Since upgrading to 5.2.0.22 Tidal (the music app installed via Auroa store) stopped working, it starts, but hangs in the loading stage, only showing the tidal logo.
I’ve reinstalled the app, cleared the cache, but it is still not working.
It was working fine before.
Tidal app version 2.218.0, this is SailfishOSX with Android App support.
Device: Sony Xperia 10 II - Dual SIM
Android-App Support: Android-Version 13
APT-Level 33
Security Patch 05.12.25
It used to work for me, I could log in and also listen to high res audio, before the last SailfishOS upgrade. Now it does not work anymore, I do not get to the the login screen.
Two users in this discussion reported that it still works for them.
the last error message is like the following and it start repeating each second in an endless loop
11-09 11:39:35.097 100 100 D surfaceflinger: APPSUPPORT: Show com.aspiro.tidal
11-09 11:39:35.101 100 100 D SurfaceFlinger: NEW BUFFER
11-09 11:39:35.131 100 100 D SurfaceFlinger: NEW BUFFER
11-09 11:39:35.136 232 406 E CellBroadcastUtils: getDefaultCellBroadcastReceiverPackageName: no package found
11-09 11:39:35.315 684 1278 E MediaProvider: Creating or writing to a non-default top level directory is not allowed!
11-09 11:39:35.328 684 1278 E MediaProvider: Creating or writing to a non-default top level directory is not allowed!
11-09 11:39:35.339 21 677 E cutils : Failed to mkdirat(/mnt/media_rw/8ff87de4-0b37-4799-b09a-82773e869e07/Android): Read-only file system
11-09 11:39:35.340 14620 14620 W ContextImpl: Failed to ensure /storage/8ff87de4-0b37-4799-b09a-82773e869e07/Android/data/com.aspiro.tidal/files: android.os.ServiceSpecificException: (code -30)
11-09 11:39:35.432 11 11 I hwservicemanager: Since android.hardware.drm@1.3::IDrmFactory/clearkey is not registered, trying to start it as a lazy HAL.
11-09 11:39:35.436 11 11 I hwservicemanager: Since android.hardware.drm@1.3::IDrmFactory/clearkey is not registered, trying to start it as a lazy HAL.
11-09 11:39:35.437 14620 14620 I HidlServiceManagement: getService: Trying again for android.hardware.drm@1.3::IDrmFactory/clearkey...
11-09 11:39:35.559 232 255 W ActivityTaskManager: Activity top resumed state loss timeout for ActivityRecord{deafe6a u0 com.aspiro.tidal/com.aspiro.wamp.LoginFragmentActivity} t5454}
11-09 11:39:36.438 14620 14620 W HidlServiceManagement: Waited one second for android.hardware.drm@1.3::IDrmFactory/clearkey
11-09 11:39:36.439 11 11 I hwservicemanager: Since android.hardware.drm@1.3::IDrmFactory/clearkey is not registered, trying to start it as a lazy HAL.
11-09 11:39:36.441 14620 14620 I HidlServiceManagement: getService: Trying again for android.hardware.drm@1.3::IDrmFactory/clearkey...
11-09 11:39:37.442 14620 14620 W HidlServiceManagement: Waited one second for android.hardware.drm@1.3::IDrmFactory/clearkey
So this looks like an Android Support defect, what would be the next step?
Is this the right category in the forum or should this go to category “Bug Reports”?
(The category description says that problems related to Android apps should be discussed in the “Application” category.)
cd /vendor/bin/hw
ls -l
ls -l *drm*
-rwxr-xr-x 1 root shell 11552 May 16 2024 android.hardware.drm@1.0-service
-rwxr-xr-x 1 root shell 152368 May 16 2024 android.hardware.drm@1.2-service.clearkey
So from the log above it tries to start 1.3, which is not there.
After I have seen it working, it does not work anymore (with the workaround in place). The log keeps saying the same thing as before: Rotating:
11-22 10:32:21.970 2208 2208 W HidlServiceManagement: Waited one second for android.hardware.drm@1.3::IDrmFactory/clearkey
11-22 10:32:21.971 11 11 I hwservicemanager: Since android.hardware.drm@1.3::IDrmFactory/clearkey is not registered, trying to start it as a lazy HAL.
11-22 10:32:21.973 2208 2208 I HidlServiceManagement: getService: Trying again for android.hardware.drm@1.3::IDrmFactory/clearkey...
