REPRODUCIBILITY (% or how often):
BUILD ID = OS VERSION (Settings > About product):
HARDWARE (Jolla1, Tablet, XA2,…): XA2
UI LANGUAGE: Android
REGRESSION: (compared to previous public release: Yes, No, ?): Never
By saying “still not streaming” I assume it did not work also on 3.3.x. My SF-phone is still 3.3.0.16 and Element 1.0.8 is installed from F-Droid and video calling to other Element instance under Android works fine. As far as I understand, P2P video calling in Element is pure WebRTC.
However as both phones have degooglified Elements, then Firebase-based push notifications do not work and you have to keep in mind to let the calls to ring long enough for the notification at receiver’s phone to appear (if receiver’s Element is in focus, then notification is instantaneous). [Maybe I should have a look at setting up MicroG.]
Jitsi is working over the mobile network of vodafone and telekom. Only with Wifi (and maybe the telefonica network) the screen stays black - exactly as found in the thread on TJC. Apparantly this is tracked by Jolla
Upgraded to 4.0.1.48 from 3 and tried jitsi. Unfortunatelly even with upgraded web browser I get this browser is not supported, plase upgrade to the most recent version. Any ideas when our engine will get upgraded to more recent versions? I also think this engine should be of high priority when it comes to apps upgrade because of all kinds of features and bugs.
I guess that this may not work with the browser anyways because it is a mobile browser. I use the Android jitsi from F-droid - but with the known problem that it does not work in local WLANs
Threema is another app using WebRTC for calls that does not work on WLANs or any connections with VPN turned on. Since it affects all apps on Android layer that are using this technology and not a single app, hopefully Jolla will notice it and try to fix the problem.
I have the same behaviour on my XA2 (4.3.0.12) with Jitsi Client (20.2.3) and Threema (4.6.2). Video call is not working with Wifi connection, but with mobile data (even with VPN) it is working. I tried connect to a Jitsi conference via Firefox for Android (95.1.0). This worked with mobile data and surprisingly also with Wifi.
