I would like to have a visible symbol somewhere on the top of the screen when the call diversion is enabled similar to android.
I have to use call diversion quite often and sometimes I have simply forgotten to disable it because there is no indication whether it is enabled or not other than not receiving any calls. Also sometimes the disabling itself just fails after trying without giving any clear error messages (a bug?).
Related to the issue, I would like to have a possibility to make a quick link to a call diversion number and another one to disable it. This was already discussed earlier in another thread and it was possible to make a quick link to a “normal” phone number but not to the special ones with *- or #-symbols required in call diversion.
