OK so this was my misunderstanding. I thought you did update SFOS and now Waydroid doesn’t work anymore.
But your problem from now I also had some times earlier as I had a Volla (unfortunately it died meanwhile). So my conclusion back then was: Never update Waydroid, Never change a working system.
At that time I had to completely deinstall Waydroid and then reinstall it, there was no other way, i really tried a lot but couldn’t make it work other way.
I’m just curious: it is supposed to get waydroid working with ne Xperia X V?
I installed it and tried waydroid init
but I get this:
waydroid init
[14:36:28] ERROR: Failed to get vendor OTA channel: http
s://ota.waydro.id/vendor/waydroid_arm64/HALIUM_16.json
[14:36:28] See also: <https://github.com/waydroid>
Run 'waydroid log' for details.
So I suppose, I’m missing something?
I can’t find that json with mentioned URL so maybe there must be an image prepared?
If so, how to do this?
I had the same problem, I reported it on the waydroid repo [Feature] Halium 16 support · Issue #1571 · waydroid/waydroid · GitHub
Hello I am trying to make it work at xperia 10iii
when i run waydroid init i get
[root@Xperia10III defaultuser]# waydroid init
[13:49:56] Already initialized
but when I run the app it is in the loading forever with
Waiting for Android Ui
am i missing something?
There is a waydroid telgram channel.
When i did play with it i did ask there
In the end it works when it works. Never update it etc
It seems very sensitive to versions
So once workings procedure might fail later due vto updated images…
