Trying to run the Mi Note 10 port on Mi Note 10 Lite
II. For me a getting complete logs to diagnose looks more easy and logic for start.
You wrote: You can edit /etc/systemd/journalctl.conf to make Storage=Persistent and have more backlog.
You mean that need to change this file?
cat /data/.stowaways/sailfishos/etc/systemd/journald.conf
[Journal]
Storage=volatile
Changed to test
# sed -i ‘s/volatile/persistent/’ /data/.stowaways/sailfishos/etc/systemd/journald.conf
Yes that and it should be accessible under etc too
Logs available here:
https://paste.fo/3008dd432ae8
Sorry for not replying earlier. Some links to block devices fail to create and from there the rest of the mounts fail. That would explain most of the following errors.
So there is something different with toco in this particular case. Maybe you can find what file to modify until I get the chance to inspect my device.
Don’t worry. I will try to find what file need to modify. As I understood kernel from tucana is suitable for toco. Or not? Maybe, better take kernel for toco, and modify this with your patches?
Yeah, kernel goes prettty far if it boots and you have telenet. I was thinking that these are woryying:
systemd-udevd[972]: Process '/bin/ln -s /dev/block/sda1 /dev/block/platform/soc/1d84000.ufshc/by-num/p1' failed with exit code 1.
Indeed that might be a kernel difference. As in, different stirage hardware is used. Do you have something equivalent in dev/block/platform/soc?
Finding a toco kernel that already builds for a Lineage 17.1 rom and applying the defconfig patches and the ramfs one would be another way forward, yes. Packaging it into a hybris boot would require partial steps from hadk
Folder by “by-num” not exists in /dev/block/platform/soc/1d84000.ufshc/
Here is containing of /dev/block/platform/soc/
https://paste.fo/31d4e520f223
I already tried to play with kernel litle bit, when waiting unlock bootloader timer - GitHub - sailfishos-on-toco/Xiaomi_Kernel_OpenSource at toco-q-oss_orig
I taked “toco-q-oss” and you are using “tucana-q-oss” from Xiaomi_Kernel_OpenSource, right?
I have created 3 branches
toco-q-oss
toco-hybris-17.1-mius
toco-q-oss_orig
Maybe you can push necessary patches to one of this branches?
In the second post here I say “probably it would be better to use the lineage xiaomi sm6150 kernel if there’s a lineage 17.1 version and patch it for hybris with my config changes” and give some context.
That route from Xiaomi Open Source is much longer and prone to errors and you should be able now to find a kernel with all the modules and mabve even some security patches backported.
I found lineage xiaomi sm6150 kernel a lineage 17.1 version
I have created a local repo - GitHub - sailfishos-on-toco/android_kernel_xiaomi_sm6150
Here is a some brances for toco
Ok, so you have many options;)
But before building another kernel you could do some more checks. I have extracted a similar journal from my device: https://paste.fo/raw/317c5c587159
It seems that udevd ln -s is also failing, so that is not the problem.
However, mine does not say this after “mount for /vendor”
mount: /vendor: wrong fs type, bad option, bad superblock on /dev/sda24, missing codepage or helper program, or other error.
If indeed you don’t have the /dev/sda24 at all that would be a problem.
Jun 14 16:53:17 MiNote10 kernel: sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 sda9 sda10 sda11 sda12 sda13 sda14 sda15 sda16 sda17 sda18 sda19 sda20 sda21 sda22 sda23 sda24 sda25 sda26 sda27 sda28 sda29 sda30 >
Jun 14 16:53:18 MiNote10 systemd-udevd[944]: Process ‘/bin/ln -s /dev/block/sda24 /dev/block/platform/soc/1d84000.ufshc/by-num/p24’ failed with exit code 1.
Jun 14 16:53:18 MiNote10 mount[1348]: mount: /vendor: wrong fs type, bad option, bad superblock on /dev/sda24, missing codepage or helper program, or other error.
