Please, add an option to the very first boot, that will completely disable encryption of phone system.
I am big fan of Jolla, but I am totally uninterested in this kind of privacy on mobile phone. For me, this encryption layer is just another trouble-maker, and this really is in the case of C2.
Regarding banking and similar questions, nowadays always exist solutions that even if somebody have acces to the phone , he will not be able to use my account. If there are no viable safe solution for your particular service, then you simple do not install it on the phone. Problem solved.
After installing Sailfish enter recovery mode before first boot rename â/var/lib/sailfish-device-encryption/encrypt
-homeâ to disable encryption. Doesnât work on the C2 at the moment.
If i understood it right, this is not possible anymore. Like encryption is required by the system in newer versions. You could flash back to a version where encryption wasnât enabled. But this would mean that you couldnât have the latest SFOS release. Or tell me if i say something wrong, compose the system yourself from the sources available. But that needs deeper programming and IT skills
Understand. Not good preposition, somehow pushed by reading to much about C2 on this forum and being nervous with waiting
My C2 arrived today and it is working. During the setup, it happens three times that touchscreen was unresponsive, last time immediatelly after updating to 5.0.21, when I was unable to enter PIN - reboot solved.
I agree that in regular use the encryption layer is not a problem. What I can learn is that in beta version this would better to be disabled. Also entering PIN after restart is not needed for beta - oh, I cannot disable this in 5.0 as it was possible on XA2, maybe that phone is not encrypted? All this security are adding complexity and could be enabled later when basic functionality is succesfuly tested - at least for me, phone is a communication device needed for calls, messages, and browsing, and not a vault for secret data.
But for curiosity, it may be completly ireleveant, If every data readed and written must go through encryption layer, how much battery is consumed for this? Do encrypted data need more space? How much is processor loaded with the encryption and how much extra RAM is consumed? I remember, on this forum, sometimes users complains about short battery time and short resources.
I thought if you flash an old version without encryption, this dtate would be persistent through the updates. At least I had XA2 Ultra without encryption up to sfos 4.5 until the upgrade to 4.6 crashed my system and I had to do a reflash
It is also my impression that upgrading will not encrypt existing storage, but reflashing will. My Xperia X has been upgraded many times since encryption was introduced and now runs the latest (last! for this device) available version of SFOS. It is still unencrypted.
(Edit to clarify that last version applies to this specific device)
SFOS uses LUKS Encryption of User Data | Sailfish OS Documentation . This should be applied from the beginning, i.e. at first installation time. You may find further information on LUKS here: Home ¡ Wiki ¡ cryptsetup / cryptsetup ¡ GitLab
For me to not encrypt mobile devices by default seems to be outdated in 2024. Especially for the privacy-aware SFOS this feature request seems odd for me and I hope for most users also.
I am generally against encryption and would undo it on my phone in particular if I could. Why is this forced on the user if you have to reflash the OS?
Because users are unknowledgeable. There are hardly any downsides (for the devices owner) to it, only huge upsides.
Thatâs why every OS, especially on a mobile device, should by default use storage encryption (and something like TPM, so encryption key is not a 5 digit pincode). And âby defaultâ means: really hard to disable.
And my point is: people who want to disable encryption(and other forms of rudimentary security), because of âi want to have the choiceâ, do 99% of the time not know enough of this subject. Itâs not an educated decision. It like saying my car doesnât need good brakes, because i dislike brakes o n a car(they are not only there for you personally of course). And then itâs bad for those people, and worse, itâs bad for other people (like hackers/botnets impersonating other users by using their stolen accounts and data for criminal activities).
On all my devices the encryption never made any troubles and always worked in a way that I never was annoyed from it, not even saw that itâs there, it just did itâs work. But on a highly experimental device like C2 in this early stage of development itâs really bad if just this part in early stage of setup fails. On my working devices Iâm happy that encryption is there.
LOL: If anything goes wrong with the encryption, including forgetting the passphrase, all your data is (very safely) inaccessible forever, i.e. this is equivalent to âerasedâ.
Hence it is absolutely O.K., if the encryption of the /home volume can be disabled by some deliberate action, e.g. after installing SailfishX enter recovery mode and rename before first boot/var/lib/sailfish-device-encryption/encrypt-home.
P.S.: There seems to be a misconception here: LUKS encryption cannot be easily switched on or off to your liking. SailfishOS implements it by creating either an encrypted or unencrypted /home volume on the first boot (i.e. when running the setup wizard). Hence to switch /home volume encryption on or off later, one would have to perform a âfactory resetâ of SailfishOS (or reflash it) and run the setup wizard again, which does not seem to be possible with the Jolla C2 AFAIU.
Seriously Olf, you apparently have very important data on your phone, so important youâre not willing to risk 1/1000000 chance drive encryption fails BUT you are not worried that someone steals your device or you lose it in the train or whatever(chance 1/3)? You know that when that happens all that data is accessible without restrictions?
i dunno about SFOS 5.0 or the C2, but this script i wrote has worked for me all the way up to 4.6.0.15 on Xperia 10 III.
it modifies the sfos image before you flash it, and it works on official licensed images as well as community images. i use it to change defaultuser to nemo, disable encryption, and enable flashing of docomo-branded SO models. it is pretty simple, but i make no guarantees about its functionality or safety.
the script is only tested on debian gnu/linux, and maybe only works on debian. it is a perl wrapper around guestfish, img2simg, simg2img, and bbe.
I just wanted to put another vote for leaving the decision about encryption to the user. I never enabled it and hopefully will never have to use it with a future SFOS version.
This is nonsense. Noone wanted to roll-back encryption. There was only the wish to have the choice. Iâm a big fan of having a choice. I donât want others to decide for me. What speaks against an opt out solution?
By the way I had problems with encryption on two devices with SF. On both a reboot often had to be done more than once, because after I entered the PIN for decryption, the device showed a never ending spinning animation. So I had to shut down the device ungracefully and start it again. Sometimes it took up to 5 retries. This was on a Xperia X and a Xperia 10 II.
Even so I had this problems I would probably still choose to encrypt my home partition. Anyway I would prefer to have the choice.
