FWIF, I’ve been running 3.4 and now 4.0 EA and I can’t recall anything important getting broken since 3.1… I think the newer glibc was introduced in 3.3…
I suggest upgrading anyway (up to 3.4 that is), the older versions have (more) unpatched vulnerabilities. Backup your data, of course :slight_smile:
Yeh, we’re also using some functionality that’s only available starting in 3.3, so even if I wanted to compile against 3.1, it wouldn’t really be possible without backporting some stuff.
I have now pushed alpha.8 to OpenRepos, with very minimal changes (current master contains an important performance bug):
Fixes in alpha.8:
  • Many hours have been spent in implementing the reCAPTCHA functionality. It works, with a LOT of thanks to @gamag for figuring out what went wrong and for actually fixing it. Jolla is shipping an old version of sqlcipher, which interfered with qt5-mozembed, and we now ship our own sqlcipher for this. Registration should hereby be fixed, so please file an issue if it is not.
  • SailfishOS 4.0 stopped shipping the (non-public) BubbleBackground, and replaced it with a ColorBackground. We now ship our own ColorRect, thanks to @ichthyosaurus . Viewing messages on 4.0.1.45EA should be fixed.
Notable bug: reCAPTCHA rendering on SailfishOS 4.0.1.45EA currently does not work. We think this is a regression in mozembed, and filed a bug with Jolla. We hope this is resolved before SailfishOS 4.0 hits the masses.
Another pair of issues just came to light:
  • Newly registered Android/iOS accounts might not be reachable from Whisperfish. This will be addressed when we finally migrate to UUID sessions.
  • Contact names may not show up and will not update. This is the same regression that @Ygriega noticed. #231
Many hours have been sunk into getting the reCAPTCHA rendered. Your patience is now finally awarded :slight_smile: The Whisperfish beta is getting in good shape, and there are many treats coming your way in a few weeks™! :partying_face:
PS: for about two hours, there has been a “new alpha.7 aarch64” on OpenRepos. This was a mistagged alpha.8, and has now been removed. No damage should’ve been done.
Just updated to alpha.8 a few hours ago, and basic messaging at least is working fine with SFOS 4.0 EA. Thank you so much!
Actually, I completed the Finnish translation yesterday evening, but it’s not included in alpha.8. I guess it gets pulled when it gets pulled :slight_smile:
It’ll be in in beta.1, and it’s in current master (or soon to be)! I’ve backported the two changes that I listed to an older state, because of some bugs in current master that would make Whisperfish unusable to some. Thanks for the :finland: translation :slight_smile:
Since 3.1 is quite old I am not that surprised that nobody tested it. And supporting old systems limits the potential for improvement (at least in my experience).
And I now know that I will have to update my system somehow …
Thanks for the answer.
I had a look an it seems there is no one who is developing the OnePlus X community port of SFOS anymore and 3.1.0.12 is the last available version :(. I will check next weekend when there is hopefully some time and will be back, once I can install the current whisperfish.
For now thank you all for the help
That is unfortunate :slightly_frowning_face: OnePlus X is a fine device, for what I can recall!
Let’s hope SFOS 4.0 gets the wheels turning again!
FWIW, the only thing that really requires SailfishOS 3.3+ is the contact name lookup. I will have to rewrite that for 4.0 anyway, so I may as well keep in mind that we could support slightly older versions, and make you an older build. No promises though, and no timeline for this unfortunately.
The alpha.8 version is still working, but I think I found a bug: my friend replied to a message of mine, and I got a message that looked something like this:
R@5623867283678: Yeah buy eggs and milk.
We figured out that it was a reply to an earlier message of mine. I guess the R@5623867283678 part is a reference to the earlier message.
I couldn’t find an existing issue about this that at a glance. Is this known or did I discover a bug? :slight_smile:
It’s an indication that your friend added a ‘reaction’ to your message (i.e. an emoticon, like a heart or a thumbs-up), but reactions aren’t implemented in the UI yet.
To elaborate on @nthn: it’s indeed a feature, not a bug. Previous versions silently dropped any reaction to a message. Our database, back-end and UI currently do not support reactions, but we’re actively working on having this supported. When it is implemented, we will run a migration that looks in the DB for these messages, and actually put them as the correct reactions.
Hello @rubdos!
I have a problem sending a message to one friend with a new phone.
Here is the censored log (XXXXXXXXXXX…his number, YYYYY…my number, some other numbers CENSORED) by RUST_LOG=trace harbour-whisperfish:
[2021-02-10T22:40:14Z TRACE harbour_whisperfish::actor::messageactor] MessageActor::handle(QueueMessage { source: "+43XXXXXXXXXXX", message: "TEST", attachment: "", group: "" })
[2021-02-10T22:40:14Z TRACE harbour_whisperfish::store] Called fetch_session_by_source(+43XXXXXXXXXXX)
[2021-02-10T22:40:14Z TRACE harbour_whisperfish::store] Called update_session()
[2021-02-10T22:40:14Z TRACE harbour_whisperfish::store] Called update_message_if_needed(3)
[2021-02-10T22:40:14Z TRACE harbour_whisperfish::store] Called create_message()
[2021-02-10T22:40:14Z TRACE harbour_whisperfish::store] Called fetch_latest_message()
[2021-02-10T22:40:14Z TRACE harbour_whisperfish::store] Inserted message id 1052
[2021-02-10T22:40:14Z INFO  harbour_whisperfish::worker::client] ClientActor::SendMessage(1052)
[2021-02-10T22:40:14Z TRACE harbour_whisperfish::store] Called fetch_message(1052)
[2021-02-10T22:40:14Z TRACE harbour_whisperfish::store] SELECT `message`.`id`, `message`.`session_id`, `message`.`source`, `message`.`message`, `message`.`timestamp`, `message`.`sent`, `message`.`received`, `message`.`flags`, `message`.`attachment`, `message`.`mime_type`, `message`.`has_attachment`, `message`.`outgoing`, CASE WHEN sentq.message_id > 0 THEN 1 ELSE 0 END AS queued FROM (`message` LEFT OUTER JOIN `sentq` ON `sentq`.`message_id` = `message`.`id`) WHERE `message`.`id` = ? -- binds: [1052]
[2021-02-10T22:40:14Z TRACE harbour_whisperfish::store] Called fetch_session(3)
[2021-02-10T22:40:14Z TRACE harbour_whisperfish::worker::client] Sending for session: Session { id: 3, source: "XXXXXXXXXXX", message: "TEST", timestamp: 1612996814443, sent: false, received: false, unread: false, is_group: false, group_members: None, group_id: None, group_name: None, has_attachment: false }
[2021-02-10T22:40:14Z TRACE harbour_whisperfish::worker::client] Sending message: Message { id: 1052, sid: 3, source: "+43XXXXXXXXXXX", message: "TEST", timestamp: 1612996814443, sent: false, received: false, flags: 0, attachment: None, mimetype: None, hasattachment: false, outgoing: true, queued: true }
[2021-02-10T22:40:14Z TRACE harbour_whisperfish::worker::client] Transmitting DataMessage { body: Some("TEST"), attachments: [], group: None, group_v2: None, flags: None, expire_timer: None, profile_key: None, timestamp: Some(1612996814443), quote: None, contact: [], preview: [], sticker: None, required_protocol_version: Some(0), is_view_once: None, reaction: None, delete: None, body_ranges: [] }
[2021-02-10T22:40:14Z TRACE libsignal_service::sender] encrypting message for Address { name: "+43XXXXXXXXXXX", device_id: 1 }
[2021-02-10T22:40:14Z TRACE harbour_whisperfish::store::protocol_store] contains_session(+43XXXXXXXXXXX)
[2021-02-10T22:40:14Z INFO  libsignal_service::sender] establishing new session with Address { name: "+43XXXXXXXXXXX", device_id: 1 }
[2021-02-10T22:40:14Z DEBUG libsignal_service_actix::push_service] AwcPushService::get(Url { scheme: "https", host: Some(Domain("textsecure-service.whispersystems.org")), port: None, path: "/v2/keys/+43XXXXXXXXXXX/*", query: None, fragment: None })
[2021-02-10T22:40:14Z TRACE actix_connect::resolve] DNS resolver: resolving host "textsecure-service.whispersystems.org"
[2021-02-10T22:40:14Z DEBUG trust_dns_proto::xfer::dns_handle] querying: textsecure-service.whispersystems.org A
[2021-02-10T22:40:14Z DEBUG trust_dns_resolver::name_server::name_server_pool] sending request: [Query { name: Name { is_fqdn: false, labels: [textsecure-service, whispersystems, org] }, query_type: A, query_class: IN }]
[2021-02-10T22:40:14Z DEBUG trust_dns_resolver::name_server::name_server] existing connection: NameServerConfig { socket_addr: [::1]:53, protocol: Udp, tls_dns_name: None }
[2021-02-10T22:40:14Z DEBUG trust_dns_proto::xfer] enqueueing message: [Query { name: Name { is_fqdn: false, labels: [textsecure-service, whispersystems, org] }, query_type: A, query_class: IN }]
[2021-02-10T22:40:14Z TRACE trust_dns_resolver::name_server::connection_provider] polling response inner
[2021-02-10T22:40:14Z DEBUG trust_dns_resolver::name_server::name_server] existing connection: NameServerConfig { socket_addr: 127.0.0.1:53, protocol: Udp, tls_dns_name: None }
[2021-02-10T22:40:14Z DEBUG rustls::session] Sending warning alert CloseNotify
[2021-02-10T22:40:14Z TRACE mio::poll] deregistering handle with poller
[2021-02-10T22:40:14Z TRACE mio::poll] registering with poller
[2021-02-10T22:40:14Z DEBUG trust_dns_proto::udp::udp_stream] created socket successfully
[2021-02-10T22:40:14Z DEBUG trust_dns_proto::rr::record_data] reading A
[2021-02-10T22:40:14Z DEBUG trust_dns_proto::udp::udp_client_stream] received message id: 47428