Jun 14 16:53:18 MiNote10 kernel: EXT4-fs (sda24): VFS: Can’t find ext4 filesystem
Jun 14 16:53:18 MiNote10 mount[1387]: mount: /vendor: wrong fs type, bad option, bad superblock on /dev/sda24, missing codepage or helper program, or other error.
ls -lah /dev/block/platform/soc/1d84000.ufshc/
lrwxrwxrwx 1 root root 16 Jun 15 12:08 sda24 → /dev/block/sda24
journal from your device:
Oct 01 22:39:18 MiNote10 kernel: sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 sda9 sda10 sda11 sda12 sda13 sda14 sda15 sda16 sda17 sda18 sda19 sda20 sda21 sda22 sda23 sda24 sda25 sda26 sda27 sda28 sda29 sda30 sda31 sda32
Oct 01 22:39:19 MiNote10 systemd-udevd[949]: Process ‘/bin/ln -s /dev/block/sda24 /dev/block/platform/soc/1d84000.ufshc/by-num/p24’ failed with exit code 1.
Oct 01 22:39:19 MiNote10 kernel: EXT4-fs (sda24): mounted filesystem with ordered data mode. Opts: barrier=1
I can see /dev/sda24
https://paste.fo/raw/ad7b9a5c7e64
But my /vendor directory is empty, it is okay?
~ # ls -lah /vendor
ls -lah /vendor
total 7K
drwxr-xr-x    2 root     root        3.4K Mar  5 02:00 .
drwxr-xr-x   30 root     root        3.4K Jun 15 12:15 ..
~ # blkid
blkid output
/dev/sdf7: UUID="2d35bc8a-6cb5-43dc-adbc-bacf286218c0" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="persist" PARTUUID="e564318c-c2ae-55dd-8bce-2c99a9275fe0"
/dev/sdf5: PARTLABEL="modemst1" PARTUUID="8dd2e37f-2a73-2a18-387f-5176b46a15d8"
/dev/sdf3: PARTLABEL="bk51" PARTUUID="809725e6-d20c-e102-9da0-546a8afd9779"
/dev/sdf1: PARTLABEL="fsg" PARTUUID="d0b20b7f-a863-0699-af20-e1989314a412"
/dev/sdf8: UUID="2d35bc8a-6cb5-43dc-adbc-bacf286218c0" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="persistbak" PARTUUID="3ba9215e-6ef9-18ee-dc08-1a9f294005ab"
/dev/sdf6: PARTLABEL="modemst2" PARTUUID="f2b76a72-c795-85c4-430f-9ed494c668f9"
/dev/sdf4: PARTLABEL="bk52" PARTUUID="6772e53e-41e8-f952-b6da-f02c79b108f3"
/dev/sdf2: PARTLABEL="fsc" PARTUUID="5bb7a736-5bdf-e541-ec9e-c21176aa1217"
/dev/sdd2: PARTLABEL="cdt" PARTUUID="e43991cf-030a-515c-6a58-2e628c96e731"
/dev/sdd5: PARTLABEL="bk33" PARTUUID="65d702c1-f056-401b-af75-eccef61befc4"
/dev/sdd3: PARTLABEL="bk32" PARTUUID="ee411b7f-0670-9087-3ab9-d9c90fc9f938"
/dev/sdd1: PARTLABEL="bk31" PARTUUID="5252c9cc-1084-065e-af03-8aea9a9d9d77"
/dev/sdd4: PARTLABEL="ddr" PARTUUID="c209fbd2-3da7-2e41-90cf-bb296c2c23f4"
/dev/sdb2: PARTLABEL="xbl" PARTUUID="7a343c5f-296b-3b7f-9c21-57703fe7def4"
/dev/sdb1: PARTLABEL="xbl_config" PARTUUID="d7097f5b-2038-ad1d-cc34-d5f60a898a5f"
/dev/sde32: PARTLABEL="cateloader" PARTUUID="07d30ae9-a19e-65e1-9eec-ce6bcfaa2c03"
/dev/sde2: PARTLABEL="multiimgqti" PARTUUID="14b691fc-4194-68f3-ebf2-e09781320eb2"
/dev/sde22: PARTLABEL="cmnlib64" PARTUUID="d9530173-07f5-5aaf-7992-3cf83c72a70f"
