Thank you for the feedback. I’d be interested to see the logs of such case, limited connection means that online check did not succeed and that part is not touched with these changes. In addition to the aforementioned files put to /etc/sysconfig/connman in this case it would be beneficial to add -d plugins/sailfish_ofono.c as well. There can be a plethora of reasons for the mobile data staying on limited connection state so it is a bit hard to guess without seeing some logs.
Thank you! All seems well there according to the logs but there is always a room for improvement. And further internal testing showed some other issues as well. We’ve made a new version that is later today /tomorrow available on the same repository.
I have installed the patch on my phone, and it fixes my issue with hotspot. With the 4.5 update, my 4g was a bit spotty will on the road. I will report back if it fixes this issue too.
I case it could help here is my configuration
Phone Xperia 10 II
Provider RED by SFR
SIM in the first slot
There might also be something going on with the WLAN adapter. That case is hard to reproduce but when it happens it sometimes has reproduced even after reboot. So in such case when tethering does not work could you try just simply try if the device connects to any WLAN, if not, power toggle WLAN and if that does not help use toggle flight mode on-off once. If you wish to send logs from journal: journalctl -b|grep -i wlan to the connman-debug@jolla.com
Thank you. Unfortunately that log did not really reveal anything :(. Will just have to try to reproduce the WLAN issues by myself next week. However, I did a fix to address the IPv6 address neighbour solicitation issue (DAD) which may have caused odd issues after a while. Android clat states that:
Apparently some network gear will refuse to perform NS for IPs that aren’t DAD’ed, this would then result in an ipv6-only network with working native ipv6, working IPv4 via DNS64, but non-functioning IPv4 via CLAT (ie. IPv4 literals + IPv4 only apps).
So before the fix DAD was unfortunately done only once. Now it, with 1.32+git193.27 repeats it. It will be available later today/during weekend on the repo.
I updated it but still have no hotspot. Now I even have the error with the hotspot like back then with 4.4 that my Steam Deck simply goes out when connecting
No problem with the translator, I just want to get a more definite description of what your Steam Deck was/is doing. Does its network disable itself, or reboot, or does the network fail to connect, or seem connected but there’s no internet?
Oh okay.
It just goes off completely.
So far it has only happened to me when establishing a connection to the 10 III hotspot. Was like that before the patch and with the current patch it happened again during testing
If the connection works, I have no internet. But then it is the same for other devices.
So far it has worked once after installing or updating and I then also had internet. Only with the current patch did that no longer work and I have this error as before
