I think you need to read up a bit on how forums work. This is not a chat.
Exact netiquette aspects (like one issue per topic) aside, just imagine for a second if everyone posted a me-me-me-thread - the forum would turn into crap rather quick.
thx for the respose dont think is a me me me thread, problems listed above are in a shipped new phone, my partner has sane three problems so i would guess other phones were shipped with same problems, so might be helpfull to ohers if listed in one thread
It is most definitely a me-me-me-thread in not being bothered to actually participate in the forum.
All three probably have on preexisting threads that you should use. (That’s not to say they are common problems - just others share your opinion and/or possible hardware defect).
Always search before posting - one topic per thread.
But you should make an effort to describe your problems better and maybe also search the forums for existing solutions.
I must say, your point 3. and the fact that your short post has many typos in it makes me think that maybe you need a phone with better accessibility options, which SFOS does not really have.
many typos cos cant get text big enough….. to be honest if the phone ships not working properly i dont think me me asking on help on the forum to get it working is me me me situation, and i wont be only person with these issues
So, lets help you a bit out there.
Go to the settings-app. Go to the second point (dont know, how its called in english, german its “Anzeige”). There you can make texts bigger and have a look for screen orientation.
Please consider, if a small-company-linux-phone is the right thing for you. SFOS is great and easy to use, but still there are moments you need some time to figure things out.
Again; it is the existence of the thread that is me-me-me, not the perceived issues as such.
If you properly describe the issues, one per thread (with a preference to pre-existing threads of the same topic) you will have a much better chance of getting somewhere.
Imagine someone coming along later, having only one of these issues and two others… should they add everything to this thread? Come on!
“Anzeige” is “Display” in English version. That is easy to find if starting the settings app from command line with a command:
LANG=en jolla-settings
That does not need the phone reboot, which is needed if the phone language is changed. By that way also screenshots can be made with English easily when using other language on phone (like me Finnish)