/dev/sde50: PARTLABEL="bk47" PARTUUID="b32a6ba8-1b99-60e3-fa22-cf9ef623a23c"
/dev/sde12: PARTLABEL="vbmeta_system" PARTUUID="3fd83039-6309-a427-e81a-2e611a183bcc"
/dev/sde40: PARTLABEL="bk45" PARTUUID="54388fbc-a297-3397-3994-38c18b547997"
/dev/sde30: PARTLABEL="bk44" PARTUUID="afe45d26-2006-c7d5-2740-3da1cb122c67"
/dev/sde20: PARTLABEL="cmnlib" PARTUUID="9e2dfa6c-1c9f-2c77-448d-aa0883f67b98"
/dev/sde49: PARTLABEL="boot" PARTUUID="780eec73-83a4-dc39-7746-920349a4602a"
/dev/sde10: PARTLABEL="vbmeta" PARTUUID="16f6dfd5-3702-b198-630c-5972865cc9ac"
/dev/sde39: PARTLABEL="tzbak" PARTUUID="d84ba100-ba03-0e54-65ad-6a34d31f7ab0"
/dev/sde9: PARTLABEL="msadp" PARTUUID="ed59bc3a-2e92-158b-59f6-e3171b14ee58"
/dev/sde29: PARTLABEL="catecontentfv" PARTUUID="4ee230f2-feeb-6f3c-9b8c-56c980fe1e97"
/dev/sde19: PARTLABEL="catefv" PARTUUID="f1961659-6f20-337d-b300-cc8476ba3fb1"
/dev/sde47: PARTLABEL="logo" PARTUUID="f0464181-53d8-86b2-b32e-04616e225534"
/dev/sde37: PARTLABEL="ablbak" PARTUUID="e73c1800-995e-cf5e-08b6-030bfb15d67a"
/dev/sde7: PARTLABEL="qupfwbak" PARTUUID="aeac658c-84f5-8a00-2b64-3546af46847c"
/dev/sde27: SEC_TYPE="msdos" UUID="00BC-614E" BLOCK_SIZE="4096" TYPE="vfat" PARTLABEL="bluetooth" PARTUUID="49d6f14e-659f-0781-583d-d295bb955427"
/dev/sde17: PARTLABEL="aopbak" PARTUUID="ea6fa7be-78ea-ac87-a981-2d01b463506a"
/dev/sde45: PARTLABEL="dtbo" PARTUUID="f5dc5865-72dc-2ae1-4e44-9229c32cc5d9"
/dev/sde35: PARTLABEL="toolsfv" PARTUUID="dd33c201-db7d-f2f1-5091-ab87a55f8add"
/dev/sde5: PARTLABEL="bk41" PARTUUID="056e5562-f15e-a23d-26cf-fba7197d7184"
/dev/sde25: PARTLABEL="keymaster" PARTUUID="f9af5e39-32cf-6b4e-2058-021eb0b1d4e0"
/dev/sde15: PARTLABEL="devcfgbak" PARTUUID="a6875a5e-3762-e869-f4fe-fe5f440a01c9"
/dev/sde43: PARTLABEL="hypbak" PARTUUID="b6c6e8df-56c9-60f5-11d0-86e26e893899"
/dev/sde33: PARTLABEL="uefisecapp" PARTUUID="e0db4c46-a25e-f40c-d0a2-3d2b0444470c"
/dev/sde3: PARTLABEL="secdata" PARTUUID="a40f7ca9-868f-ca5c-d808-39ee1477fc2d"
/dev/sde23: PARTLABEL="cmnlib64bak" PARTUUID="52e5f5be-eb58-583f-df6f-146f8737dc25"
/dev/sde51: PARTLABEL="core_nhlos" PARTUUID="32744c5e-e79c-f1e6-0fca-e21e338e9eec"
/dev/sde13: PARTLABEL="vbmeta_vendor" PARTUUID="6810a532-7863-bd69-5674-7f84569d0a11"
/dev/sde41: PARTLABEL="spunvm" PARTUUID="b9aba849-7261-0451-e72c-b24c4ff63383"
/dev/sde31: PARTLABEL="bk44" PARTUUID="508d43be-fc11-1001-b810-c01bb16e82c5"
/dev/sde1: PARTLABEL="multiimgoem" PARTUUID="ecb1ea1d-3175-7631-37a1-5e62c74a5e83"
/dev/sde21: PARTLABEL="cmnlibbak" PARTUUID="8a2569b9-47df-881d-a11f-c15caee00368"
/dev/sde11: PARTLABEL="storsec" PARTUUID="bd76f8af-3c29-d46b-c545-7fc39e50a507"