[2021-02-10T22:40:14Z DEBUG trust_dns_resolver::name_server::name_server_pool] mDNS responsed for query: NoError
[2021-02-10T22:40:14Z TRACE actix_connect::resolve] DNS resolver: host "textsecure-service.whispersystems.org" resolved to [13.248.212.111:443, 76.223.92.165:443]
[2021-02-10T22:40:14Z TRACE actix_connect::connector] TCP connector - connecting to "textsecure-service.whispersystems.org" port:443
[2021-02-10T22:40:14Z TRACE actix_connect::connector] TCP connector - successfully connected to connecting to "textsecure-service.whispersystems.org" - Ok(13.248.212.111:443)
[2021-02-10T22:40:14Z TRACE actix_connect::ssl::rustls] SSL Handshake start for: "textsecure-service.whispersystems.org"
[2021-02-10T22:40:14Z DEBUG rustls::client::hs] Resuming session
[2021-02-10T22:40:14Z TRACE rustls::client::hs] Sending ClientHello Message {
        typ: Handshake,
        version: TLSv1_0,
        payload: Handshake(
            HandshakeMessagePayload {
                typ: ClientHello,
                payload: ClientHello(
                    ClientHelloPayload {
                        client_version: TLSv1_2,
                        random: Random(
                                43,
                                204,
                                19,
                                118,
                                76,
                                131,
                                48,
                                182,
                                146,
                                59,
                                170,
                                68,
                                229,
                                145,
                                43,
                                133,
                                6,
                                185,
                                30,
                                194,
                                77,
                                77,
                                214,
                                136,
                                172,
                                91,
                                67,
                                207,
                                111,
                                140,
                                116,
                                55,
                        session_id: SessionID(
                            142,
                            188,
                            56,
                            19,
                            62,
                            101,
                            227,
                            173,
                            44,
                            22,
                            241,
                            200,
                            215,
                            9,
                            172,
                            26,
                            41,
                            169,
                            6,
                            0,
                            197,
                            211,
                            173,
                            209,
                            172,
                            238,
                            29,
                            206,
                            225,
                            14,
                            174,
                            27,
                        cipher_suites: [
                            TLS13_CHACHA20_POLY1305_SHA256,
                            TLS13_AES_256_GCM_SHA384,
                            TLS13_AES_128_GCM_SHA256,
                            TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256,
                            TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256,
                            TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384,
                            TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256,
                            TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384,
                            TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256,
                            TLS_EMPTY_RENEGOTIATION_INFO_SCSV,
                        compression_methods: [
                            Null,
                        extensions: [
                            SupportedVersions(
                                    TLSv1_3,
                                    TLSv1_2,
                            ServerName(
                                    ServerName {
                                        typ: HostName,
                                        payload: HostName(
                                            DNSName(
                                                "textsecure-service.whispersystems.org",
                            ECPointFormats(
                                    Uncompressed,
                            NamedGroups(
                                    X25519,
                                    secp384r1,
                                    secp256r1,
                            SignatureAlgorithms(
                                    ECDSA_NISTP384_SHA384,
                                    ECDSA_NISTP256_SHA256,
                                    ED25519,
                                    RSA_PSS_SHA512,
                                    RSA_PSS_SHA384,
                                    RSA_PSS_SHA256,
                                    RSA_PKCS1_SHA512,
                                    RSA_PKCS1_SHA384,
                                    RSA_PKCS1_SHA256,
                            ExtendedMasterSecretRequest,
                            CertificateStatusRequest(
                                OCSP(
                                    OCSPCertificateStatusRequest {
                                        responder_ids: [],
                                        extensions: PayloadU16(
                            KeyShare(
                                    KeyShareEntry {
                                        group: X25519,
                                        payload: PayloadU16(
                                                34,
                                                52,
                                                25,
                                                168,
                                                24,
                                                72,
                                                102,
                                                148,
                                                240,
                                                171,
                                                254,
                                                157,
                                                246,
                                                187,
                                                93,
                                                204,
                                                124,
                                                168,
                                                239,
                                                36,
                                                6,
                                                38,
                                                77,
                                                116,
                                                128,
                                                7,
                                                246,
                                                143,
                                                150,
                                                235,
                                                88,
                                                13,
                            PresharedKeyModes(
                                    PSK_DHE_KE,
                            Protocols(
                                    PayloadU8(
                                            104,
                                            116,
                                            116,
                                            112,
                                            47,
                                            49,
                                            46,
                                            49,
                            SessionTicketOffer(
                                Payload(
                                        245,
                                        224,
                                        150,
                                        179,
                                        23,
                                        175,
                                        246,
                                        189,
                                        116,
                                        59,
                                        151,
                                        187,
                                        160,
                                        131,
                                        119,
                                        39,
                                        56,
                                        217,
                                        79,
                                        188,
                                        78,
                                        16,
                                        153,
