I wiped /etc/connman/main.conf on my Xperia 10 III, and can’t reflesh it right now.
- Can someone show that content?
cat /etc/connman/main.conf
- Where can i find this file myself?
Thanks.
Thanks.
[General]
FallbackTimeservers = 0.sailfishos.pool.ntp.org,1.sailfishos.pool.ntp.org,2.
sailfishos.pool.ntp.org,3.sailfishos.pool.ntp.org
NetworkInterfaceBlacklist = p2p,usb,rmnet,rev_rmnet
SingleConnectedTechnology = false
Ipv4StatusUrl = http://ipv4.jolla.com/return_204
Ipv6StatusUrl = http://ipv6.jolla.com/return_204
PreferredTechnologies = bluetooth,ethernet,wifi,cellular
DefaultAutoConnectTechnologies = ethernet
PersistentTetheringMode = false
AllowHostnameUpdates = false
TetheringSubnetBlock = 172.28.172.0
DontBringDownAtStartup = rndis
InputRequestTimeout = 300
# ConnMan will create dir "connman", no need to define here.
StorageRoot = /home/.system/var/lib
# In case uevent for rndis0 does not contain DEVTYPE=gadget
FallbackDeviceTypes = rndis0:gadget
# Enable login manager for multiuser environment. This enables systemd login
support.
EnableLoginManager = true
# Use timed localtime path
Localtime = /var/lib/timed/localtime
# Enable regdomain changes with timezone changes
RegdomFollowsTimezone = true
mkdir /tmp/foo
cd /tmp/foo
# download the package
pkcon download /tmp/foo connman-configs-sailfish
# unpack the package here
rpm2cpio connman-configs-sailfish*rpm | cpio - id
# show what has been unpacked
ls -lR /tmp/foo