/dev/sde48: LABEL="dsp" UUID="af32c008-2a39-7e5b-a5dc-201456d93103" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="dsp" PARTUUID="39d4553a-5a57-7423-19c0-a9bed9b1f604"
/dev/sde38: PARTLABEL="tz" PARTUUID="619a51bc-3f0a-9244-1273-9fcf5a5e57fd"
/dev/sde8: PARTLABEL="apdp" PARTUUID="79c2e699-65bb-f5da-0563-23f9d3e440c2"
/dev/sde28: PARTLABEL="dip" PARTUUID="dd68ca4e-9436-c7ae-d1c3-64347ae6b95b"
/dev/sde18: PARTLABEL="uefivarstore" PARTUUID="20c1d9dd-2644-3044-bd29-eb9b72162ab1"
/dev/sde46: PARTLABEL="ifaa" PARTUUID="eb456794-bd63-9282-7a98-ae1a5c3da7f4"
/dev/sde36: PARTLABEL="abl" PARTUUID="16fd21cc-d108-af0a-fd61-36ca8cd938b1"
/dev/sde6: PARTLABEL="qupfw" PARTUUID="4b0ac7e5-888c-ea7d-98ff-01ac95992bf7"
/dev/sde26: PARTLABEL="keymasterbak" PARTUUID="052afdb6-7aef-3546-d85a-a9a22520af99"
/dev/sde16: PARTLABEL="aop" PARTUUID="79349e9f-062d-63ab-d967-5af2be421f55"
/dev/sde44: PARTLABEL="gsort" PARTUUID="776462af-8e02-4c31-be26-a3d91702f7c9"
/dev/sde34: PARTLABEL="uefisecappbak" PARTUUID="3b482312-3759-6b87-47c1-3f755ab346be"
/dev/sde4: PARTLABEL="limits" PARTUUID="b7ba0008-4d7b-5411-c937-8059950d7d8f"
/dev/sde24: PARTLABEL="bk43" PARTUUID="ed37b464-eb6d-b465-e960-74639517458b"
/dev/sde52: SEC_TYPE="msdos" UUID="00BC-614E" BLOCK_SIZE="4096" TYPE="vfat" PARTLABEL="modem" PARTUUID="93ed7146-b393-ef69-f080-f8475cb210e9"
/dev/sde14: PARTLABEL="devcfg" PARTUUID="edce4593-8440-14a4-2d0c-73f98fb0b9e7"
/dev/sde42: PARTLABEL="hyp" PARTUUID="08f08ebc-11a7-9767-6cbf-ea74c1f6ff4e"
/dev/sdc2: PARTLABEL="xblbak" PARTUUID="007b932c-2883-ae39-09c3-2ccd257159c9"
/dev/sdc1: PARTLABEL="xbl_configbak" PARTUUID="ad453d60-8365-b9a8-8112-d04349a3c73b"
/dev/sda4: PARTLABEL="bk01" PARTUUID="159df18d-cde0-fb33-4641-de14fd25912e"
/dev/sda26: PARTLABEL="rawdump" PARTUUID="602c9596-9872-7968-c960-9443258f8998"
/dev/sda16: PARTLABEL="oops" PARTUUID="9d0b8c4c-794e-c5f8-6d42-8bbbb48943f7"
/dev/sda2: PARTLABEL="ssd" PARTUUID="b15463b0-eb98-9b36-d27e-88d0c03879db"
**/dev/sda24: PARTLABEL="logdump" PARTUUID="711fdbdb-75c9-8a89-5fd9-c382104862bc"**
/dev/sda14: SEC_TYPE="msdos" LABEL="LOGFS" UUID="D273-55EA" BLOCK_SIZE="4096" TYPE="vfat" PARTLABEL="logfs" PARTUUID="ff540b61-91e7-9ffa-87da-e79b85088ad7"
/dev/sda32: UUID="cf279b97-d2be-45d0-ab76-f996558b2170" BLOCK_SIZE="4096" TYPE="f2fs" PARTLABEL="userdata" PARTUUID="e19d44ff-926f-b9e4-a5b1-ef37b2e46dda"
/dev/sda22: PARTLABEL="bk09" PARTUUID="e0442119-6f47-a86a-09c5-91b5b08ab69f"
/dev/sda12: PARTLABEL="vm-data" PARTUUID="42f88045-6ed6-d205-d8e6-a9e7495dc061"
/dev/sda9: PARTLABEL="frp" PARTUUID="e2495557-344a-4c44-baef-348577b9dbf6"
/dev/sda30: PARTLABEL="exaid" PARTUUID="35960405-2a78-1b9b-de81-df3f83a65eed"
/dev/sda20: PARTLABEL="bk08" PARTUUID="01b23c75-031e-98e2-5683-4fcda9050041"