                                        16,
                                        172,
                                        205,
                                        69,
                                        188,
                                        103,
                                        36,
                                        122,
                                        185,
                                        72,
                                        228,
                                        29,
                                        16,
                                        115,
                                        67,
                                        96,
                                        138,
                                        78,
                                        103,
                                        4,
                                        165,
                                        218,
                                        91,
                                        187,
                                        212,
                                        0,
                                        243,
                                        195,
                                        176,
                                        46,
                                        61,
                                        8,
                                        86,
                                        133,
                                        82,
                                        48,
                                        114,
                                        143,
                                        186,
                                        166,
                                        246,
                                        236,
                                        174,
                                        95,
                                        70,
                                        162,
                                        60,
                                        36,
                                        11,
                                        37,
                                        255,
                                        71,
                                        181,
                                        13,
                                        93,
                                        152,
                                        138,
                                        185,
                                        177,
                                        23,
                                        1,
                                        65,
                                        2,
                                        161,
                                        109,
                                        61,
                                        39,
                                        89,
                                        245,
                                        102,
                                        4,
                                        160,
                                        35,
                                        188,
                                        24,
                                        142,
                                        1,
                                        61,
                                        55,
                                        170,
                                        129,
                                        103,
                                        83,
                                        158,
                                        115,
                                        228,
                                        149,
                                        66,
                                        193,
                                        82,
                                        104,
                                        123,
                                        211,
                                        3,
                                        33,
                                        231,
                                        90,
                                        5,
                                        11,
                                        6,
                                        132,
                                        123,
                                        73,
                                        152,
                                        248,
                                        85,
                                        250,
                                        21,
                                        161,
                                        251,
                                        114,
                                        95,
                                        242,
                                        139,
                                        41,
                                        190,
                                        62,
                                        198,
                                        237,
                                        125,
                                        131,
                                        48,
                                        34,
                                        23,
                                        111,
                                        2,
                                        65,
                                        42,
                                        25,
                                        45,
                                        59,
                                        167,
                                        230,
                                        113,
                                        132,
                                        88,
                                        16,
                                        59,
                                        82,
                                        62,
                                        34,
                                        113,
                                        76,
                                        231,
                                        244,
                                        108,
                                        184,
                                        253,
                                        219,
                                        53,
                                        111,
                                        37,
                                        102,
                                        43,
                                        167,
                                        16,
                                        231,
                                        45,
                                        123,
                                        132,
                                        86,
                                        7,
                                        191,
                                        209,
                                        234,
                                        18,
                                        238,
                                        229,
                                        57,
                                        247,
                                        36,
                                        194,
                                        202,
                                        206,
                                        42,
                                        59,
                                        180,
                                        148,
                                        96,
                                        97,
                                        177,
                                        69,
                                        25,
                                        118,
                                        85,
                                        23,
                                        82,
                                        132,
                                        242,
                                        75,
                                        166,
                                        28,
                                        133,
                                        174,
                                        184,
                                        18,
                                        87,
                                        242,
                                        217,
                                        230,
                                        231,
[2021-02-10T22:40:14Z TRACE rustls::client::hs] We got ServerHello ServerHelloPayload {
        legacy_version: TLSv1_2,
        random: Random(
                204,
                138,
                209,
                119,
                137,
                146,
                129,
                237,
                166,
                121,
                6,
                219,
                224,
                81,
                100,
                24,
                97,
                214,
                208,
                76,
                10,
                202,
                142,
