I only discovered Sailfish OS a little while ago and I was extremely mindblown when I learned about it. The interface looks so, SO good! This might just be the most matured “Linux on mobile distro” that I have seen so far. It looks very userfriendly and the porting guide was amazing - I read the whole 63 pages. It was a fantastic read.
Now, I have been looking for a way to get away from iOS. These days, I am trying out an Android phone (Razer Phone 2 - which is my porting target) and it’s accessibility features… well, they exist. But this is still farther than some of the feature sets in GNOME, Plasma and other Linux DEs that are being “ported” to mobile. Meanwhile, SFOS was never a desktop shell in the first place - from what I figured. But as such, it never really needed accessibility features.
So, I would love to request these.
In detail:
Screen Magnification
On iOS, this is a double-tap with three fingers.
On Android, this is a tripple tap with one finger (which conflicts with turning on developer settings. Derp…?)
Color Inversion
Some apps, but most specifically websites, use a bright theme. This can be very difficult for people that have issues with very bright light and can’t read black text on a white background. I have that issue - and trust me, especially during the iPhone 4S days, my retina felt like it was set ablaze more often than not…
On iOS, this can be turned on using a tripple-tab on the home- or side button.
On Android, this can be turned on by holding Vol+ and Vol-. Annoyingly, that also plays a notification sound…
Screen Reader
Plain simple: Since SFOS uses Qt, and almost that exclusively, NVDA or Orca should really just work. Some customization might be preferable though, but for most of the basics, it’ll do. Most of the customization would probably go into touch control (change reading language, “tab” between controls, reading labels, …)
On iOS, it can be turned on with either a tripple-press of the home or power button
On Android, it can be turned on with Vol+ and Vol-. It might also be triggered by other means, that I haven’t explored yet…
Color-Blind / Greyscale
This really is just a color-filtering shader.
There usually are no shortcuts for it.
Voice Control
Might become useful eventually, where simple voice commands (Open app …, select textbox …, call contact …)
Bigger (system wide) text
Explains itself.
For me, personally, the most important part is the screen magnification. But I thought I’d list the others just in case.
Let’s see what becomes of this! In the meantime, I am going to try and port SFOS to the Razer Phone 2 so I have an actual “test device”.
Well, since OP mentions Accessibility, i think the point is that some people need it more than others. You and i may do just fine with normal font size, and zoom only where it is an explicitly added feature. Others may need it system-wide… and i believe that is what’s being asked for.
Given that the UI zooms in when you are moving the cursor in text entry i suspect it wont be quite hard to make it zoom in other areas for accessibility purposes. No idea if someone can make a patch that does that.
Yep, system-wide. I mean, I can’t exactly magnify the contents of the settings app, where there is a lot of not so unimportant text.
Yeah, not wrong. I am still working on the device port… Didn’t find anything about running SFOS in a VM for testing purposes, and most youtube videos don’t really do a whole settings tour (and, to be fair, that would be boring content xD).
oh! Good to know Will have to figure out how to do this properly since I use Ubuntu via WSL2 + Windows 10 for my main maschine - where adb and fastboot are installed via Windows - since WSL has no USB access - and the other tools are all contained in WSL. Hopefuly I can strip the VBox image out and use it that way to test. Thanks for the hint though!
I had a discussion with one potential SFOS user and they asked me, if Orca works on SFOS. Therefore, I got curious to know, how much effort it would take to add this accessibility feature. Is it something that could be done, given that some parts of SFOS are proprietary?
They are currently writing their own screenreader on Rust, so I guess they could be at least a bit of help, if somebody is interested to add support for Orca.
