Device 1: Primary. Was affected by account deletion. Have backed up whisperfish dirs, removed them, and re-registered.
Device 2: Was Secondary to Device1 before the deletion. Is now (obviously) always Disconnected.
What’s the preferred way to get Device 2 to be Secondary to Device 1 again?
Is it also just delete the WF dirs, and repeat the Linking?
I’m running into the same issue on my Xperia 10 II. Even worse, after a few tries (closing Whisperfish and restarting it) I now get an error right after entering my phone number, so it never even reaches the captcha anymore.
Thanks for sharing! Meanwhile I tried also to register the same device as second device, instead of as primary device, but I am getting the same error. Running on SailfishOS 5.0.0.67 btw., but previously tried with the most recent 4 version with the same result.
If someone sends me a meme bomb with around 15 pictures, I can only check the first few. When I tap on the images that indicate “+XY”, it opens only the underlying single image. I cannot swipe left or right in the image viewer to navigate to the previous or next image of that meme bomb. It’s quite unintuitive. The missing “Write new message to someone” feature is, nobrainer, a huge problem to use this app.
It also does not run in background, unlike the settings option would indicate. I must manually open Whisperfish here and there to receive new messages.
Hi, the registration as a secondary device doesn’t work for me, have a fresh XA2 sailfish with 5.0.0.67 and a fresh WF installation from openrepos.
for my old device xperia X (sailfish 4) it no longer works.
Does Signal canceled this feature?
On support.signal.org I found:
Multiple mobile devices are not currently supported
Best regards Alex
That shouldn’t happen, normally it should run in the background, if you checked the option. Maybe you have disabled notifications? Or, have you enabled “Autostart at boot”?
You can work around that by setting the attachment path manually in settings, and then viewing the downloaded attachments in Gallery. I don’t think this is well documented, but you can check out the voice notes thing in the FAQ.
Workaround is to use a linked Signal Desktop to start conversations.
That’s fixed on Git, but unreleased.
Could you provide us with logs in an issue?
That’s a limit of Signal’s client implementations, that’s not relevant to our case.
I acquired the Jolla C2 Curiosity prompted me to ask if WF supports Voice calls and Video calls
Is there a detailed reference for the construction method
I have also just renamed the folders ~/.config/be.rubdos/ and ~/.local/share/be.rubdos/ and restarted WF. I reassigned the old password, choose primary device and entered my cell phone number and pressed continue. Then a web page from Signal Captcha (I think) was launched. I wanted to enter the checkbox for the question “Are you a human” but then the browser crashed. This procedure I repeated several times after erasing the browser cache. Now I only see the message if I click the “continue” button.
I tried to use whisperfish a couple of years ago but I found that the aggressive oom killer on my xperia 10II made it unusable. It constantly got killed so I indeed had to manually restart it several times a day to get any messages.
Whisperfish had no background deamon for a long time and actually had run visible on the home screen. Without visible WF no messages. Now, and for quite a time now, there’s the possibility to activate a background deamon. Maybe that was the issue back then for you.
Nope, that’s not the case. I have the same problem on 10II. Most of the times I use the browser, after that I have to restart the WF because the daemon is also killed…
