[4.2.0.19] Launch Android Settings
The command ‘apkd-launcher com.android.settings’ doesn’t work on new version. Any ideas?
Thank you very much.
try apkd-launcher com.android.settings/com.android.settings.Settings
Worked great :smile:
Thank you very much :+1:
To make it easier, you can use Launcher icon for android settings, from patchmanager’s web catalogue.
Maybe easier to tap five times Settings → Android App Support → Android version 11 ?
Thank you. Works for me
