[Xperia 10 II] Unable to reach Recovery Mode
I will do that.
The 4.5.0.25 images for various devices are available here, so get working hybris-recovery files from there. In other words, devices running 4.6.0 should be able to access the recovery mode by using the 4.5.0 recovery images.
A doc update will not cut it. In fact the recovery images have so little functionality that they hardly deserve the name. But i might be wrong and some people find the limited features somewhat useful.
What aspect of what problem?
Dropping to a shell gives you basically limitless possibilities if you know how use it.
But this is not the problem discussed in this thread.
Thanks for your valuable answer. But if you use the search function of the forum it can already be found endless times.
People coming here likely have a serious problem, and the recovery image will very likely not help them. That is my opinion, accept it and drop your comments to echo > /dev/null
It is fixed in 4.6.0.15.
