AdaHome: Minimalistic Homescreen and Top Menu Notifications
I wanted a minimal phone UI on my Jolla Phone, and a few things about the stock homescreen kept bugging me. So I rearranged it with a Patchmanager patch. I’m new to Sailfish and to how its homescreen works inside, so there are surely smarter ways to do some of this. If you see something I got wrong, or know a better approach, please tell me.
Why I built it
AdaHome moves things around in the stock homescreen rather than replacing it:
  • A calm Home. In the running apps grid, where an app sits depended on when and in what order you opened your apps, and it changed again whenever you closed one. Closing all apps to “clean up” just started the shuffle over. To me that felt messy. So Home is now a clock, the date and up to 8 apps as plain text. The running apps moved to the second page, where the notifications used to be.
  • Notifications at the top. New notifications have always slid in from the top and hide back up there, so to me it only makes sense to find them there too. Most other systems do it that way, so it should also feel familiar to newcomers. They’re now in the Top menu, below the toggles, and you can swipe them away directly, without a long-press first.
  • It feels snappier. Before when I opened an app, I didn’t see the app but the (messy) homescreen for a couple of seconds until it started. Now a loading screen with the app’s icon and name shows right away. Apps don’t start any faster of course, but it feels a lot faster.
  • Links land where they should. When I tapped a link in an Android app like WhatsApp or Signal, I sometimes ended up looking at the running apps and had to find and tap the browser myself. Now AdaHome handles links smoothly for you.
Quickstart guide
  • Tap the clock or the date to open your clock or calendar app. Long-press them to choose which app that is (any app, also Android ones).
  • Long-press an app to choose another one from a searchable list. To rename it, type the new name and tap Rename.
  • Swipe left or right in the middle of the screen to open an app of your choice (by default Calculator and Contacts). Swipes from the screen edge still switch to the second page.
  • Long-press on empty space opens the settings, with the clock staying visible on top so you see changes right away.
  • Optional: double tap to lock, a hidden status bar that shows up when you touch the screen, and hiding the alarm bell (your alarms are listed on the second page anyway).
More screenshots
All settings
All values are stored in dconf under /desktop/lipstick-jolla-home/ada_home/.
Section Setting Default Key
Home screen Apps on home screen 4 slot_count
Show date time (Off / On / Date only) On date_time
App alignment (Left / Center / Right) Left alignment
Layout Apps at the bottom Off bottom
Side margin, Top margin, Bottom margin (steps of one standard spacing) 0 margin_side, margin_top, margin_bottom
Clock to apps distance (Auto = centred) Auto apps_gap
Always small covers (running apps 3 per row) On small_covers
Weather header (on the second page) On weather_header
Appearance Text size 1.0 text_scale
Bold font Off bold
Text shadow (Off / Small / Medium / Large) Small shadow_level
Text color (Ambience / Ambience highlight / White / Black) Ambience text_color
Hide status bar (on Home; touching Home shows it for a moment) Off hide_status_bar
Hide status bar clock (on Home only; in apps it stays) On hide_status_clock
Hide alarm bell (in the status bar; alarms stay listed on the second page) Off hide_alarm_bell
Auto show keyboard (in the app list) On auto_keyboard
Gestures Swipe left app, Swipe right app Calculator, Contacts swipe_left_app, swipe_right_app
Double tap to lock Off double_tap_lock
Patch compatibility
AdaHome doesn’t change any status bar file, so I expect status bar patches to work alongside it. These are active together with AdaHome on my phone right now:
  • Launcher Search List 0.2.6
  • Compact Battery 0.1.2
  • Compact Cellular Indicator
Patches that change the same lines of the homescreen as AdaHome can’t be active at the same time. I think that’s most likely for patches that change the notifications, the Top menu or the covers page. Anything a patch adds to the Events view won’t show.
Install
You need Patchmanager (3.x). AdaHome is in the Patchmanager web catalog:
  1. Settings → Patchmanager → pull down → Web Catalog, open AdaHome and tap the newest version under Files to install it.
  2. Back in Patchmanager: activate AdaHome, then pull down → Restart preloaded services. This restarts the homescreen and closes your open apps.
Install as an RPM instead
Use either the catalog or the RPM, not both: they install into the same folder.
  1. Download ada-home-sailfish-<version>-<release>.noarch.rpm from the releases on the phone and tap it in the file manager to install it (with developer mode on).
  2. Activate it as in step 2 above.
Updating: install the new RPM the same way. It deactivates AdaHome before replacing its files, so activate it again afterwards. Your settings stay. There’s no update notification for the RPM.
