! "No calendars for this account"
[D] unknown:0 - Session finished: "caldav-sync-37" , status: 4
[D] unknown:0 - ProfileManager::enableStorages
[D] unknown:0 - Clean up session for profile "caldav-sync-37"
[D] unknown:0 - Stopping the OOP process for "caldav"
[D] unknown:0 - Process "/usr/lib/buteo-plugins-qt5//oopp/caldav-client" finished with exit code 15
[D] unknown:0 - lastSync: QDateTime(2020-10-25 17:54:34.000 EET Qt::TimeSpec(LocalTime))
[D] unknown:0 - lastSync: QDateTime( Qt::TimeSpec(LocalTime))
Successful sync with 3.1.0.11
[D] unknown:0 - Starting Log At : QDateTime(2020-10-25 17:38:22.221 EET Qt::TimeSpec(LocalTime))
[D] unknown:0 - New network state: true New type: "WLAN" ( 2 )
[D] unknown:0 - Connection:: 2
[W] unknown:0 - This device does not have a BT adapter
[D] unknown:0 - ProfileManager::syncProfile( "caldav-sync-28" )
[D] unknown:0 - found a valid sync profile with the given name: "caldav-sync-28"
[D] unknown:0 - ProfileManager::syncProfile( "carddav.Contacts-28" )
[D] unknown:0 - found a valid sync profile with the given name: "carddav.Contacts-28"
[D] unknown:0 - ProfileManager::syncProfile( "syncemail-29" )
[D] unknown:0 - found a valid sync profile with the given name: "syncemail-29"
[D] unknown:0 - ProfileManager::syncProfile( "syncemail-8" )
[D] unknown:0 - found a valid sync profile with the given name: "syncemail-8"
[D] unknown:0 - ProfileManager::syncProfile( "caldav-sync" )
[D] unknown:0 - found a valid sync profile with the given name: "caldav-sync"
[D] unknown:0 - No sync log found for profile: "caldav-sync"
[D] unknown:0 - ProfileManager::syncProfile( "carddav.Contacts" )
[D] unknown:0 - found a valid sync profile with the given name: "carddav.Contacts"
[D] unknown:0 - No sync log found for profile: "carddav.Contacts"
[D] unknown:0 - ProfileManager::syncProfile( "dropbox.Backup" )
[D] unknown:0 - found a valid sync profile with the given name: "dropbox.Backup"
[D] unknown:0 - No sync log found for profile: "dropbox.Backup"
[D] unknown:0 - ProfileManager::syncProfile( "dropbox.Images" )
[D] unknown:0 - found a valid sync profile with the given name: "dropbox.Images"
[D] unknown:0 - No sync log found for profile: "dropbox.Images"
[D] unknown:0 - ProfileManager::syncProfile( "facebook.Calendars" )
[D] unknown:0 - found a valid sync profile with the given name: "facebook.Calendars"
[D] unknown:0 - No sync log found for profile: "facebook.Calendars"
[D] unknown:0 - ProfileManager::syncProfile( "facebook.Contacts" )
[D] unknown:0 - found a valid sync profile with the given name: "facebook.Contacts"
[D] unknown:0 - No sync log found for profile: "facebook.Contacts"
[D] unknown:0 - ProfileManager::syncProfile( "facebook.Images" )
[D] unknown:0 - found a valid sync profile with the given name: "facebook.Images"
[D] unknown:0 - No sync log found for profile: "facebook.Images"
[D] unknown:0 - ProfileManager::syncProfile( "facebook.Signon" )
[D] unknown:0 - found a valid sync profile with the given name: "facebook.Signon"
[D] unknown:0 - No sync log found for profile: "facebook.Signon"
[D] unknown:0 - ProfileManager::syncProfile( "google.Calendars" )
[D] unknown:0 - found a valid sync profile with the given name: "google.Calendars"
[D] unknown:0 - No sync log found for profile: "google.Calendars"
[D] unknown:0 - ProfileManager::syncProfile( "google.Contacts" )
[D] unknown:0 - found a valid sync profile with the given name: "google.Contacts"
[D] unknown:0 - No sync log found for profile: "google.Contacts"