/dev/sda10: PARTLABEL="bk05" PARTUUID="26a4be96-acd3-0b1c-d0c2-6af9f09cf86b"
/dev/sda7: PARTLABEL="bk04" PARTUUID="4e24d1f2-ce30-1cf9-3b67-37e690cad34d"
/dev/sda29: UUID="735d9d73-abee-411d-a4bf-c57bc1e77a60" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="cache" PARTUUID="b42bbd7c-f61f-b6c8-cbbc-60a0ecfb8821"
/dev/sda19: UUID="2b750f4b-dc22-49a6-a6dc-e3ee8310dec4" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="metadata" PARTUUID="4b9cbd02-e89f-7e9a-b8d7-c7f8482855dc"
/dev/sda5: PARTLABEL="bk02" PARTUUID="0054517f-e8fb-ca69-de9a-56f0866c9d00"
/dev/sda27: PARTLABEL="imagefv" PARTUUID="25d05a73-70cc-2f66-793d-8e8b1509a9bf"
/dev/sda17: PARTLABEL="devinfo" PARTUUID="122ff74e-6a15-5ccc-d660-9617c743a395"
/dev/sda3: PARTLABEL="dbg" PARTUUID="ba156041-43d8-9466-8742-1b78f85387b6"
/dev/sda25: PARTLABEL="minidump" PARTUUID="693c8a43-e393-ee7a-57bc-83f8e834cbfd"
/dev/sda15: PARTLABEL="bk07" PARTUUID="7fb4f41c-2292-a77d-e657-5e3819398307"
/dev/sda1: PARTLABEL="switch" PARTUUID="db68403e-f27a-dff3-3792-55037e6f117a"
/dev/sda23: PARTLABEL="super" PARTUUID="5c5bdb29-c767-7eda-7b03-f5d60cf047ed"
/dev/sda13: PARTLABEL="bk06" PARTUUID="5058eaf3-1582-80cc-3643-b188436b60b5"
/dev/sda31: LABEL="cust" UUID="6bd92fa5-c011-48f0-86ce-795013b1d9d4" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="cust" PARTUUID="eb432a82-6dca-2cdc-0743-ece970cf0e56"
/dev/sda21: PARTLABEL="splash" PARTUUID="a11b5a5d-937e-6d6b-e497-724ecb2c4e67"
/dev/sda11: PARTLABEL="misc" PARTUUID="eab82c96-57ce-14fa-e6e3-6d1ff260a5bb"
/dev/sda8: PARTLABEL="keystore" PARTUUID="0be45f1b-2e05-091b-5a61-9574a137a1a0"
/dev/sda6: PARTLABEL="bk03" PARTUUID="9b091c9c-f5ba-d6d7-b043-090334a82d9a"
/dev/sda28: PARTLABEL="recovery" PARTUUID="560b10e9-a72f-5448-65bb-e91933d57167"
/dev/sda18: PARTLABEL="oem_misc1" PARTUUID="49bd9c74-338c-359d-5d3b-81d27d67f941"
~ # df
df output
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda32            49811420   3518952  46292468   7% /
/dev/sda32            49811420   3518952  46292468   7% /data
devtmpfs               2731212         0   2731212   0% /dev
tmpfs                  2838712         0   2838712   0% /dev/shm
tmpfs                  2838712      8204   2830508   0% /run
tmpfs                  2838712         0   2838712   0% /sys/fs/cgroup
tmpfs                  2838712         0   2838712   0% /tmp
/dev/sda32               59376      2712     54704   5% /persist
/dev/sdf7                59376      2712     54704   5% /mnt/vendor/persist
/dev/sdf7                59376      2712     54704   5% /persist
tmpfs                   567740         8    567732   0% /run/user/100000
Clearly toco’s partitions are numbered differently, thanks for the output.
