REPRODUCIBILITY: 100%
OS VERSION: 4.5.0.16
HARDWARE: Xperia 10
UI LANGUAGE: PL
REGRESSION: Yes
After conv with @vlagged I came to conclusion that this could be patchmanager issue.
This may sound odd and crazy but somehow the SailfishBrowser “forgets” that it’s patched.
patchmanager installed
- reboot phone (so we sure everything is clear)
- go to patchmanager ui and apply my patch Browser toolbar always visible.
- Start up browser and go to the settings, check if you have “Behavior” section at the bottom, if not, reboot the phone.
- after reboot check again if you have the option,
- play with the browser until it crash
- once browser reload, go to settings, observe the “Behavior” section is gone even that browser.qml and SettingsPage.qml of the browser still contains the patch.
- go to terminal, kill
/usr/libexec/mapplauncherd/booster-browser --application=sailfish-browser - start up browser, go to settings, observe the “Behavior” section is back again
After browser reload the patch should still be there, the Behavior section shouldn’t be gone
Even that browser qml files still contain the patch, the Behavior section is gone.
Only this one patch