Uninstall
Settings → Patchmanager → long-press AdaHome → Deactivate, then long-press it again → Remove. The homescreen is stock again after Restart preloaded services or a reboot. Your AdaHome settings stay in dconf; dconf reset -f /desktop/lipstick-jolla-home/ada_home/ removes them.
Source & Download
Made with the help of Claude. Tested on my Jolla Phone (2026), SFOS 5.2.0.22 - use at your own risk.
Hi,
I’ve tested the new patch and I love it!
One piece of feedback: swiping to the left doesn’t work properly. Sometimes the left panel appears, but at other times the status bar slides down along with it instead of the app. It’s not very reliable.
Otherwise, everything is great. Best regards,
Hey, thanks for testig and for the feedback. I will try to reproduce that behavior later so i can fix it - on my setup i dont have that issue currently.
since you said “to the left” is assume a swipe from the right to the left which changes depending on where you start the swipe:
  • starting from the screen edge shows the secondary page
  • starting from somewhere on the screen (closer to the middle) opens the calculator by default.
The top menu should never ever come down on any horizontal swipe. Are you maybe doing the gesture a bit diagonal? If not i really need to look into this.
Hope that helps, otherwise please let me know more details so i can fix it up for you :grin:
If you swipe it from the center as you suggest, it works. But if you do it quickly and your finger moves down a little, it’s the status bar you see.
Thanks a lot, that detail was exactly what I needed! The Top menu took over the touch as soon as the finger moved a few millimetres down, even when the swipe was mostly sideways. Now, once a swipe goes more sideways than down, it stays a swipe and opens the app (it works on my phone, also with quick, slightly diagonal swipes). Pulling straight down still opens the Top menu.
The fix is in version 0.3.2, which is now in the Patchmanager web catalog and on GitHub. To update: open Settings → Patchmanager → Web Catalog → AdaHome and tap 0.3.2 under Files. Then deactivate and activate AdaHome once (otherwise the old version keeps running) and pull down → Restart preloaded services. Please let me know if it works for you too!
If you don’t want to check yourself, Patchmanager looks for updates every 2 hours or so and shows an “Update available” notification. You still install it as above and de- and reactivate the patch.
Let me know if that fixed it for you :slight_smile:
Works excellently. Thanks
Web app no longer starts after patch update After applying the latest patch update, the web application can no longer be started. **Symptoms** - Starting the web app no longer works; the browser is not responding (no error message, no response). - On the second page, the web app tile is still displayed correctly. - When the app is launched via the tile, a black screen appears. This is done with the built-in browser
Thanks for reporting this, and great to hear the swipes work now!
I could reproduce it on my phone and it was quite the tough nut to crack. While testing I also found and fixed that tapping the cover of a running Terminal (and probably some other native apps) didn’t open it.
Both fixes are in version 0.3.3, which is on GitHub now and should show up in the Patchmanager web catalog soon. As before, after installing the update deactivate and activate AdaHome once, then pull down → Restart preloaded services.
Thanks, everything’s working now.
great, thanks for the info. Please lmk if you run into any more issues :+1:
I really like your approach. I’ve been using your patch for a few days now and I might keep it. One suggestion though: Could you include an option to have the running apps below the listed apps on the home screen? I find having to swipe twice from the edge of the screen to get to another opened app quite cumbersome. The other modifications speed up my workflow. Thanks!
Also: The mastodon notifications don’t show up after using your patch. You might want to include the option to keep the notifications where they are in vanilla Sfos.
To sum up: App list: great! Clock: great! Left and right swipe for favourite apps: Ace!
Imho, the rest should be configurable.
Thank you for your work. I use your patch and find it very compfy. One thing I would be change is leave the notifications as it is in vanila SailfishOS, not in the top menu. Maybe it make sense to add configureration for the notifications location - top menu or left side.
Thank you
Thanks for the kind words. I also find the current double swipe to open a recent app a bit tedious. What bugs me even more tho is that i can never seem to find the app that i want to switch to in the grid - i had that problem with the default launcher before aswell. so maybe sorting the running apps by most recent would also be a good first step.
i would have to look into offering both versions of running apps (primary and/or secondary) screen as an option. it was quite the task to get this part of the system working as is now but maybe with all the effort and learnings it would be easier the second time around. gotta think on that a bit as to how to integrate the running apps without losing the minimalist style - might be difficult.
about the mastodon notifications: are you using a native, web or android app? any more info on that would be helpful so i can reproduce the issue on my end and fix it. Because as it stands I have not had issues with notifications.
Thanks again :+1:
I’m using the native mastodon integration that sfos has been offering for a while. You can add it in settings / accounts.
(post deleted by author)
