REPRODUCIBILITY: 100%
OS VERSION: 4.5.0.19
HARDWARE: Sony Xperia XA2
UI LANGUAGE: pl_PL
REGRESSION: yes
The Android AppSupport does not start, neither manually through its Settings page, nor through launching individual apps, nor auto-start on reboot / cold boot. It says ‘Unable to start’.
It used to crash randomly quite a lot since the last Sailfish update (once every couple days), but restarting always helped, so I did not investigate. It suddenly stopped helping a few days ago. Logcat says something about the watchdog killing system_server because of hung PowerManagerService, and then init segfaulting during a reboot sequence (attached).
I think none? I installed quite a lot of apps, maybe this might be low disk space related.
- Launch AppSupport.
- Wait.
The AppSupport starts, Android apps work.
It fails to start after a couple minutes, Android apps are unusable.
none I guess (no openrepos, no storeman, no waydroid)
I use microG as a GMS replacement inside the Android container, but that has survived all updates and now crashed out of nowhere.
Full logcat: Logs of crashing Sailfish's Android AppSupport · GitHub
The watchdog bit:
05-17 00:54:04.731 136 159 W Watchdog: Failed to write to /proc/sysrq-trigger
05-17 00:54:04.731 136 159 W Watchdog: java.io.FileNotFoundException: /proc/sysrq-trigger: open failed: EROFS (Read-only file system)
05-17 00:54:04.731 136 159 W Watchdog: at libcore.io.IoBridge.open(IoBridge.java:492)
05-17 00:54:04.731 136 159 W Watchdog: at java.io.FileOutputStream.<init>(FileOutputStream.java:236)
05-17 00:54:04.731 136 159 W Watchdog: at java.io.FileOutputStream.<init>(FileOutputStream.java:125)
05-17 00:54:04.731 136 159 W Watchdog: at java.io.FileWriter.<init>(FileWriter.java:63)
05-17 00:54:04.731 136 159 W Watchdog: at com.android.server.Watchdog.doSysRq(Watchdog.java:724)
05-17 00:54:04.731 136 159 W Watchdog: at com.android.server.Watchdog.run(Watchdog.java:657)
05-17 00:54:04.731 136 159 W Watchdog: Caused by: android.system.ErrnoException: open failed: EROFS (Read-only file system)
05-17 00:54:04.731 136 159 W Watchdog: at libcore.io.Linux.open(Native Method)
05-17 00:54:04.731 136 159 W Watchdog: at libcore.io.ForwardingOs.open(ForwardingOs.java:166)
05-17 00:54:04.731 136 159 W Watchdog: at libcore.io.BlockGuardOs.open(BlockGuardOs.java:254)
05-17 00:54:04.731 136 159 W Watchdog: at libcore.io.IoBridge.open(IoBridge.java:478)
05-17 00:54:04.731 136 159 W Watchdog: ... 5 more
05-17 00:54:04.732 136 159 W Watchdog: Failed to write to /proc/sysrq-trigger
05-17 00:54:04.732 136 159 W Watchdog: java.io.FileNotFoundException: /proc/sysrq-trigger: open failed: EROFS (Read-only file system)
05-17 00:54:04.732 136 159 W Watchdog: at libcore.io.IoBridge.open(IoBridge.java:492)
05-17 00:54:04.732 136 159 W Watchdog: at java.io.FileOutputStream.<init>(FileOutputStream.java:236)
05-17 00:54:04.732 136 159 W Watchdog: at java.io.FileOutputStream.<init>(FileOutputStream.java:125)
05-17 00:54:04.732 136 159 W Watchdog: at java.io.FileWriter.<init>(FileWriter.java:63)
05-17 00:54:04.732 136 159 W Watchdog: at com.android.server.Watchdog.doSysRq(Watchdog.java:724)
05-17 00:54:04.732 136 159 W Watchdog: at com.android.server.Watchdog.run(Watchdog.java:658)
05-17 00:54:04.732 136 159 W Watchdog: Caused by: android.system.ErrnoException: open failed: EROFS (Read-only file system)
05-17 00:54:04.732 136 159 W Watchdog: at libcore.io.Linux.open(Native Method)
05-17 00:54:04.732 136 159 W Watchdog: at libcore.io.ForwardingOs.open(ForwardingOs.java:166)
05-17 00:54:04.732 136 159 W Watchdog: at libcore.io.BlockGuardOs.open(BlockGuardOs.java:254)
05-17 00:54:04.732 136 159 W Watchdog: at libcore.io.IoBridge.open(IoBridge.java:478)
05-17 00:54:04.732 136 159 W Watchdog: ... 5 more
05-17 00:54:04.741 136 159 W Watchdog: *** WATCHDOG KILLING SYSTEM PROCESS: Blocked in handler on main thread (main)
05-17 00:54:04.744 136 159 W Watchdog: main annotated stack trace:
05-17 00:54:04.744 136 159 W Watchdog: at com.android.server.power.PowerManagerService.nativeInit(Native Method)
05-17 00:54:04.745 136 159 W Watchdog: at com.android.server.power.PowerManagerService.access$500(PowerManagerService.java:144)
05-17 00:54:04.745 136 159 W Watchdog: at com.android.server.power.PowerManagerService$NativeWrapper.nativeInit(PowerManagerService.java:738)
05-17 00:54:04.745 136 159 W Watchdog: at com.android.server.power.PowerManagerService.<init>(PowerManagerService.java:1034)
05-17 00:54:04.745 136 159 W Watchdog: - locked <0x040f282c> (a java.lang.Object)
05-17 00:54:04.745 136 159 W Watchdog: at com.android.server.power.PowerManagerService.<init>(PowerManagerService.java:892)
05-17 00:54:04.745 136 159 W Watchdog: at java.lang.reflect.Constructor.newInstance0(Native Method)
05-17 00:54:04.746 136 159 W Watchdog: at java.lang.reflect.Constructor.newInstance(Constructor.java:343)
05-17 00:54:04.746 136 159 W Watchdog: at com.android.server.SystemServiceManager.startService(SystemServiceManager.java:150)
05-17 00:54:04.746 136 159 W Watchdog: at com.android.server.SystemServer.startBootstrapServices(SystemServer.java:817)
05-17 00:54:04.748 136 159 W Watchdog: at com.android.server.SystemServer.run(SystemServer.java:624)
05-17 00:54:04.749 136 159 W Watchdog: at com.android.server.SystemServer.main(SystemServer.java:438)
05-17 00:54:04.749 136 159 W Watchdog: at java.lang.reflect.Method.invoke(Native Method)
05-17 00:54:04.749 136 159 W Watchdog: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:599)
05-17 00:54:04.749 136 159 W Watchdog: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:925)
05-17 00:54:04.749 136 159 W Watchdog: *** GOODBYE!
Free disk:
[defaultuser@Arex2 ~]$ df -h / ~ /run/media/defaultuser/*
Filesystem Size Used Avail Use% Mounted on
/dev/sailfish/root 2,4G 1,9G 499M 80% /
/dev/mapper/luks-91fa3577-f58d-4444-8c72-1f99e1d578b6 18G 17G 464M 98% /home
/dev/mmcblk1p1 30G 30G 604M 99% /run/media/defaultuser/9016-4EF8
I consider reinstalling AppSupport, if it might help, however I hope I can somehow back up all the apps’ settings first (hopefully including banking apps, microG etc.) so that they can later be restored. Is there any ‘cache’ that might be worth cleaning, or something that might be removed/recreated without affecting the apps that might help?