                78,
                46,
                204,
                113,
                130,
                7,
                226,
                37,
                1,
        session_id: SessionID,
        cipher_suite: TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256,
        compression_method: Null,
        extensions: [
            RenegotiationInfo(
                PayloadU8(
            ECPointFormats(
                    Uncompressed,
                    ANSIX962CompressedPrime,
                    ANSIX962CompressedChar2,
            SessionTicketAck,
            Protocols(
                    PayloadU8(
                            104,
                            116,
                            116,
                            112,
                            47,
                            49,
                            46,
                            49,
[2021-02-10T22:40:14Z DEBUG rustls::client::hs] ALPN protocol is Some([104, 116, 116, 112, 47, 49, 46, 49])
[2021-02-10T22:40:14Z DEBUG rustls::client::hs] Using ciphersuite TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
[2021-02-10T22:40:14Z DEBUG rustls::client::hs] Server supports tickets
[2021-02-10T22:40:14Z DEBUG rustls::client::tls12] ECDHE curve is ECParameters { curve_type: NamedCurve, named_group: secp256r1 }
[2021-02-10T22:40:14Z TRACE rustls::client::tls12] Server cert is [Certificate(b"0\x82\x03\xe30\x82\x02\xcb\xa0\x03\x02\x01\x02\x02\x02\x10\x180\r\x06\t*\x86H\x86\xf7\r\x01\x01\x0b\x05\00\x81\x8d1\x0b0\t\x06\x03U\x04\x06\x13\x02US1\x130\x11\x06\x03U\x04\x08\x0c\nCalifornia1\x160\x14\x06\x03U\x04\x07\x0c\rSan Francisco1\x1d0\x1b\x06\x03U\x04\n\x0c\x14Open Whisper Systems1\x1d0\x1b\x06\x03U\x04\x0b\x0c\x14Open Whisper Systems1\x130\x11\x06\x03U\x04\x03\x0c\nTextSecure0\x1e\x17\r190215173817Z\x17\r290312182020Z0\x81\x901\x0b0\t\x06\x03U\x04\x06\x13\x02US1\x130\x11\x06\x03U\x04\x08\x0c\nCalifornia1\x1d0\x1b\x06\x03U\x04\n\x0c\x14Open Whisper Systems1\x1d0\x1b\x06\x03U\x04\x0b\x0c\x14Open Whisper Systems1.0,\x06\x03U\x04\x03\x0c%textsecure-service.whispersystems.org0\x82\x01\"0\r\x06\t*\x86H\x86\xf7\r\x01\x01\x01\x05\0\x03\x82\x01\x0f\00\x82\x01\n\x02\x82\x01\x01\0\xac\xc8\x11\xb5\xd1E\xb7\xc0\xa2\xcb\xcf\x93\x89\x9a\x80u\xb3\xb0xp;;\xbb:~\xc4\x03\x8cq\xa9X\x87l\xde(\xc7\x88\xe5\xe4\xb8}\x9a\xee\xa7Um\x1e\x06\xfc\\\xf74\n<m\"\x8e\x04\t7\xf4\x95\xe7x\xc5\xc2:\xaa\xb6\xbe\ta;\x07\xcc\xab:n\x01\xe5`~\xac[u\xc7\xc5\xe3\xe3\xe4\x91JI%\xd6c\xb9J4\x04\x95\x97\x92\xa4JhZ\x89\x82-\x10\xf11\xbd*\x0f\x07\xd6\xcd\xc2\xeab\xc5\x9e@{H\x88\x13\xf3X@\x0e\xb2ezPM\x8d\x1d\x05M%\xd6\xad)A\xe5\xf3-z\xa0%\xebS\x874\x97\xaf\xa8\xf9\xb2\x83N\xd8\xac\x91\xa0\xc0Ml\x8e6|\xf5\x18\xbddB9G\xf2P\xd26}\xbd\xea\xb2\xe6C\xf9\x04;`\xace\xe6\x18\x03\x05O(4#M\xf3K\rZ8a\xe6qD9a\xa3\xe6\\e\xd6\xa6\x13\x92\x9d\xecX\x92F`>\x9c\xb9\0\xc9\xd4:\xd2(\xd6\xc3Qi\xec\x94\x87\xbe\xc2\xf6_O\x1f~\x92m\x02\x03\x01\0\x01\xa3H0F0D\x06\x03U\x1d\x11\x04=0;\x82%textsecure-service.whispersystems.org\x82\x12service.signal.org0\r\x06\t*\x86H\x86\xf7\r\x01\x01\x0b\x05\0\x03\x82\x01\x01\0)k.G\xbc\xf7\x0c?\xe1\xc4\xda\xf4\xb7X\xecK\xff(\x06\xd6\x8f\xea\xe37\x0e\xfdV\x0e|\x0e\xea\xdb(\x857aC\x17\xc9Ds\x01*p3\0\xcfo\xa1\x18\xaf\xdf^-\xa0h\x86*\xe9\xfaw|\xbfN\xb72+^e\r\x08\x1d\x88\xf4\xfan#\x88\xe3\xeb\x15-\x11\x17\x9c9t\x9a\x1cM\x82\xdd27\xb7\xb0\x88r\xf8[\x19MN\xac\x98\x83-\xb5E\x1cO\x11\x01\xebl$\x9c\x9d\xd9\x85\xae\xcc\x1c\x1d\xf5M\xe8Y.\x1978\xe5\xc1\x02\xd3:\"i\xa0\nR*c%C\xa3\x95~\x07k\xea\xb4S#Z\x1c\xc3\xea\xb8\xff\0\xf1q\x81!\x88\xba\x0c\x96<\xb8\xd8\x0f\xd6\xaf\x05\xf3\xc9C\x03\x91\xc0-dt\xe3\x91@.H\xb8\xaf\x9f\x8d\xf8\x9c\xb7\x18]\xa9LP\x85\xbc\xb1\x03K\x92\xc2\x93\xa9Q\xf6\xe8\xc2\x92\xda\xdd\x87E[8s\0\xdf\x9a\xd1\xb3\x99d\x8bn\x04A\x97\xff\x0e\xaa\xea\xb9\\\xb2\xcd\x11B\x0c\xdfSUp\x15\x05\xa4\xa8I"), Certificate(b"0\x82\x03\xef0\x82\x02\xd7\xa0\x03\x02\x01\x02\x02\t\0\x89\xba-\xabJ\xe4\xf3b0\r\x06\t*\x86H\x86\xf7\r\x01\x01\x05\x05\00\x81\x8d1\x0b0\t\x06\x03U\x04\x06\x13\x02US1\x130\x11\x06\x03U\x04\x08\x0c\nCalifornia1\x160\x14\x06\x03U\x04\x07\x0c\rSan Francisco1\x1d0\x1b\x06\x03U\x04\n\x0c\x14Open Whisper Systems1\x1d0\x1b\x06\x03U\x04\x0b\x0c\x14Open Whisper Systems1\x130\x11\x06\x03U\x04\x03\x0c\nTextSecure0\x1e\x17\r130325221835Z\x17\r230323221835Z0\x81\x8d1\x0b0\t\x06\x03U\x04\x06\x13\x02US1\x130\x11\x06\x03U\x04\x08\x0c\nCalifornia1\x160\x14\x06\x03U\x04\x07\x0c\rSan Francisco1\x1d0\x1b\x06\x03U\x04\n\x0c\x14Open Whisper Systems1\x1d0\x1b\x06\x03U\x04\x0b\x0c\x14Open Whisper Systems1\x130\x11\x06\x03U\x04\x03\x0c\nTextSecure0\x82\x01\"0\r\x06\t*\x86H\x86\xf7\r\x01\x01\x01\x05\0\x03\x82\x01\x0f\00\x82\x01\n\x02\x82\x01\x01\0\xc1I`i8 C\x17H\xb8\xabgx\x8c\x05\xe4Iu\x06\xa5\xb7\x96\xba\x05O@(\xda/\xaa\x83\xf5\0\xce\xc5\xe5\xb5i\xfb\xdf>\x8f:\xde.\x82\xae\xadJ\x0f\x11\xe9\x07~\x84\xc35\\\x8f\x02\xe4\x152\x0cz\x8e\xed\xf6\xcdEB\x89@\xb7y\x84\xad]\x94\xd2\xf8\x9e\xe9W\xac\xfb(\xfa\x82\xb4\x9f\xc7\x02\x03\x01\xc7l*b4kT\x90\t\x99k\xdd\rmpp$\0\xa1Q\xc5\x83Z\xc0\0\xf2\xa6\xceA\xf9\x99\xaar\x07\xfa\xe7t\xd7K\x9f\xf4 \xf3\xd0.\x87\x0b\x9f\xc1\x96/\x03\x986v\x1f\x06\xf2\x0b(3\x08\xb6fS\xb4F\xeeq\xd8\xa0\xc4@=\x99\xf2/\xbcp\x03\x11\xbb^.\xd5`\xc0\x19\xbdG\x9b\xd5\xbe\xdc+\x0f\xa0\x82\xc4\x8d\xe9\x80~\xc4\x1f\xb9\x0c?C\x9d\xf7|\x0b\x8a\xcb\xe7\xd7(Gc\xb1nbZ\xe4b\xa7d2\xf5\x94\xac\xaa\0I\\8\x8d\xbe\xbd\xbd\xa7\x89\tGT\xf8p\xa8\\\xe4\x8f\xd4\xf4\x1c/\xa5\x9e\x9c\xd0\x87\x02\x03\x01\0\x01\xa3P0N0\x1d\x06\x03U\x1d\x0e\x04\x16\x04\x14\x01\x8b\x18\xf1?\xfb9\x19Dn\x85\x86\xbe\x94e2\xa72<\x900\x1f\x06\x03U\x1d#\x04\x180\x16\x80\x14\x01\x8b\x18\xf1?\xfb9\x19Dn\x85\x86\xbe\x94e2\xa72<\x900\x0c\x06\x03U\x1d\x13\x04\x050\x03\x01\x01\xff0\r\x06\t*\x86H\x86\xf7\r\x01\x01\x05\x05\0\x03\x82\x01\x01\0~\x1e\xbe!\x0b\x9e\xa6\xd0\xbb\xc9\x02\xedQ+\xa3n<6\xd30C{\xfe3(\x8cQ\xf1\x1f\x83\xf7\\\xf1_\xba\x98\xd1\xf9\xb9\x03\xabJO9N\x89\x8c\x8cg\xac=W\x0f\xf1\x15\x994\xdaMV9\x88\xe8^\xca\xfe\xd4\xcc\x93\x9e}\xbd\xa9,\xe7=\xaa\xcb\xaf#\x87\xe7hD\xa1\xf5\xb8s\x96\x7f\x8b_\x1bB\xad\x13\xc6\x86L@\xd4\x83\x08\xa3r\x7f\xb3e\x85\xfc\xa5Xg'\"\xbb\xa6\xf8\xb9\xb2}\xd5s\xc0\xb8\x13Y\xc0\x89\xae\x83\xbf\xec\xadk\xdb\xa6M!\xab\xa0:\xcf^4Y5R*\xd2F\xecC\xf8\xd6B^\xfe\x81x\xba\xc69'\xb2\xcf\x93\x12\xb7-l\xcc&v\xf9\x10\x82C\x99\x1b\xf2\x1f\xcarG\x05\xa0\xe9\t\xba\xaa!\x85h\x8e'/\xc4\x14\xe0\xb6\xb5\xc7g\xa7\xe01\x97E\xa2\xcc=\x1c#\x10\xb3`@\xfa\x1dG\x7f3\xa0#.\x03\xc8\x07e\xf6Xb\x86{\x0f\xb45\xc0\xd5\"Tw1\xb8Z\xc4x\x16\x98%\xb2\xc4\xaf\x02\xd5")]
[2021-02-10T22:40:14Z DEBUG rustls::client::tls12] Server DNS name is DNSName("textsecure-service.whispersystems.org")
[2021-02-10T22:40:15Z DEBUG rustls::client::tls12] Session saved
[2021-02-10T22:40:15Z TRACE actix_connect::ssl::rustls] SSL Handshake success: "textsecure-service.whispersystems.org"
[2021-02-10T22:40:15Z TRACE actix_codec::framed] flushing framed transport
[2021-02-10T22:40:15Z TRACE actix_codec::framed] writing; remaining=313
[2021-02-10T22:40:15Z TRACE actix_codec::framed] framed transport flushed
[2021-02-10T22:40:15Z TRACE actix_codec::framed] attempting to decode a frame
[2021-02-10T22:40:15Z TRACE actix_codec::framed] frame decoded from buffer
[2021-02-10T22:40:15Z DEBUG libsignal_service_actix::push_service] AwcPushService::get response:
    ClientResponse HTTP/1.1 413 Payload Too Large
      headers:
        "cache-control": "must-revalidate,no-cache,no-store"
        "date": "Wed, 10 Feb 2021 22:40:15 GMT"
        "content-type": "text/html;charset=iso-8859-1"
        "x-signal-timestamp": "1612996815244"
        "connection": "keep-alive"
        "content-length": "476"
[2021-02-10T22:40:15Z TRACE mio::poll] deregistering handle with poller
[2021-02-10T22:40:15Z ERROR harbour_whisperfish::worker::client] Error sending message: Rate limit exceeded
[2021-02-10T22:40:15Z DEBUG harbour_whisperfish::store] [refresh_session] Fetching session
[2021-02-10T22:40:15Z TRACE harbour_whisperfish::store] Called fetch_session_by_source(+43XXXXXXXXXXX)
[2021-02-10T22:40:15Z DEBUG harbour_whisperfish::store] [refresh_session] 1052 +43XXXXXXXXXXX
[2021-02-10T22:40:15Z TRACE harbour_whisperfish::store] Called update_session()
[2021-02-10T22:40:15Z DEBUG harbour_whisperfish::store] [refresh_session] Updated
[2021-02-10T22:40:15Z TRACE harbour_whisperfish::model::session] STUB: Mark sent called
[2021-02-10T22:40:15Z TRACE harbour_whisperfish::model::message] Mark message 1052 sent 'true'
[2021-02-10T22:40:15Z TRACE harbour_whisperfish::model::contact] Formatting phone number with country Some(AT)
[2021-02-10T22:40:15Z TRACE harbour_whisperfish::model::contact] Formatted phone number: PhoneNumber { code: Code { value: 43, source: Plus }, national: NationalNumber { value: XXXXXXXXXXX, zeros: 0 }, extension: None, carrier: None }
[2021-02-10T22:40:15Z TRACE harbour_whisperfish::model::contact] Formatted phone number: PhoneNumber { code: Code { value: 43, source: Plus }, national: NationalNumber { value: YYYYY, zeros: 0 }, extension: None, carrier: None }
CENSORED
[2021-02-10T22:40:31Z TRACE libsignal_service_actix::websocket] Triggering keep-alive
[2021-02-10T22:40:31Z TRACE libsignal_service::messagepipe] Sending request WebSocketRequestMessage { verb: Some("GET"), path: Some("/v1/keepalive"), body: None, headers: [], id: Some(1612996831492) }
[2021-02-10T22:40:31Z TRACE actix_codec::framed] flushing framed transport
[2021-02-10T22:40:31Z TRACE actix_codec::framed] writing; remaining=37
[2021-02-10T22:40:31Z TRACE actix_codec::framed] framed transport flushed
[2021-02-10T22:40:31Z TRACE libsignal_service::messagepipe] request on route.