(maybe format the previous post into a <details><summary>output</summary> <pre>$OUTPUTHERE </pre></details> for easier thread browsing)
Unfortunaltey not even a fstab file such as this points exactly to where the partition is.
And the kernel just seems to use "/dev/block/platform/soc/1d84000.ufshc/by-name/vendor " just as does mine.
Maybe you can figure out the system / vendor and other partitions that fail to mount from /dev/block/platform/soc/1d84000.ufshc/by-name ? If you do, you would need to change the systemd mount files
Thanks, previous post edited and now looks better.
Not sure, but maybe here is defined mounting-point?
-e 's block/bootdevice/by-name/vendor sda24 ' \
Ah, you’re right, the by-name are defined by me in hybris-boot :blush:
I think I determined them from running mount in Android shell… which means you’d have to flash one of the android boot.img s you had before and boot into that. Might require re-formatting of data afterwords.
Of course you could just try to mount each /dev/block/sd* by hand and see which one looks like a system or vendor partition (or the other missing ones…)
From HADK §5.3:
To get that mapping, you should flash and boot an image of your Android base and execute adb shell on
your host and something like this: ls -l /dev/block/platform/*/by-name/ on your device.
To get the correct path you must find Android’s fstab in device repository or in device itself and get by-name path like: block/bootdevice/by-name/userdata, ls -l /dev/block/platform/*/*/by-name/ or block/platform/*/by-name/userdata from it.
Okey, I will try to flash android boot.img
I can take original boot.img
or better to use patched.img boot with root?
Steps for flashing are correct?
'# fastboot devices
'# fastboot flash boot magisk_patched-27000_XxPuq.img
'# fastboot reboot
Sure, use the root one. Maybe not even flash, fastboot boot it. But that still may encrypt your /data…
When you get a hold of what the system or vendor partions are, we could fix that too from the on-device fstab
I got toco mount points
toco mount points
1|toco:/ $ ls -l /dev/block/platform/*/*/by-name/
total 0
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 abl -> /dev/block/sde36
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 ablbak -> /dev/block/sde37
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 aop -> /dev/block/sde16
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 aopbak -> /dev/block/sde17
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 apdp -> /dev/block/sde8
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 bk01 -> /dev/block/sda4
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 bk02 -> /dev/block/sda5
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 bk03 -> /dev/block/sda6
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 bk04 -> /dev/block/sda7
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 bk05 -> /dev/block/sda10
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 bk06 -> /dev/block/sda13
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 bk07 -> /dev/block/sda15
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 bk08 -> /dev/block/sda20
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 bk09 -> /dev/block/sda22
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 bk31 -> /dev/block/sdd1
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 bk32 -> /dev/block/sdd3
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 bk33 -> /dev/block/sdd5
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 bk41 -> /dev/block/sde5
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 bk43 -> /dev/block/sde24
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 bk44 -> /dev/block/sde30
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 bk45 -> /dev/block/sde40
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 bk47 -> /dev/block/sde50
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 bk51 -> /dev/block/sdf3
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 bk52 -> /dev/block/sdf4
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 bluetooth -> /dev/block/sde27
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 boot -> /dev/block/sde49
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 cache -> /dev/block/sda29
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 catecontentfv -> /dev/block/sde29
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 catefv -> /dev/block/sde19
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 cateloader -> /dev/block/sde32
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 cdt -> /dev/block/sdd2
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 cmnlib -> /dev/block/sde20
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 cmnlib64 -> /dev/block/sde22
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 cmnlib64bak -> /dev/block/sde23
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 cmnlibbak -> /dev/block/sde21
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 core_nhlos -> /dev/block/sde51
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 cust -> /dev/block/sda31
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 dbg -> /dev/block/sda3
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 ddr -> /dev/block/sdd4
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 devcfg -> /dev/block/sde14
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 devcfgbak -> /dev/block/sde15
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 devinfo -> /dev/block/sda17
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 dip -> /dev/block/sde28
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 dsp -> /dev/block/sde48
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 dtbo -> /dev/block/sde45
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 exaid -> /dev/block/sda30
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 frp -> /dev/block/sda9
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 fsc -> /dev/block/sdf2
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 fsg -> /dev/block/sdf1
