Hi,
After the update, my bloototh didn’t work so I reset it but it didn’t help then I turned it off for a minute and here the problems start.
Startup usually stops at the loading image, and when it somehow goes further, the system is not complete (I recorded a video) After that I can’t connect via cable.
On the turned off phone, using the usb cable and the volume up button, the blue light does not light up for me (keys work)
Can he still be saved?