[2021-02-10T22:40:31Z TRACE actix_codec::framed] attempting to decode a frame
[2021-02-10T22:40:31Z TRACE actix_codec::framed] frame decoded from buffer
[2021-02-10T22:40:31Z TRACE libsignal_service::messagepipe] Decoded WebSocketMessage { r#type: Some(Response), request: None, response: Some(WebSocketResponseMessage { id: Some(1612996831492), status: Some(200), message: Some("OK"), headers: ["Content-Length:0"], body: None }) }
^A[2021-02-10T22:41:26Z TRACE libsignal_service_actix::websocket] Triggering keep-alive
[2021-02-10T22:41:26Z TRACE libsignal_service::messagepipe] Sending request WebSocketRequestMessage { verb: Some("GET"), path: Some("/v1/keepalive"), body: None, headers: [], id: Some(1612996886495) }
[2021-02-10T22:41:26Z TRACE actix_codec::framed] flushing framed transport
[2021-02-10T22:41:26Z TRACE actix_codec::framed] writing; remaining=37
[2021-02-10T22:41:26Z TRACE actix_codec::framed] framed transport flushed
[2021-02-10T22:41:26Z TRACE libsignal_service::messagepipe] request on route.
[2021-02-10T22:41:26Z TRACE actix_codec::framed] attempting to decode a frame
[2021-02-10T22:41:26Z TRACE actix_codec::framed] frame decoded from buffer
[2021-02-10T22:41:26Z TRACE libsignal_service::messagepipe] Decoded WebSocketMessage { r#type: Some(Response), request: None, response: Some(WebSocketResponseMessage { id: Some(1612996886495), status: Some(200), message: Some("OK"), headers: ["Content-Length:0"], body: None }) }
Version: v0.6.0-alpha.8 on SailfishOS X 4.0.1.45.
Now I thought that maybe I have to start a “New Message”… I did but accidentally sent “Test” to some number that does not exist. Result: I only see phone numbers and no names in the app anymore. Even after restart!
I have the trace copied (again censored) until I restarted:
2021-02-10T22:56:41Z TRACE harbour_whisperfish::actor::messageactor] MessageActor::handle(QueueMessage { source: "+62884427", message: "Test", attachment: "", group: "" })
[2021-02-10T22:56:41Z TRACE harbour_whisperfish::store] Called fetch_session_by_source(+62884427)
[2021-02-10T22:56:41Z TRACE harbour_whisperfish::store] Called create_session()
[2021-02-10T22:56:41Z TRACE harbour_whisperfish::store] Called fetch_latest_session()
[2021-02-10T22:56:41Z TRACE harbour_whisperfish::store] Called update_message_if_needed(14)
[2021-02-10T22:56:41Z TRACE harbour_whisperfish::store] Called create_message()
[2021-02-10T22:56:41Z TRACE harbour_whisperfish::store] Called fetch_latest_message()
[2021-02-10T22:56:41Z TRACE harbour_whisperfish::store] Inserted message id 1053
[2021-02-10T22:56:41Z INFO  harbour_whisperfish::worker::client] ClientActor::SendMessage(1053)
[2021-02-10T22:56:41Z TRACE harbour_whisperfish::store] Called fetch_message(1053)
[2021-02-10T22:56:41Z TRACE harbour_whisperfish::store] SELECT `message`.`id`, `message`.`session_id`, `message`.`source`, `message`.`message`, `message`.`timestamp`, `message`.`sent`, `message`.`received`, `message`.`flags`, `message`.`attachment`, `message`.`mime_type`, `message`.`has_attachment`, `message`.`outgoing`, CASE WHEN sentq.message_id > 0 THEN 1 ELSE 0 END AS queued FROM (`message` LEFT OUTER JOIN `sentq` ON `sentq`.`message_id` = `message`.`id`) WHERE `message`.`id` = ? -- binds: [1053]
[2021-02-10T22:56:41Z TRACE harbour_whisperfish::store] Called fetch_session(14)
[2021-02-10T22:56:41Z TRACE harbour_whisperfish::worker::client] Sending for session: Session { id: 14, source: "+62884427", message: "Test", timestamp: 1612997801578, sent: false, received: false, unread: false, is_group: false, group_members: None, group_id: None, group_name: None, has_attachment: false }
[2021-02-10T22:56:41Z TRACE harbour_whisperfish::worker::client] Sending message: Message { id: 1053, sid: 14, source: "+62884427", message: "Test", timestamp: 1612997801578, sent: false, received: false, flags: 0, attachment: None, mimetype: None, hasattachment: false, outgoing: true, queued: true }
[2021-02-10T22:56:41Z TRACE harbour_whisperfish::worker::client] Transmitting DataMessage { body: Some("Test"), attachments: [], group: None, group_v2: None, flags: None, expire_timer: None, profile_key: None, timestamp: Some(1612997801578), quote: None, contact: [], preview: [], sticker: None, required_protocol_version: Some(0), is_view_once: None, reaction: None, delete: None, body_ranges: [] }
[2021-02-10T22:56:41Z TRACE libsignal_service::sender] encrypting message for Address { name: "+62884427", device_id: 1 }
[2021-02-10T22:56:41Z TRACE harbour_whisperfish::store::protocol_store] contains_session(+62884427)
[2021-02-10T22:56:41Z INFO  libsignal_service::sender] establishing new session with Address { name: "+62884427", device_id: 1 }
[2021-02-10T22:56:41Z DEBUG libsignal_service_actix::push_service] AwcPushService::get(Url { scheme: "https", host: Some(Domain("textsecure-service.whispersystems.org")), port: None, path: "/v2/keys/+62884427/*", query: None, fragment: None })
[2021-02-10T22:56:41Z TRACE actix_connect::resolve] DNS resolver: resolving host "textsecure-service.whispersystems.org"
[2021-02-10T22:56:41Z TRACE actix_connect::resolve] DNS resolver: host "textsecure-service.whispersystems.org" resolved to [76.223.92.165:443, 13.248.212.111:443]
[2021-02-10T22:56:41Z TRACE actix_connect::connector] TCP connector - connecting to "textsecure-service.whispersystems.org" port:443
[2021-02-10T22:56:41Z TRACE mio::poll] registering with poller
[2021-02-10T22:56:41Z TRACE harbour_whisperfish::model::contact] Formatting phone number with country Some(AT)
CENSORED
[2021-02-10T22:56:41Z TRACE harbour_whisperfish::model::contact] Formatted phone number: PhoneNumber { code: Code { value: 43, source: Plus }, national: NationalNumber { value: YYYYYYYY, zeros: 0 }, extension: None, carrier: None }
CENSORED
[2021-02-10T22:56:42Z TRACE actix_connect::connector] TCP connector - successfully connected to connecting to "textsecure-service.whispersystems.org" - Ok(76.223.92.165:443)
[2021-02-10T22:56:42Z TRACE actix_connect::ssl::rustls] SSL Handshake start for: "textsecure-service.whispersystems.org"
[2021-02-10T22:56:42Z DEBUG rustls::client::hs] Resuming session
[2021-02-10T22:56:42Z TRACE rustls::client::hs] Sending ClientHello Message {
        typ: Handshake,
        version: TLSv1_0,
        payload: Handshake(
                typ: ClientHello,
                        random: Random(
                                48,
                                128,
                                69,
                                204,
                                238,
                                153,
                                45,
                                130,
                                146,
                                216,
                                185,
                                2,
                                30,
                                225,
                                56,
                                144,
                                236,
                                220,
                                48,
                                196,
                                8,
                                38,
                                222,
                                98,
                                164,
                                7,
                                144,
                                73,
                                154,
                                19,
                                123,
                                166,
                            205,
                            143,
                            66,
                            191,
                            155,
                            80,
                            162,
                            217,
                            36,
                            49,
                            197,
                            48,
                            238,
                            131,
                            55,
                            109,
                            56,
                            232,
                            164,
                            223,
                            138,
                            208,
                            119,
                            86,
                            220,
                            242,
                            180,
                            230,
                            7,
                            47,
                            244,
                            198,
                        cipher_suites: [
                            Null,
                        extensions: [
                            SupportedVersions(
                                    TLSv1_3,
                                    TLSv1_2,
                            ServerName(
                                    ServerName {
                                        typ: HostName,
                                        payload: HostName(
                                            DNSName(
                            ECPointFormats(
