[3.4.0.22] phone calls with headset too loud
REPRODUCIBILITY (% or how often): always
BUILD ID = OS VERSION (Settings > About product): 3.4.0.22
HARDWARE (Jolla1, Tablet, XA2,…): Xperia 10
UI LANGUAGE: German
With my (cable) headphones (Sennheiser CX 300S) phone calls are generally way too loud since the OS update. The minimum sound level still hurts my ears.
Before the update the maximum volume was mostly not loud enough to understand properly in noisy environments. Now it’s the other way around. It seems the volume intervall just got shifted upwards instead of extending it. Maybe it is possible to correct that for the official release?
Similar issue discussed here: Request: Minimum volume a lot quieter
