[4.0.1.45] Text input for android apps is buggy
REPRODUCIBILITY: 100%
BUILD ID: 4.0.1.45
HARDWARE: Sony XA2
UI LANGUAGE: German
REGRESSION: Unclear
Jumping within a text input field is impossible
Open a textfield in a android browser (like Firefox for Android). For example by opening the “reply” dialog in this forum :slight_smile:
  1. Type in a few words an start jumping to different text sections
  2. The cursor will alway mark the chosen text position
  3. Type in new words - they will appear in that place where you last wrote (not where you marked)
You should be able to jumo in diefferent text sections and carry on writing there!
The typed word appear in former place
Bad work around: You can close the SFOF keybord an restart it again every time this issue appears. Then it will work for short while before it comes up again.
Known issue, sadly… WhatsApp works fine, but e.g. Vivaldi suffers from this.
Tip: after typing a space you can relocate the cursor…
Thanks for the report. This is a known issue and currently being worked on.
I have noticed a lot of replies lately about internal bug tickets having being created. I would like to say thanks to @jiit for the level of communication!
In the meantime, I have a workaround: install a keyboard for Android from, say, F-Droid! I’m using Gboard with Aurora Store at the moment, and it works like a charm! (Plus I can finally use swiping to input text! I really wish Jolla would implement it officially, as onboard doesn’t work with Finnish nor XA2 Ultra…)
This issue is still the same with SFOS 4.4.0
As @jiit notes above, we have this issue logged on our internal bug tracker, so I’ve tagged it as tracked.
You can train okboard to “learn” Finnish, with a textfile with a list of words and a textfile (corpusfile) with some texts so it can learn which word will probably follow after which word. You find the instructions in the readme of the source code repository
Issue seems to remain on 4.6.
