REPRODUCIBILITY: 100%
OS VERSION: 4.5.0.24
HARDWARE: XA2
UI LANGUAGE: Polish
REGRESSION: ?
AppSupport does not start, the logs mention aptoide is being installed but it crashes. Restarting does not help, restarting the phone does not help.
Just being me.
- Start AppSupport in any way
AppSupport starts and stays on.
AppSupport starts and only stays on for like 2 seconds, then crashes (unable to start). Apparently not enough for any app to show up.
I have Chum GUI installed and I admit I played a bit with the AppSupport, but looking at the logs I am quite sure I did not break anything myself.
These suspicious logs consistently appear in logcat:
01-09 08:42:02.691 160 312 I AlienService: Installing /data/aas-staging/app/incoming/cm.aptoide.pt.apk
01-09 08:42:02.693 160 604 D AlarmManagerService: Kernel timezone updated to -60 minutes west of GMT
01-09 08:42:02.694 160 604 D AlienAudioControlService: set AlienAudioControlListener
01-09 08:42:03.139 682 682 D NetworkSecurityConfig: No Network Security Config specified, using platform default
01-09 08:42:03.145 682 682 D ExternalStorage: After updating volumes, found 0 active roots
01-09 08:42:03.175 160 312 E AlienService: IOException on package transfer
01-09 08:42:03.175 160 312 E AlienService: java.io.IOException: Failed to allocate 20714491 because only 0 allocatable
01-09 08:42:03.175 160 312 E AlienService: at com.android.server.StorageManagerService.allocateBytes(StorageManagerService.java:3899)
01-09 08:42:03.175 160 312 E AlienService: at android.os.storage.StorageManager.allocateBytes(StorageManager.java:2278)
01-09 08:42:03.175 160 312 E AlienService: at android.os.storage.StorageManager.allocateBytes(StorageManager.java:2335)
01-09 08:42:03.175 160 312 E AlienService: at com.android.server.pm.PackageInstallerSession.doWriteInternal(PackageInstallerSession.java:988)
01-09 08:42:03.175 160 312 E AlienService: at com.android.server.pm.PackageInstallerSession.openWrite(PackageInstallerSession.java:930)
01-09 08:42:03.175 160 312 E AlienService: at android.content.pm.PackageInstaller$Session.openWrite(PackageInstaller.java:1025)
01-09 08:42:03.175 160 312 E AlienService: at com.android.server.AlienService.alien_handle_installPackage(AlienService.java:315)
01-09 08:42:03.175 160 312 E AlienService: at com.android.server.AlienService.access$000(AlienService.java:76)
01-09 08:42:03.175 160 312 E AlienService: at com.android.server.AlienService$AlienServiceHandler.handleMessage(AlienService.java:116)
01-09 08:42:03.175 160 312 E AlienService: at android.os.Handler.dispatchMessage(Handler.java:106)
01-09 08:42:03.175 160 312 E AlienService: at android.os.Looper.loop(Looper.java:223)
01-09 08:42:03.175 160 312 E AlienService: at android.os.HandlerThread.run(HandlerThread.java:67)
01-09 08:42:03.175 160 312 E AlienService: at com.android.server.ServiceThread.run(ServiceThread.java:44)
--------- beginning of crash
01-09 08:42:03.177 160 312 E AndroidRuntime: *** FATAL EXCEPTION IN SYSTEM PROCESS: AlienService
01-09 08:42:03.177 160 312 E AndroidRuntime: java.lang.SecurityException: Files still open
01-09 08:42:03.177 160 312 E AndroidRuntime: at com.android.server.pm.PackageInstallerSession.assertNoWriteFileTransfersOpenLocked(PackageInstallerSession.java:1112)
01-09 08:42:03.177 160 312 E AndroidRuntime: at com.android.server.pm.PackageInstallerSession.commit(PackageInstallerSession.java:1125)
01-09 08:42:03.177 160 312 E AndroidRuntime: at android.content.pm.PackageInstaller$Session.commit(PackageInstaller.java:1243)
01-09 08:42:03.177 160 312 E AndroidRuntime: at com.android.server.AlienService.alien_handle_installPackage(AlienService.java:335)
01-09 08:42:03.177 160 312 E AndroidRuntime: at com.android.server.AlienService.access$000(AlienService.java:76)
01-09 08:42:03.177 160 312 E AndroidRuntime: at com.android.server.AlienService$AlienServiceHandler.handleMessage(AlienService.java:116)
01-09 08:42:03.177 160 312 E AndroidRuntime: at android.os.Handler.dispatchMessage(Handler.java:106)
01-09 08:42:03.177 160 312 E AndroidRuntime: at android.os.Looper.loop(Looper.java:223)
Why does it try to install aptoide? Can I prevent it? The file in question has a very very recent mtime, but there is an exact copy nearby, with a 2021 mtime.
If all else fails I will surely try reflashing, but I would love to avoid that.