[D] unknown:0 - ProfileManager::syncProfile( "google.Signon" )
[D] unknown:0 - found a valid sync profile with the given name: "google.Signon"
[D] unknown:0 - No sync log found for profile: "google.Signon"
[D] unknown:0 - ProfileManager::syncProfile( "onedrive.Backup" )
[D] unknown:0 - found a valid sync profile with the given name: "onedrive.Backup"
[D] unknown:0 - No sync log found for profile: "onedrive.Backup"
[D] unknown:0 - ProfileManager::syncProfile( "onedrive.Images" )
[D] unknown:0 - found a valid sync profile with the given name: "onedrive.Images"
[D] unknown:0 - No sync log found for profile: "onedrive.Images"
[D] unknown:0 - ProfileManager::syncProfile( "onedrive.Signon" )
[D] unknown:0 - found a valid sync profile with the given name: "onedrive.Signon"
[D] unknown:0 - No sync log found for profile: "onedrive.Signon"
[D] unknown:0 - ProfileManager::syncProfile( "sociald.All" )
[D] unknown:0 - found a valid sync profile with the given name: "sociald.All"
[D] unknown:0 - No sync log found for profile: "sociald.All"
[D] unknown:0 - ProfileManager::syncProfile( "syncemail" )
[D] unknown:0 - found a valid sync profile with the given name: "syncemail"
[D] unknown:0 - No sync log found for profile: "syncemail"
[D] unknown:0 - ProfileManager::syncProfile( "twitter.Notifications" )
[D] unknown:0 - found a valid sync profile with the given name: "twitter.Notifications"
[D] unknown:0 - No sync log found for profile: "twitter.Notifications"
[D] unknown:0 - ProfileManager::syncProfile( "twitter.Posts" )
[D] unknown:0 - found a valid sync profile with the given name: "twitter.Posts"
[D] unknown:0 - No sync log found for profile: "twitter.Posts"
[D] unknown:0 - ProfileManager::syncProfile( "vk.Calendars" )
[D] unknown:0 - found a valid sync profile with the given name: "vk.Calendars"
[D] unknown:0 - No sync log found for profile: "vk.Calendars"
[D] unknown:0 - ProfileManager::syncProfile( "vk.Contacts" )
[D] unknown:0 - found a valid sync profile with the given name: "vk.Contacts"
[D] unknown:0 - No sync log found for profile: "vk.Contacts"
[D] unknown:0 - ProfileManager::syncProfile( "vk.Images" )
[D] unknown:0 - found a valid sync profile with the given name: "vk.Images"
[D] unknown:0 - No sync log found for profile: "vk.Images"
[D] unknown:0 - ProfileManager::syncProfile( "vk.Notifications" )
[D] unknown:0 - found a valid sync profile with the given name: "vk.Notifications"
[D] unknown:0 - No sync log found for profile: "vk.Notifications"
[D] unknown:0 - ProfileManager::syncProfile( "vk.Posts" )
[D] unknown:0 - found a valid sync profile with the given name: "vk.Posts"
[D] unknown:0 - No sync log found for profile: "vk.Posts"
[D] unknown:0 - Sync externally is off for profile: "caldav-sync-28"
[D] unknown:0 - Sync externally is off for profile: "carddav.Contacts-28"
[D] unknown:0 - lastSync: QDateTime(2020-10-25 17:33:55.000 EET Qt::TimeSpec(LocalTime))
[D] unknown:0 - aPrevSync "Sun Oct 25 17:33:55 2020" Last Configured Time "" CurrentDateTime QDateTime(2020-10-25 17:38:22.456 EET Qt::TimeSpec(LocalTime))
[D] unknown:0 - Sync interval defined as 15
[D] unknown:0 - numberOfInterval: 1 interval time 15
[D] unknown:0 - next non rush hour sync is at:: QDateTime(2020-10-25 17:48:55.000 EET Qt::TimeSpec(LocalTime))
[D] unknown:0 - nextSync "Sun Oct 25 17:48:55 2020"
[D] unknown:0 - BackgroundSync::set() profile name = "syncemail-29" with frequency 10 minutes, waiting.
