I am not sure what manual changes you made yourselve, but /etc/resolv.conf should be a symlink to /var/run/connman/resolv.conf. And it should point to 127.0.0.1, the connman DNS proxy. Then Connman knows what DNS to use. This works for VPN and non VPN situations I can confirm.
Then I do not know where these nameservers come from.
You can try to use a temporary fix. After connecting via wireguard VPN use
echo 'nameserver 88.252.172.57' >>/run/connman/resolv.conf
or even 1.1.1.1 or whatever DNS public server.
echo 'nameserver 1.1.1.1' >>/run/connman/resolv.conf
Is that a permanent change?
Not sure if it is required or the opposite but as I wrote it is a temporary fix. /run/connman/resolv.conf is/should be overwritten every network change or connman restart.
And I found the solution:
AllowedIPs = 0.0.0.0/0, ::/0
works. All traffic is routed through Wireguard.
AllowedIPs = 192.168.23.0/24, 0.0.0.0/0, ::/0
only routes local traffic through Wireguard but the rest over the standard internet connection.
The checkbox to route all traffic through Wireguard must also be checked.
Tested, approved and added here : Installing WireGuard | SailfishOS community wiki
Thank you !
To complete the wiki on Wireguard I suggest adding how to prevent DNS leaks as a last step: Settings > VPN > Edit > Advanced > Enable Ipv6 data leak protection
Done
(twenty characters)
I just installed wg and it is working. I can ping and ssh from my phone to the other wireguard clients in the wg-subnet but I canāt ping or ssh from other clients into the phone. Is there some firewall settings I have to adapt? Developer-mode and ssh is of course enabled and I can ssh normally via other interfaces (wifi, cell or usb) to the phone.
Wireguard is based on nftables hence please check nftables rules.
Been routing all my data traffic through my home network for a week now without issues. Wireguard is quite impressive. Iām actually seeing a substantial speed increase. On my home network Iām running pihole. And the filtering removes so much crap from the web that it makes browsing over my wireguard tunnel much faster. Iām also seeing a lot fewer browser crasches.
Has anyone managed to set up a split tunnel on sfos to just route dns traffic through wireguard?
Whay do you want to do that? Just use dnscrypt-proxy.
For custom wireguard config you can use custom wg-quick script.
Tested with ProtonVPN free account but with a little fix.
When adding the configuration from a file all works ok except the DNS configuration. Itās necessary to edit the configuration, go to Advance and add the DNS manually. After that, works fine.
Xperia 10 III with SfOS 5.1.0.11
Tested with the wireguard server on my router (cudy WR3000s). Iāve generated a conf file on my router and exported it and imported it on my phone. After importation some settings are forgotten: DNS and the pre-shared key. Without the pre-shared key, SFOS claims the VPN is connected but my router says handshake fails. After having edited the vpn settings in phone and inserted the pre-shared key, it works.
Is there a command so I can have Wireguard connecting when I disconnect from my home wifi?
The triggering can be done through āsituationsā, I just need the commandline to enable/disable vpn, but I cannot find it/figure it out.
You need connmanctl:
pkcon install connman-tools
and then
connmanctl connect "service"
Thanks!
That works!
(Now only how to make āsituationsā act on disconnecting wifi instead of connecting.)
You can tap on āconnectingā icon rule in Situation then you get negative function.
thanks again
also fixed
