@MRQ, @ljo
There is considerable risk that your comments in this thread will remain unnoticed.
Please create a report in the Bug reports section, maybe using the Bugger app to help with the scaffolding. This will make the problem more visible, and a lot easier to track and discuss.
Hallo, if I want to update to Tampella 5.0.0.43 I’ll be getting an error message: “package size cannot be determined”. Does anyone know the problem or has a solution?
I’ve just received my C2 yesterday. and then after setting it up, it just offered to update to this mentioned version. and then when attempting to get it installed it will produce this error message.
just checkt in system settings/product information, there it says “Build 5.0.0.55 (Tampella)”. So I guess this means that we are running a newer version as what is offered as update. So basicaly I guess that we are indeed up to date already and would not require to install this offered update. Infact I guess this would rather be a downgrade than an update…
