On the advice of martyone posting here that the 3.4 emulator seems to not work (4.x seems TO work) with the latest, 3.4 SDK.
I’m working directly against a phone for the time being.
(Apologies for the late reply - I missed your post.)
Indeed, due to a bug in Sailfish SDK 3.4, the 3.4.0.24 emulator is nonfunctional. Emulators for other Sailfish OS versions work well.
Deployment to a 3.4.0.24 emulator fails with error:
ssh: Could not resolve hostname 10.220.220.a: Name or service not known
It can be worked around by manually fixing the configuration files under the Sailfish SDK installation directory like with this sed invocation:
sed -i 's/<index>a/<index>10/' ~/SailfishOS/vmshare/devices.xml \
~/SailfishOS/emulator/*/vmshare/devices.xml
(Assuming that the SDK installation directory is ~/SailfishOS.)
After that restart the emulator. Needs to be repeated whenever devices configuration changes.
Thanks! I’ve actually just been going directly to device since I have a second SFOS device now. It’s better in any case…
Just to confirm that it works with index 1.
