A-GPS, EGNOS, quick and working position?
I also use GPSInfo. Wonderful little Program and it helps a lot getting a fast fix. Using GPS from time to time also helps a lot.
And I notice a serious decline in GPS accuracy when connected with 5G. Makes no sense to me but after all what makes sense to me?
@henris42 , Maybe you want to try this:
and report if this works on new devices. It works fine on good old Xperia 10.
I hope this aspect will be properly fixed in the new Jolla phone. Its been a pain.
Have you tried the AGPS ‘fix’ (it’s not really a fix but using google’s agps service (or graphenes)), doubtful jolla will officially start using google’s service, but hopefully community can plug in extra services (like apple’s wifi-based locatiom service that can pinpoint your location within seconds even inside buildings see:
Use BeaconDB as online positioning service - #68 by throwaway69)
Even if it cannot be officially supported, apple will not notice few k handsets pinging them every now and then vs 100mil they have pinging them all the time
Jolla has announced that they will introduce BeaconDB officially in 5.1
lets see again.. hope it will be good, and EGNOS data is used.
