Since the last update of Meecast (incl. daemon and event-view), the event-view doesn’t update the actual weather condition. After reboot or after restarting the start screen it is up to date, but it doesn’t update without doing so.
The version was 1.12.17-1.30.1.bso. To make sure, that I didn’t mixed up the sources, I uninstalled all three components, but then I wasn’t able to install them again, neither from Chum nor from OpenRepos. It always claimed, that the event-view package ist not available.
Then I set Chum to version 4.6 and I could install all three components (same version as above, but ending with .jolla).
The result is the same, event-view does not date the data up.
Manual works - Openrepos site or via Storeman or Chum. Just match the version number across the three apps.
Meecast Sailfish
Meecast Eventview
Meecat Daemon
I un-installed Meecast daemon Storeman App, then downloaded the previous rpm version from Openrepos site and installed it. And finally, rebooted the phone.
I’ve installed the latest 1.12.18.1 updates for all three parts (app, daemon, eventview) from Openrepos, but the events view is still not updating for me. If I reboot or restart the home screen, or delete and re-add the location in the app it does update, but only once and never again.
