REPRODUCIBILITY: 100%
OS VERSION: 5.0.0.55
HARDWARE: XA2 Dual sim
UI LANGUAGE: German
REGRESSION: Yes
In all previous versions my 2 SIM-Cards worked. With upgrade to Version 5 one Simcard is no longer working. It is a SimCard from Discotel (1&1 Germany). After starting the phone I am asked about the PIN for both SIM-Cards (behaviour is the same if I disable PIN request). I enter both PINS. SIM 2 gets registered correctly. SIM 1 stays disabled with warning “SIM 1 ist nicht eingerichtet” (SIM1 is not registered)
- Hitherto, I tried without any improvement:
- Restarting phone
- Changing SIM Cards manually - the discotel SIM stays unregistered
- I tried to follow instructions in a similar post: In version 4.3.0.12 and 4.3.0.15 my SIM-Card (Phonecard) works and also the SD-Card. As soon as I upgrade to Version 4.4.0.58 and also re-flash my SIM-Card no longer works.
- resetting ofono service: Resetting oFono Settings | Sailfish OS Documentation
- uninstalling patchmanager and reboot.
- check for uncomplete update of adaptation-common ([4.4.0.58] No SIM-Card (Phonecard) inserted - #9 by uwelabs). → ssu lr shows only versions 5.00.55
I can provide ofono logs it that helps.
