REPRODUCIBILITY: Always/ Permanent
OS VERSION: 4.5.0.25
HARDWARE: Xperia 10 III
UI LANGUAGE: German
REGRESSION: Yes, New
I do not get anymore mobile connection (4G) on my phone. A week ago I got a new sim card by my provider, which shall enable 5G. This worked now for a week, however since two days, my provider “finished activating 5g” (that is what they told me on the phone).
Now, I can no more connect to 2G/3G/4G. I have VoLTE not enabled.
What I have tried:
- I checked the APN settings
- Restarted ofono (many times)
- I checked several topics in this forum, but non seems to be similar to mine. In the journalctrl for ofono, I see some strange errors:
Facility lock query error: INVALID_ARGUMENTS
Requested file structure differs from SIM: 6fb7
Unexpected data call status 55
I have noticed, that when I restart ofono, the net strength symbol shows up, showing maximum possible value, then for 0.5s it shows “4G” right next to that. Then “4G” disappears and the strength symbol shows no access (0/5). It then takes a while (about 5s), then only the net strength symbol returns to full strength, however “4G” is no more showing up.
Try to switch on mobile data
There are not steps to reproduce. The issue happens permanently.
Mobile data connection works
The phone does only shows the strength of the cellular network, but it does not show “2G/3G/4G” beside that
No additional patches or custom changes
I have attached:
- Ofono logs
- journalctrl -u ofono
here: https://www.filemail.com/d/ujblcajdavjkvdc
One thing that I noticed:
In the logs, I can see:
inder_network_poll_operator_ok() slot1 lalpha=Willkommen, salpha=Willkommen, numeric=26202, Willkommen, mcc=262, mnc=02, gsm
However, from my provider, I got:
MCC: 262
MNC: 23
Maybe I simply need to change that? Where do I do that?
