Hello, in the 2nd night of charging I discovered in the logs of battery buddy 2 times a surprising behavior:
charging started at 87% although it should not start before 20%
Does anyone else observe this, too?
Is it a problem between system settings and installed battery buddy 4.2.2-1. ?
Technical hints to my phone:
HARDWARE: Sony Xperia 10 III - xqbt52 - xqbt52 - 1.0.1.12 - aarch64
UI LANGUAGE: Deutsch (user: de_DE, os: de_DE.utf8)
Pictures:
This is “expected” behavior when you have both Battery Buddy and the Battery Ageing Protection setting on. They try to both do what they do. Jolla tries to keep the battery around 90%, whereas BB would wait until it sinks down to 20% to enable charging.
I suggest you either set Battery Buddy to stop at 89% (just below Jolla setting) or just disable the control in either one of them.
Thanks for your hints; I set Battery Buddy to 89%, because I’m interested in the detailed logs.