[D] unknown:0 - Sync externally is off for profile: "syncemail-29"
[D] unknown:0 - lastSync: QDateTime(2020-10-25 17:33:53.000 EET Qt::TimeSpec(LocalTime))
[D] unknown:0 - aPrevSync "Sun Oct 25 17:33:53 2020" Last Configured Time "" CurrentDateTime QDateTime(2020-10-25 17:38:22.465 EET Qt::TimeSpec(LocalTime))
[D] unknown:0 - Sync interval defined as 30
[D] unknown:0 - numberOfInterval: 1 interval time 30
[D] unknown:0 - next non rush hour sync is at:: QDateTime(2020-10-25 18:03:53.000 EET Qt::TimeSpec(LocalTime))
[D] unknown:0 - nextSync "Sun Oct 25 18:03:53 2020"
[D] unknown:0 - BackgroundSync::set() profile name = "syncemail-8" with frequency 25 minutes, waiting.
[D] unknown:0 - Sync externally is off for profile: "syncemail-8"
[D] unknown:0 - AccountsHelper::registerAccountListener() is disabled! Not listening to change signals for account: 29
[D] unknown:0 - AccountsHelper::registerAccountListener() is disabled! Not listening to change signals for account: 28
[D] unknown:0 - AccountsHelper::registerAccountListener() is disabled! Not listening to change signals for account: 14
[D] unknown:0 - AccountsHelper::registerAccountListener() is disabled! Not listening to change signals for account: 8
[D] unknown:0 - Start sync requested for profile: "caldav-sync-28"
[D] unknown:0 - Starting sync with profile "caldav-sync-28"
[D] unknown:0 - Starting oop plugin "caldav-sync-28"
[D] unknown:0 - Starting process "/usr/lib/buteo-plugins-qt5//oopp/caldav-client" with plugin name "caldav" and profile name "caldav-sync-28"
[D] unknown:0 - attempting to register dbus service: "com.buteo.msyncd.plugin.caldav-sync-28"
[D] unknown:0 - Plugin "caldav" with profile "caldav-sync-28" registered at dbus "com.buteo.msyncd.plugin.caldav-sync-28" and path /
[D] unknown:0 - Process "/usr/lib/buteo-plugins-qt5//oopp/caldav-client" started with pid 7872
[D] unknown:0 - ClientPluginRunner started thread for plugin: "caldav-sync-28" , returning: true
[D] unknown:0 - Sync status changed for account "28"
[D] unknown:0 - connection-manager.cpp 107 setupSocketConnection p2p error: QDBusError("org.freedesktop.DBus.Error.FileNotFound", "Failed to connect to socket /run/user/100000/signond/socket: No such file or directory") 1
[D] unknown:0 - connection-manager.cpp 148 init Peer connection unavailable, activating service
[D] unknown:0 - identityimpl.cpp 96 updateState Updating state: "PendingRegistration" SignOn::IdentityImpl(0x2092c00)
[D] unknown:0 - authsessionimpl.cpp 94 initInterface
[D] unknown:0 - Sync running for 28
[D] unknown:0 - connection-manager.cpp 165 init Connected to "libsignon-qt1"
[D] unknown:0 - identityimpl.cpp 96 updateState Updating state: "Ready" SignOn::IdentityImpl(0x2092c00)
[D] unknown:0 - identityimpl.cpp 96 updateState Updating state: "NeedsUpdate" SignOn::IdentityImpl(0x2092c00)
[D] unknown:0 - identityimpl.cpp 96 updateState Updating state: "PendingUpdate" SignOn::IdentityImpl(0x2092c00)
[D] unknown:0 - identityimpl.cpp 442 infoUpdated SERVER INFO UPDATED. NeedsUpdate " 30 "