                                    Uncompressed,
                            NamedGroups(
                                    X25519,
                                    secp384r1,
                                    secp256r1,
                                    ED25519,
                                    RSA_PSS_SHA512,
                                    RSA_PSS_SHA384,
                                    RSA_PSS_SHA256,
                                    RSA_PKCS1_SHA512,
                                    RSA_PKCS1_SHA384,
                                    RSA_PKCS1_SHA256,
                                OCSP(
                                        responder_ids: [],
                            KeyShare(
                                    KeyShareEntry {
                                        group: X25519,
                                                234,
                                                6,
                                                138,
                                                219,
                                                191,
                                                51,
                                                135,
                                                178,
                                                13,
                                                224,
                                                37,
                                                69,
                                                128,
                                                171,
                                                246,
                                                155,
                                                88,
                                                177,
                                                191,
                                                87,
                                                34,
                                                236,
                                                50,
                                                101,
                                                100,
                                                159,
                                                86,
                                                122,
                                                19,
                                                88,
                                                20,
                                                87,
                            PresharedKeyModes(
                                    PSK_DHE_KE,
                            Protocols(
                                    PayloadU8(
                                            104,
                                            116,
                                            116,
                                            112,
                                            47,
                                            49,
                                            46,
                                            49,
                            SessionTicketOffer(
                                Payload(
                                        164,
                                        169,
                                        229,
                                        42,
                                        158,
                                        97,
                                        234,
                                        94,
                                        96,
                                        32,
                                        67,
                                        30,
                                        93,
                                        204,
                                        224,
                                        192,
                                        71,
                                        106,
                                        134,
                                        240,
                                        77,
                                        24,
                                        219,
                                        157,
                                        244,
                                        72,
                                        177,
                                        212,
                                        25,
                                        100,
                                        66,
                                        219,
                                        147,
                                        11,
                                        97,
                                        13,
                                        13,
                                        199,
                                        2,
                                        67,
                                        247,
                                        165,
                                        193,
                                        94,
                                        202,
                                        120,
                                        180,
                                        42,
                                        97,
                                        55,
                                        8,
                                        175,
                                        25,
                                        172,
                                        78,
                                        143,
                                        38,
                                        23,
                                        22,
                                        253,
                                        71,
                                        135,
                                        77,
                                        229,
                                        245,
                                        6,
                                        55,
                                        189,
                                        44,
                                        220,
                                        45,
                                        245,
                                        20,
                                        28,
                                        183,
                                        38,
                                        202,
                                        39,
                                        198,
                                        31,
                                        236,
                                        225,
                                        227,
                                        80,
                                        249,
                                        238,
                                        169,
                                        244,
                                        163,
                                        231,
                                        87,
                                        205,
                                        224,
                                        211,
                                        133,
                                        175,
                                        232,
                                        14,
                                        253,
                                        95,
                                        43,
                                        214,
                                        129,
                                        91,
                                        123,
                                        178,
                                        165,
                                        2,
                                        76,
                                        238,
                                        81,
                                        30,
                                        97,
                                        140,
                                        225,
                                        5,
                                        218,
                                        107,
                                        127,
                                        77,
                                        230,
                                        49,
                                        139,
                                        183,
                                        158,
                                        129,
                                        164,
                                        29,
                                        7,
                                        37,
                                        86,
                                        203,
                                        120,