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 gsort -> /dev/block/sde44
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 hyp -> /dev/block/sde42
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 hypbak -> /dev/block/sde43
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 ifaa -> /dev/block/sde46
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 imagefv -> /dev/block/sda27
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 keymaster -> /dev/block/sde25
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 keymasterbak -> /dev/block/sde26
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 keystore -> /dev/block/sda8
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 limits -> /dev/block/sde4
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 logdump -> /dev/block/sda24
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 logfs -> /dev/block/sda14
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 logo -> /dev/block/sde47
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 metadata -> /dev/block/sda19
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 minidump -> /dev/block/sda25
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 misc -> /dev/block/sda11
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 modem -> /dev/block/sde52
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 modemst1 -> /dev/block/sdf5
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 modemst2 -> /dev/block/sdf6
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 msadp -> /dev/block/sde9
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 multiimgoem -> /dev/block/sde1
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 multiimgqti -> /dev/block/sde2
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 oem_misc1 -> /dev/block/sda18
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 oops -> /dev/block/sda16
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 persist -> /dev/block/sdf7
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 persistbak -> /dev/block/sdf8
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 qupfw -> /dev/block/sde6
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 qupfwbak -> /dev/block/sde7
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 rawdump -> /dev/block/sda26
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 recovery -> /dev/block/sda28
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 secdata -> /dev/block/sde3
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 splash -> /dev/block/sda21
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 spunvm -> /dev/block/sde41
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 ssd -> /dev/block/sda2
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 storsec -> /dev/block/sde11
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 super -> /dev/block/sda23
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 switch -> /dev/block/sda1
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 toolsfv -> /dev/block/sde35
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 tz -> /dev/block/sde38
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 tzbak -> /dev/block/sde39
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 uefisecapp -> /dev/block/sde33
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 uefisecappbak -> /dev/block/sde34
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 uefivarstore -> /dev/block/sde18
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 userdata -> /dev/block/sda32
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 vbmeta -> /dev/block/sde10
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 vbmeta_system -> /dev/block/sde12
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 vbmeta_vendor -> /dev/block/sde13
lrwxrwxrwx 1 root root 16 1970-03-12 10:21 vm-data -> /dev/block/sda12
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 xbl -> /dev/block/sdb2
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 xbl_config -> /dev/block/sdb1
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 xbl_configbak -> /dev/block/sdc1
lrwxrwxrwx 1 root root 15 1970-03-12 10:21 xblbak -> /dev/block/sdc2
Oops. You have Dynamic Partitions…are you sure your device came like this 4-5 years ago? That’s a newer thing. There might have been custom roms that added that later, though.
That was actually visible from lsblk. And it explainds missing /dev/sda24 (as it got merged into sda23 probably, for more space).
Need to think more if we can retrofitt dynparts easily, maybe you have instructions how to revert if they were created by a custom ROM?
No, my device without any fw modifications.
According to information from GitHub - tchebb/parse-android-dynparts: Allows mounting Android Dynamic Partitions (a.k.a. super.img) files on Linux using "dmsetup create"
Most devices running Android 10 and higher use Android’s Dynamic Partitions feature…
About Dynamic partitions:
Dinamik bölümlendirme uygulama  |  Android Open Source Project
BTW, maybe, it is possible to use this tool under Sailfish OS for mounting necessary stuff?
Other user-guide that I found
https://xdaforums.com/t/guide-flash-retrofit-dynamic-partition-roms-on-redmi-7a-8-8a.4515423/
Revert back to standard partition ROM:
  1. Enter recovery
  2. Untick “Settings > Unmount System before installing a ZIP”
  3. Do “Advanced > Unmap Super Devices”
  4. Flash the ROM
  5. Factory Reset (Format data is recommended)
  6. Reboot and Enjoy
From: adb - How to mount system under super partion? - Android Enthusiasts Stack Exchange
On devices with enough disk space one can convert ext4-dedup dynamic partition into r/w system partition.
This can be done
  1. offline on linux computer using (official) Dynamic Partition Tools lpunpack and lpmake for which precompiled binaries are available from (unofficial) OTA Tools
  2. offline on device from TWRP recovery with 3rd party tool super image dumper for which precompiled binaries can be downloaded from XDA super image tools
  3. online on device via 3rd party bash script SystemRW running entirely from /data/local/tmp
