REPRODUCIBILITY: 100 %
OS VERSION: 5.0.0.43
HARDWARE: C2
UI LANGUAGE: German
REGRESSION: not sure
Restoring a backup takes very long if big files are part of the Backup. E.g. restoring a big Video takes very, very long.
System backup, in my case from a Xperia 10 III with SFOS 4.5.0.16 with a very big Video (3 GB) in the ~/Videos/
folder.
- Load Backup on SD-Card and insert SD in C2
- Start restoring the Backup from the UI
- You can observe the file being transferred very slow with e.g.
ls -l
Reasonable time to get it finished or some more indication about “something” is going on.
No progress indication in UI, and much more patience needed than 24h.
None
None
I also experienced this bug on my C2, but never on Xperia10ii.
I experienced that the unzipping of archives bigger than ~500MB is not possible with the embedded tools on my device (XA2 Ultra with SFOS 4.6, but also for earlier versions). Using an Android App does work for bigger files. Maybe this is related.
From my observation for the backup it works with files >500 MB, just sooooo slow. And also they seem not to be really “compressed” in the backup .tar file.
@sausset observed (and i think I can observe the same) that it is a little faster, when there is e.g. the Browser running while restoring the backup (you can keep it active with playing a video or audio stream), as the cores 6 and 7 of the CPU are active then, but it still is super slow.
from sony x10 , the restore haven’t completed : music, documents, and notes
but for honesty i have done the restore without installed app : note, multimedia, documents.
i have installed there after. any way files of music and document i hoped that been restored
enrico
Was there some kind of error message? Or did it just “not proceed” for ages?
no message, the process is had need many hours for complete; i have leave working the phone for all night ; at the morning, i had imported photos, video, address book and account (jolla, mail, owndrive) , this not connected; for jolla account i was need reinsert the password , the other haven’t try to reinsert the passwords, i have deleted those .
Others files nothing.
Enrico
There is no compression, the backup is just a tar file. However, it wouldn’t help too much, given the fact, that most of the data consists of incompressible data like pictures, audio, videos or already compressed formats like pdf. I just tried it out, zstd (the modern solution to compress at reasonable speed) compresses my backup to 97.2% of its original size.