                                        153,
                                        17,
                                        188,
                                        233,
                                        94,
                                        66,
                                        109,
                                        41,
                                        114,
                                        106,
                                        73,
                                        179,
                                        84,
                                        92,
                                        248,
                                        238,
                                        185,
                                        191,
                                        87,
                                        87,
                                        7,
                                        18,
                                        27,
                                        179,
                                        136,
                                        176,
                                        165,
                                        55,
                                        16,
                                        108,
                                        38,
                                        14,
                                        28,
                                        92,
                                        14,
                                        235,
                                        80,
                                        215,
                                        35,
                                        142,
                                        133,
                                        47,
                                        172,
                                        112,
                                        181,
                                        127,
                                        131,
                                        224,
                                        28,
                                        152,
                                        20,
                                        94,
                                        114,
                                        180,
                                        102,
                                        55,
                                        54,
                                        30,
                                        72,
                                        60,
                                        96,
                                        54,
                                        90,
                                        171,
                                        61,
                                        187,
                                        130,
                                        175,
                                        10,
                                        133,
                                        185,
                                        154,
                                        22,
                                        131,
                                        186,
                                        171,
                                        158,
                                        36,
                                        54,
                                        25,
                                        178,
                                        63,
                                        192,
                                        32,
                                        87,
                                        98,
                                        126,
                                        212,
                                        118,
                                        102,
                                        21,
[2021-02-10T22:56:42Z TRACE rustls::client::hs] We got ServerHello ServerHelloPayload {
        random: Random(
                139,
                185,
                110,
                60,
                114,
                105,
                62,
                98,
                124,
                35,
                42,
                27,
                198,
                215,
                88,
                17,
                148,
                189,
                75,
                41,
                72,
                159,
                208,
                70,
                227,
                236,
                106,
                132,
                238,
                115,
                149,
                155,
        extensions: [
            RenegotiationInfo(
                PayloadU8(
            ECPointFormats(
                    Uncompressed,
            SessionTicketAck,
            Protocols(
                    PayloadU8(
                            104,
                            116,
                            116,
                            112,
                            47,
                            49,
                            46,
                            49,
[2021-02-10T22:56:42Z DEBUG rustls::client::hs] ALPN protocol is Some([104, 116, 116, 112, 47, 49, 46, 49])
[2021-02-10T22:56:42Z DEBUG rustls::client::hs] Using ciphersuite TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
[2021-02-10T22:56:42Z DEBUG rustls::client::hs] Server supports tickets
[2021-02-10T22:56:42Z DEBUG rustls::client::tls12] ECDHE curve is ECParameters { curve_type: NamedCurve, named_group: secp256r1 }
[2021-02-10T22:56:42Z TRACE rustls::client::tls12] Server cert is [Certificate(b"0\x82\x03\xe30\x82\x02\xcb\xa0\x03\x02\x01\x02\x02\x02\x10\x180\r\x06\t*\x86H\x86\xf7\r\x01\x01\x0b\x05\00\x81\x8d1\x0b0\t\x06\x03U\x04\x06\x13\x02US1\x130\x11\x06\x03U\x04\x08\x0c\nCalifornia1\x160\x14\x06\x03U\x04\x07\x0c\rSan Francisco1\x1d0\x1b\x06\x03U\x04\n\x0c\x14Open Whisper Systems1\x1d0\x1b\x06\x03U\x04\x0b\x0c\x14Open Whisper Systems1\x130\x11\x06\x03U\x04\x03\x0c\nTextSecure0\x1e\x17\r190215173817Z\x17\r290312182020Z0\x81\x901\x0b0\t\x06\x03U\x04\x06\x13\x02US1\x130\x11\x06\x03U\x04\x08\x0c\nCalifornia1\x1d0\x1b\x06\x03U\x04\n\x0c\x14Open Whisper Systems1\x1d0\x1b\x06\x03U\x04\x0b\x0c\x14Open Whisper Systems1.0,\x06\x03U\x04\x03\x0c%textsecure-service.whispersystems.org0\x82\x01\"0\r\x06\t*\x86H\x86\xf7\r\x01\x01\x01\x05\0\x03\x82\x01\x0f\00\x82\x01\n\x02\x82\x01\x01\0\xac\xc8\x11\xb5\xd1E\xb7\xc0\xa2\xcb\xcf\x93\x89\x9a\x80u\xb3\xb0xp;;\xbb:~\xc4\x03\x8cq\xa9X\x87l\xde(\xc7\x88\xe5\xe4\xb8}\x9a\xee\xa7Um\x1e\x06\xfc\\\xf74\n<m\"\x8e\x04\t7\xf4\x95\xe7x\xc5\xc2:\xaa\xb6\xbe\ta;\x07\xcc\xab:n\x01\xe5`~\xac[u\xc7\xc5\xe3\xe3\xe4\x91JI%\xd6c\xb9J4\x04\x95\x97\x92\xa4JhZ\x89\x82-\x10\xf11\xbd*\x0f\x07\xd6\xcd\xc2\xeab\xc5\x9e@{H\x88\x13\xf3X@\x0e\xb2ezPM\x8d\x1d\x05M%\xd6\xad)A\xe5\xf3-z\xa0%\xebS\x874\x97\xaf\xa8\xf9\xb2\x83N\xd8\xac\x91\xa0\xc0Ml\x8e6|\xf5\x18\xbddB9G\xf2P\xd26}\xbd\xea\xb2\xe6C\xf9\x04;`\xace\xe6\x18\x03\x05O(4#M\xf3K\rZ8a\xe6qD9a\xa3\xe6\\e\xd6\xa6\x13\x92\x9d\xecX\x92F`>\x9c\xb9\0\xc9\xd4:\xd2(\xd6\xc3Qi\xec\x94\x87\xbe\xc2\xf6_O\x1f~\x92m\x02\x03\x01\0\x01\xa3H0F0D\x06\x03U\x1d\x11\x04=0;\x82%textsecure-service.whispersystems.org\x82\x12service.signal.org0\r\x06\t*\x86H\x86\xf7\r\x01\x01\x0b\x05\0\x03\x82\x01\x01\0)k.G\xbc\xf7\x0c?\xe1\xc4\xda\xf4\xb7X\xecK\xff(\x06\xd6\x8f\xea\xe37\x0e\xfdV\x0e|\x0e\xea\xdb(\x857aC\x17\xc9Ds\x01*p3\0\xcfo\xa1\x18\xaf\xdf^-\xa0h\x86*\xe9\xfaw|\xbfN\xb72+^e\r\x08\x1d\x88\xf4\xfan#\x88\xe3\xeb\x15-\x11\x17\x9c9t\x9a\x1cM\x82\xdd27\xb7\xb0\x88r\xf8[\x19MN\xac\x98\x83-\xb5E\x1cO\x11\x01\xebl$\x9c\x9d\xd9\x85\xae\xcc\x1c\x1d\xf5M\xe8Y.\x1978\xe5\xc1\x02\xd3:\"i\xa0\nR*c%C\xa3\x95~\x07k\xea\xb4S#Z\x1c\xc3\xea\xb8\xff\0\xf1q\x81!\x88\xba\x0c\x96<\xb8\xd8\x0f\xd6\xaf\x05\xf3\xc9C\x03\x91\xc0-dt\xe3\x91@.H\xb8\xaf\x9f\x8d\xf8\x9c\xb7\x18]\xa9LP\x85\xbc\xb1\x03K\x92\xc2\x93\xa9Q\xf6\xe8\xc2\x92\xda\xdd\x87E[8s\0\xdf\x9a\xd1\xb3\x99d\x8bn\x04A\x97\xff\x0e\xaa\xea\xb9\\\xb2\xcd\x11B\x0c\xdfSUp\x15\x05\xa4\xa8I"), Certificate(b"0\x82\x03\xef0\x82\x02\xd7\xa0\x03\x02\x01\x02\x02\t\0\x89\xba-\xabJ\xe4\xf3b0\r\x06\t*\x86H\x86\xf7\r\x01\x01\x05\x05\00\x81\x8d1\x0b0\t\x06\x03U\x04\x06\x13\x02US1\x130\x11\x06\x03U\x04\x08\x0c\nCalifornia1\x160\x14\x06\x03U\x04\x07\x0c\rSan Francisco1\x1d0\x1b\x06\x03U\x04\n\x0c\x14Open Whisper Systems1\x1d0\x1b\x06\x03U\x04\x0b\x0c\x14Open Whisper Systems1\x130\x11\x06\x03U\x04\x03\x0c\nTextSecure0\x1e\x17\r130325221835Z\x17\r230323221835Z0\x81\x8d1\x0b0\t\x06\x03U\x04\x06\x13\x02US1\x130\x11\x06\x03U\x04\x08\x0c\nCalifornia1\x160\x14\x06\x03U\x04\x07\x0c\rSan Francisco1\x1d0\x1b\x06\x03U\x04\n\x0c\x14Open Whisper Systems1\x1d0\x1b\x06\x03U\x04\x0b\x0c\x14Open Whisper Systems1\x130\x11\x06\x03U\x04\x03\x0c\nTextSecure0\x82\x01\"0\r\x06\t*\x86H\x86\xf7\r\x01\x01\x01\x05\0\x03\x82\x01\x0f\00\x82\x01\n\x02\x82\x01\x01\0\xc1I`i8 C\x17H\xb8\xabgx\x8c\x05\xe4Iu\x06\xa5\xb7\x96\xba\x05O@(\xda/\xaa\x83\xf5\0\xce\xc5\xe5\xb5i\xfb\xdf>\x8f:\xde.