[4.6.0.13] Threema freezes on XA2
REPRODUCIBILITY: >90%
OS VERSION: 4.6.0.13
HARDWARE: Xperia XA2
UI LANGUAGE: English
REGRESSION:
Threema freezes after 1st click (on a contact or submenu). When clicking on a contact, the keyboard is not shown. Usually it is possible to respond to a contact through the notification.
Sailfish 4.6.0.13, Android App Support, Threema Libre
  1. Open Threema
  2. Select any contact/group/submenu
  3. Try to reply to the contact or select any option
The app should respond to selection
Freezing of the app, can only be closed.
None
Try some patience. You might have accidentally double clicked.
Press the Android back button once (!) and the freeze might be gone.
The same behaviour can be found in Signal as well.
Xperia 10 III 4.6.0.13
I only know this behavior from threema. I wonder if there is a invisible window or something blocking interaction
Thanks! That’s a good workaround. Hopefully they will fix it soon…
On my device I can confirm the problem.
Threema Libre: 5.3.2l (959)
SailfishOS: 4.6.0.13
HARDWARE: Xperia X10 II
UI LANGUAGE: German
with the upgrade of sailfishos the frequency of freezes is very high to almost make the app unusable. Using the “android back button” unfreezes.
