REPRODUCIBILITY: 100%
OS VERSION: 4.5.0.16 (Struven ketju)
HARDWARE: Sony Xperia 10 - Dual SIM (i4113)
UI LANGUAGE: en_GB
REGRESSION: yes
Trying to install a package which has Requires: libxslt.so.1 fails
none
zypper inorpkcon installa package with a dep on libxslt - wait for resolving
- observe dependency error
Also:
On a device with SFOS 4.4:
$ rpm -qPp libxslt-1.1.34+git1-1.7.2.jolla.aarch64.rpm
warning: libxslt-1.1.34+git1-1.7.2.jolla.aarch64.rpm: Header V3 RSA/SHA256 Signature, key ID 47394f23: NOKEY
libexslt.so.0()(64bit)
libxslt = 1.1.34+git1-1.7.2.jolla
libxslt(aarch-64) = 1.1.34+git1-1.7.2.jolla
libxslt.so.1()(64bit)
libxslt.so.1(LIBXML2_1.0.11)(64bit)
libxslt.so.1(LIBXML2_1.0.12)(64bit)
libxslt.so.1(LIBXML2_1.0.13)(64bit)
libxslt.so.1(LIBXML2_1.0.16)(64bit)
libxslt.so.1(LIBXML2_1.0.17)(64bit)
libxslt.so.1(LIBXML2_1.0.18)(64bit)
libxslt.so.1(LIBXML2_1.0.22)(64bit)
libxslt.so.1(LIBXML2_1.0.24)(64bit)
libxslt.so.1(LIBXML2_1.0.30)(64bit)
libxslt.so.1(LIBXML2_1.0.32)(64bit)
libxslt.so.1(LIBXML2_1.0.33)(64bit)
libxslt.so.1(LIBXML2_1.1.0)(64bit)
libxslt.so.1(LIBXML2_1.1.1)(64bit)
libxslt.so.1(LIBXML2_1.1.18)(64bit)
libxslt.so.1(LIBXML2_1.1.2)(64bit)
libxslt.so.1(LIBXML2_1.1.20)(64bit)
libxslt.so.1(LIBXML2_1.1.23)(64bit)
libxslt.so.1(LIBXML2_1.1.24)(64bit)
libxslt.so.1(LIBXML2_1.1.25)(64bit)
libxslt.so.1(LIBXML2_1.1.26)(64bit)
libxslt.so.1(LIBXML2_1.1.27)(64bit)
libxslt.so.1(LIBXML2_1.1.3)(64bit)
libxslt.so.1(LIBXML2_1.1.30)(64bit)
libxslt.so.1(LIBXML2_1.1.34)(64bit)
libxslt.so.1(LIBXML2_1.1.5)(64bit)
libxslt.so.1(LIBXML2_1.1.7)(64bit)
libxslt.so.1(LIBXML2_1.1.9)(64bit)
$ rpm -qPp libxslt-1.1.37+git1-1.7.2.jolla.armv7hl.rpm
warning: libxslt-1.1.37+git1-1.7.2.jolla.armv7hl.rpm: Header V3 RSA/SHA256 Signature, key ID 47394f23: NOKEY
libexslt.so.0.8.20
libxslt = 1.1.37+git1-1.7.2.jolla
libxslt(armv7hl-32) = 1.1.37+git1-1.7.2.jolla
libxslt.so.1.1.35
Library package should Provide: its libraries
Problem: nothing provides 'libxslt.so.1' needed by the to be installed ...
Lots, but it’s not really relevant.
Haven’t checked by possibly switching to cmake and a _build dir doesn’t create symlinks in the install phase.
https://github.com/sailfishos/libxslt/blame/master/rpm/libxslt.spec
