This is a great summary, thanks!
I slapped Open Camera on it and it’s a very nice app:
Even with very quick testing, you can tell that it works much better than the built-in camera app and Advanced Camera.
You’ve probably also noticed the menus are very broken. Fiddle with them and you can get them to work. Notable setting is switching it from Camera 1.0 API to 2.0.
I wrote a thread on HDR photography here:
Hi,
Thanks for that,
It took me a little while to find my way into the menus and those are tricky to get working. There seem to be some options that you can’t quite get at, but it works fine overall.
One thing I noticed was that, when I enabled API 2, whatever you tried, the image would be very pale - what it captured was very noticeably different (overexposed). That was the case when you left on auto, or HDR or anything.
When I put it back on API 1, it seems to work faster, and it takes a decent image.
