REPRODUCIBILITY: 100%
OS VERSION: 4.5.0.16
HARDWARE: Xperia 10 II
UI LANGUAGE: Finnish
REGRESSION: Yes, 4.4 and earlier were much more smoother
After updating to 4.5.0.16 I noticed that Android applications had significantly poorer performance when for instance navigating, scrolling etc. inside the apps. I suspect that either the changes in LXC container stuff or Android AppSupport upgrade might be the reason for this performance regression. For instance, now the animations etc. work correctly in Android applications which might have something to do witht his as well.
No special preconditions, just the new version 4.5.0.16 and Android AppSupport itself.
- Open Android application e.g. Telegram
- Use the application e.g. scroll, click, or move in the app
- Notice the poor performance and slow fps in Android apps
I expected the performance to be better (according to release notes) or at least in par with the previous versions.
UI performance in Android applications is horrible and much poorer compared to previous versions e.g. 4.4.0.72, not great.
None
None, for now.
