2 SIMs breaks network connectivity for Android apps
REPRODUCIBILITY: 100%
OS VERSION: 5.0.0.67
HARDWARE: C2
UI LANGUAGE: English
REGRESSION: Cannot confirm or deny.
Android applications lose network connectivity when both SIM cards are enabled.
Connectivity is restored when one SIM is deactivated.
Use and enable two SIM cards (both active in Settings > SIM cards).
  1. Insert two SIM cards into the device.
  2. Enable both SIM cards under Settings > SIM cards.
  3. Launch any Android application that uses the internet (e.g., Aurora Strore, YouTube).
  4. Observe that the app cannot connect to the internet.
Android apps should be able to connect to the internet while both SIMs are enabled.
Android apps cannot connect to the internet when both SIMs are active. Disabling one SIM resolves the issue.
I noticed that WhatsApp is for some reason working and I can send messages.
I installed it from Aurora store.
No custom modifications, patches.
I’m happy to provide logs or other diagnostic data upon request. Please advise what would be useful.
I have both SIM Cards enabled on my C2 with 5.0.0.67 and I don’t have this problem…
Thx @joboe for info. Do you use some of the apps I mentioned above?
It behaves weirdly even more know. Maybe I tested it incorectly before but now network doesnt work in Android apps even when I remove 2nd sim. Looks like something is broken on my side :frowning: The network for Android app works wifi only. It is kinda wierd that whatsapp is working always …
I use Aurora Store, the ING banking app, fennec, signal, whatsapp, spotify, discogs - just to name few apps. From time to time (after switching from WiFi to mobile internet or vice versa) apps cannot connect to the internet, but restarting network services and/or app support helps in most cases. If not, a reboot solves the issue.
But in general it works and it works way better than on my old XA2.
