[5.0.0.71] Audio output goes through speaker instead of connected wired headphones
REPRODUCIBILITY: 75% (often)
OSVERSION: 5.0.0.71
HARDWARE: Sony Xperia 10 III - xqbt52 - xqbt52 - 1.0.1.47 - aarch64
UI LANGUAGE: English (US) (user: en_US, os: en_US.utf8)
REGRESSION: yes (since: other - aarch64)
After the update audio output switching from speakers to wired headphones doesn’t work properly. Sound still goes through speakers instead of headphones
Wired headphones are required
  1. Play any audio without connected headphones
  2. Connect headphones
  3. Try to play any sound via media/gpodder app
EXPECTED RESULTS:
Audio output switches to wired headphones after connecting them
ACTUAL RESULTS:
  • Patchmanager: yes
  • OpenRepos: yes
  • Chum: yes
  • Other: none specified
Workaround: Audio subsystem restart via settings utilities
the initial version of this bug report was created using Bugger 0.9.10+git7
How?
Thank you!
Did you tried to open Settings and search for Utilities?
Hey man.
Open Settings - Utilities. There you’ll find Audio section. Just tap Restart button and voila, audio subsystem is restarted. Hopefully, it will help
Allright! Thank you very much!