[W] unknown:0 - sqlitestorage.cpp: 193 - database "/home/nemo/.local/share/system/privileged/Calendar/mkcal/db" opened
[D] unknown:0 - found notebook: "b772ad20-eaf7-4842-b84f-06edeafd221a" for remote calendar: "/radicale/CALENDAR_ROOT/CALENDAR/"
[D] unknown:0 - Start quick sync for notebook: "b772ad20-eaf7-4842-b84f-06edeafd221a" between QDateTime(2020-04-25 15:38:36.779 UTC Qt::TimeSpec(UTC)) to QDateTime(2021-10-25 15:38:36.779 UTC Qt::TimeSpec(UTC)) , sync changes since QDateTime(2020-10-25 15:14:07.000 UTC Qt::TimeSpec(UTC))
[D] unknown:0 - "Content-Length : 302"
[D] unknown:0 - "URL = https://user:pass@REDACTED/radicale/CALENDAR_ROOT/CALENDAR/"
[D] unknown:0 - "Request : REPORT"
[D] unknown:0 - "<c:calendar-query xmlns:d=\"DAV:\" xmlns:c=\"urn:ietf:params:xml:ns:caldav\"><d:prop><d:getetag /></d:prop><c:filter><c:comp-filter name=\"VCALENDAR\"><c:comp-filter name=\"VEVENT\"> <c:time-range start=\"20200425T153836Z\" end=\"20211025T153836Z\" /></c:comp-filter></c:comp-filter></c:filter></c:calendar-query>"
[D] unknown:0 - identityimpl.cpp 381 getInfoReply QMap(("ACL", QVariant(QStringList, ()))("AuthMethods", QVariant(QDBusArgument, ))("Caption", QVariant(QString, "Jolla"))("Id", QVariant(uint, 30))("Owner", QVariant(QStringList, ()))("Realms", QVariant(QStringList, ()))("RefCount", QVariant(int, 0))("StoreSecret", QVariant(bool, true))("Type", QVariant(int, 0))("UserName", QVariant(QString, "USERNAME"))("UserNameSecret", QVariant(bool, false))("Validated", QVariant(bool, true)))
[D] unknown:0 - Process REPORT response for server path "/radicale/CALENDAR_ROOT/CALENDAR/"
[D] unknown:0 - "REPORT response status code: 207"
[D] unknown:0 - "REPORT response headers:"
[D] unknown:0 - "\tServer : nginx/1.16.1"
[D] unknown:0 - "\tDate : Sun, 25 Oct 2020 15:38:37 GMT"
[D] unknown:0 - "\tContent-Type : text/xml; charset=utf-8"
[D] unknown:0 - "\tConnection : keep-alive"
[D] unknown:0 - "\tContent-Encoding : gzip"
[D] unknown:0 - "REPORT response data:<?xml version='1.0' encoding='utf-8'?>"
<<REDACTED MULTIPLE LINES>>
[D] unknown:0 - Process tags for server path "/radicale/CALENDAR_ROOT/CALENDAR/"
[D] unknown:0 - Calculated local A/M/R: 0 / 1 / 0
[D] unknown:0 - Calculated remote A/M/R: 19 / 0 / 0
[D] unknown:0 - "Content-Length : 2495"
[D] unknown:0 - "\tDate : Sun, 25 Oct 2020 15:38:38 GMT"
[D] unknown:0 - "</C:calendar-data></prop><status>HTTP/1.1 200 OK</status></propstat></response></multistatus>"
[D] unknown:0 - iCal data contains 1 VEVENT instances
[D] unknown:0 - Report request finished: received: 4 iCal blobs containing a total of 4 incidences of which 3 incidences were remote additions/modifications
[D] unknown:0 - no local changes to upsync - finished with notebook "CALENDAR_ROOT/CALENDAR" "/radicale/CALENDAR_ROOT/CALENDAR/"
[D] unknown:0 - Notebook sync finished. Total agents: 1
[D] unknown:0 - Calendar storage saved successfully after writing notebook changes!
[D] unknown:0 - CalDAV sync succeeded! ""
[D] unknown:0 - Session finished: "caldav-sync-28" , status: 4
[D] unknown:0 - aStatus 4
[D] unknown:0 - lastSync: QDateTime(2020-10-25 15:38:39.000 UTC Qt::TimeSpec(UTC))
