AAS browser not opening correctly from Open Link Menu
REPRODUCIBILITY: Always
OS VERSION: SFOS 5
HARDWARE: Xperia XA2 Plus Dual SIM
UI LANGUAGE: ENG
REGRESSION: YES
When opening an Android AppSupport browser (Opera in my case) using a browser link, the actual screen opens as a mini window. This only happens the first time the browser is started, once the browser is active in the background, the problem is gone. It was not an issue in the previous AAS version.
AAS for Android 13 installed with for example Opera installed
  1. Make sure no AAS browser is active (restart AAS for that matter)
  2. Open an SFOS app that has a clickable weblink, for example in the About page.
  3. Chose the AAS browser (Opera in my case)
  4. See a small active window
Window would be full-screen
Small window
Patchmanager
Not sure if it is only a 32-bits (Xperia-XA) issue (can’t test)