\x82\xae\xadJ\x0f\x11\xe9\x07~\x84\xc35\\\x8f\x02\xe4\x152\x0cz\x8e\xed\xf6\xcdEB\x89@\xb7y\x84\xad]\x94\xd2\xf8\x9e\xe9W\xac\xfb(\xfa\x82\xb4\x9f\xc7\x02\x03\x01\xc7l*b4kT\x90\t\x99k\xdd\rmpp$\0\xa1Q\xc5\x83Z\xc0\0\xf2\xa6\xceA\xf9\x99\xaar\x07\xfa\xe7t\xd7K\x9f\xf4 \xf3\xd0.\x87\x0b\x9f\xc1\x96/\x03\x986v\x1f\x06\xf2\x0b(3\x08\xb6fS\xb4F\xeeq\xd8\xa0\xc4@=\x99\xf2/\xbcp\x03\x11\xbb^.\xd5`\xc0\x19\xbdG\x9b\xd5\xbe\xdc+\x0f\xa0\x82\xc4\x8d\xe9\x80~\xc4\x1f\xb9\x0c?C\x9d\xf7|\x0b\x8a\xcb\xe7\xd7(Gc\xb1nbZ\xe4b\xa7d2\xf5\x94\xac\xaa\0I\\8\x8d\xbe\xbd\xbd\xa7\x89\tGT\xf8p\xa8\\\xe4\x8f\xd4\xf4\x1c/\xa5\x9e\x9c\xd0\x87\x02\x03\x01\0\x01\xa3P0N0\x1d\x06\x03U\x1d\x0e\x04\x16\x04\x14\x01\x8b\x18\xf1?\xfb9\x19Dn\x85\x86\xbe\x94e2\xa72<\x900\x1f\x06\x03U\x1d#\x04\x180\x16\x80\x14\x01\x8b\x18\xf1?\xfb9\x19Dn\x85\x86\xbe\x94e2\xa72<\x900\x0c\x06\x03U\x1d\x13\x04\x050\x03\x01\x01\xff0\r\x06\t*\x86H\x86\xf7\r\x01\x01\x05\x05\0\x03\x82\x01\x01\0~\x1e\xbe!\x0b\x9e\xa6\xd0\xbb\xc9\x02\xedQ+\xa3n<6\xd30C{\xfe3(\x8cQ\xf1\x1f\x83\xf7\\\xf1_\xba\x98\xd1\xf9\xb9\x03\xabJO9N\x89\x8c\x8cg\xac=W\x0f\xf1\x15\x994\xdaMV9\x88\xe8^\xca\xfe\xd4\xcc\x93\x9e}\xbd\xa9,\xe7=\xaa\xcb\xaf#\x87\xe7hD\xa1\xf5\xb8s\x96\x7f\x8b_\x1bB\xad\x13\xc6\x86L@\xd4\x83\x08\xa3r\x7f\xb3e\x85\xfc\xa5Xg'\"\xbb\xa6\xf8\xb9\xb2}\xd5s\xc0\xb8\x13Y\xc0\x89\xae\x83\xbf\xec\xadk\xdb\xa6M!\xab\xa0:\xcf^4Y5R*\xd2F\xecC\xf8\xd6B^\xfe\x81x\xba\xc69'\xb2\xcf\x93\x12\xb7-l\xcc&v\xf9\x10\x82C\x99\x1b\xf2\x1f\xcarG\x05\xa0\xe9\t\xba\xaa!\x85h\x8e'/\xc4\x14\xe0\xb6\xb5\xc7g\xa7\xe01\x97E\xa2\xcc=\x1c#\x10\xb3`@\xfa\x1dG\x7f3\xa0#.\x03\xc8\x07e\xf6Xb\x86{\x0f\xb45\xc0\xd5\"Tw1\xb8Z\xc4x\x16\x98%\xb2\xc4\xaf\x02\xd5")]
[2021-02-10T22:56:42Z DEBUG rustls::client::tls12] Server DNS name is DNSName("textsecure-service.whispersystems.org")
[2021-02-10T22:56:42Z TRACE harbour_whisperfish::model::contact] Formatting phone number with country Some(AT)
[2021-02-10T22:56:42Z TRACE harbour_whisperfish::model::contact] Formatted phone number: PhoneNumber { code: Code { value: 43, source: Plus }, national: NationalNumber { value: CENSORED, zeros: 0 }, extension: None, carrier: None }
[2021-02-10T22:56:42Z DEBUG rustls::client::tls12] Session saved
[2021-02-10T22:56:42Z TRACE actix_connect::ssl::rustls] SSL Handshake success: "textsecure-service.whispersystems.org"
[2021-02-10T22:56:42Z TRACE actix_codec::framed] flushing framed transport
[2021-02-10T22:56:42Z TRACE actix_codec::framed] writing; remaining=309
[2021-02-10T22:56:42Z TRACE actix_codec::framed] framed transport flushed
[2021-02-10T22:56:42Z TRACE actix_codec::framed] attempting to decode a frame
[2021-02-10T22:56:42Z TRACE actix_codec::framed] frame decoded from buffer
[2021-02-10T22:56:42Z DEBUG libsignal_service_actix::push_service] AwcPushService::get response:
    ClientResponse HTTP/1.1 404 Not Found
      headers:
        "date": "Wed, 10 Feb 2021 22:56:42 GMT"
        "content-type": "application/json"
        "x-signal-timestamp": "1612997802849"
        "content-length": "43"
[2021-02-10T22:56:42Z TRACE actix_http::h1::decoder] Length read: 43
[2021-02-10T22:56:42Z TRACE libsignal_service_actix::push_service] Unhandled response with body: Ok(b"{\"code\":404,\"message\":\"HTTP 404 Not Found\"}")
[2021-02-10T22:56:42Z ERROR harbour_whisperfish::worker::client] Error sending message: Unexpected response: HTTP 404
[2021-02-10T22:56:42Z DEBUG harbour_whisperfish::store] [refresh_session] Fetching session
[2021-02-10T22:56:42Z TRACE harbour_whisperfish::store] Called fetch_session_by_source(+62884427)
[2021-02-10T22:56:42Z DEBUG harbour_whisperfish::store] [refresh_session] 1053 +62884427
[2021-02-10T22:56:42Z TRACE harbour_whisperfish::store] Called update_session()
[2021-02-10T22:56:42Z DEBUG harbour_whisperfish::store] [refresh_session] Updated
[2021-02-10T22:56:42Z TRACE harbour_whisperfish::model::session] STUB: Mark sent called
[2021-02-10T22:56:43Z TRACE harbour_whisperfish::model::contact] Formatting phone number with country Some(AT)
[2021-02-10T22:56:43Z TRACE harbour_whisperfish::model::contact] Formatted phone number: PhoneNumber { code: Code { value: 62, source: Plus }, national: NationalNumber { value: CENSORED, zeros: 0 }, extension: None, carrier: None }
[2021-02-10T22:56:43Z WARN  harbour_whisperfish::model::contact] Phone number is invalid according to the `phonenumber` library. Proceed with caution
[2021-02-10T22:56:43Z TRACE harbour_whisperfish::model::contact] Formatted phone number: PhoneNumber { code: Code { value: 43, source: Plus }, national: NationalNumber { value: CENSORED, zeros: 0 }, extension: None, carrier: None }
[2021-02-10T22:56:43Z TRACE harbour_whisperfish::model::contact] Formatted phone number: PhoneNumber { code: Code { value: 43, source: Plus }, national: NationalNumber { value: YYYYYYYY, zeros: 0 }, extension: None, carrier: None }
CENSORED
[D] onClicked:142 - Activating session: 3
[2021-02-10T22:56:46Z TRACE harbour_whisperfish::model::contact] Formatting phone number with country Some(AT)
[2021-02-10T22:56:46Z TRACE harbour_whisperfish::model::contact] Formatted phone number: PhoneNumber { code: Code { value: 43, source: Plus }, national: NationalNumber { value: CENSORED, zeros: 0 }, extension: None, carrier: None }
[W] unknown:25 - file:///usr/share/harbour-whisperfish/qml/pages/Conversation.qml:25:25: Unable to assign [undefined] to QString
[2021-02-10T22:56:46Z TRACE harbour_whisperfish::model::message] Dispatched actor::FetchSession(3)
[2021-02-10T22:56:46Z TRACE harbour_whisperfish::store] Called fetch_session(3)
[2021-02-10T22:56:46Z TRACE harbour_whisperfish::model::message] handle_fetch_session(TEST)
[2021-02-10T22:56:46Z TRACE harbour_whisperfish::model::message] Dispatched actor::FetchAllMessages(3)
[2021-02-10T22:56:46Z TRACE harbour_whisperfish::store] Called fetch_all_messages(3)
[2021-02-10T22:56:46Z TRACE harbour_whisperfish::store] SELECT `message`.`id`, `message`.`session_id`, `message`.`source`, `message`.`message`, `message`.`timestamp`, `message`.`sent`, `message`.`received`, `message`.`flags`, `message`.`attachment`, `message`.`mime_type`, `message`.`has_attachment`, `message`.`outgoing`, CASE WHEN sentq.message_id > 0 THEN 1 ELSE 0 END AS queued FROM (`message` LEFT OUTER JOIN `sentq` ON `sentq`.`message_id` = `message`.`id`) WHERE `message`.`session_id` = ? ORDER BY `message`.`id` DESC -- binds: [3]
[2021-02-10T22:56:46Z TRACE harbour_whisperfish::model::message] handle_fetch_all_messages(3) count 35
[2021-02-10T22:56:47Z TRACE libsignal_service_actix::websocket] Triggering keep-alive
[2021-02-10T22:56:47Z TRACE libsignal_service::messagepipe] Sending request WebSocketRequestMessage { verb: Some("GET"), path: Some("/v1/keepalive"), body: None, headers: [], id: Some(1612997807332) }
[2021-02-10T22:56:47Z TRACE actix_codec::framed] flushing framed transport
[2021-02-10T22:56:47Z TRACE actix_codec::framed] writing; remaining=37
[2021-02-10T22:56:47Z TRACE actix_codec::framed] framed transport flushed
[2021-02-10T22:56:47Z TRACE libsignal_service::messagepipe] request on route.
[2021-02-10T22:56:47Z TRACE actix_codec::framed] attempting to decode a frame
[2021-02-10T22:56:47Z TRACE actix_codec::framed] frame decoded from buffer
[2021-02-10T22:56:47Z TRACE libsignal_service::messagepipe] Decoded WebSocketMessage { r#type: Some(Response), request: None, response: Some(WebSocketResponseMessage { id: Some(1612997807332), status: Some(200), message: Some("OK"), headers: ["Content-Length:0"], body: None }) }
[2021-02-10T22:56:52Z ERROR harbour_whisperfish::sfos::tokio_qt] unregisterTimers
[2021-02-10T22:56:52Z INFO  harbour_whisperfish] Shut down.
[2021-02-10T22:56:52Z TRACE mio::poll] deregistering handle with poller
The contact names not showing up (correctly) is a known issue and the cause is a change in Sailfish OS 4.0. It will be fixed in a later release of Whisperfish.
(I have a dirty workaround bubbling in the back of my head, but more research is needed…)
You tried too often to send a message to this new person, the actual error is hidden behind “413 rate limit exceeded” :crazy_face:
What is happening here is we’re bouncing on a new version of Signal’s registration procedure (which is not yet enforced on us): Signal now only allows to download pre-keys via the UUID path.
I made a “known issues” section on the Wiki because both of these issues will continue to show up everywhere now.
The good news is: everything boils down to implementing the UUID stuff. GroupV2, Sealed Sessions, new contacts, … The bad news is this is quite a bit of work :slight_smile:
I was using Whisperfish todat and I noticed that Read Receipts isn’t implemented yet. I didn’t find it in issues, either. It would be nice to have, but also completely “non-critical” feature - and optional, too. Just thought I’d mention it here anyway :slight_smile:
I thougt that it is shown at the overview page.
Noted
It’s shown both there and on the conversation page, but it’s only halfly implemented at this point.
