[RELEASE] FUTO Keyboard (with Swipe and Offline Voice Input)
@htheb This is the following Icon I use to “paste” data.
This icon is not present by default when I place my cursor to type text. It only appears if I type at least one letter.
@fulg09 Will be fixed in the next update
FUTO Keyboard for Sailfish OS 0.9.0
New features
  • Added Japanese input with Romaji and 12-key kana flick layouts, kana/kanji conversion, and next-word suggestions.
  • Added Chinese Pinyin and stroke layouts for Simplified and Traditional Chinese, including fuzzy Pinyin and double-Pinyin options.
  • Added downloadable Japanese and Chinese dictionaries, encrypted learning, and an expandable conversion picker.
  • Added an option to change selected text using Shift: initial capitals or ALL CAPS.
  • Added an option to delete more words by dragging farther left from Backspace.
  • Saved-login prompts can now be dismissed by swiping left or right.
Fixes
  • Fixed unwanted word replacements and misplaced text when editing sentences or changing text fields.
  • Fixed missed or out-of-order words when swiping quickly.
  • Keypress sounds now play on press instead of release.
  • Paste now appears immediately in a text field, without needing to type first.
  • Improved key sizing and alignment in thumb mode, and removed stray separator lines.
Download
The download is available via OpenRepos.net or the OpenRepos app Storeman
Tested, works like a charm. Thank you very much !
Japanese flick works well but Emoji is not visible.
Thanks for the updates!
It seems like the suggested fix solved the emoji problem, it is being rendered properly now.
Now I have an issue about keyboard layout:
I really miss that feature of the built in Sailfish keyboard that has dedicated “Ö“ “Ü“ and “ ´ “ keys which is a lot more convenient than using the traditional long keypress that everything uses except the Sailfish keyboard, including this keyboard aswell. The “ ´ “ key is to make vowels long in Hungarian so when I press that key all of the vowels became bold and gain that accent over them so typing “Ű“ for example is done by pressing the “ ´ “ key then pressing the “Ü“ key. The same is true for I → Í, A → Á and so on.
Now because of the nature of the Hungarian language relying on text prediction is completely wrong as words has different forms depending on the context and sentence so simply typing out the words without accents then picking the right word from the keyboard suggestions will never work properly.
I should also mention that long pressing the keys has a lot of completely unnecessary accented letters that the Hungarian language don’t have and because of them I have to travel with my finger across the screen since the right letters are usually far away from the starting point. For example the letter “O“ has options like Ò, Ô, Õ and Ø that are all useless for Hungarian but they are all more reachable than Ö, Ő or Ó that would actually be used.
But again having a dead key would be significantly faster than using the long press method, because the latter is slow.
@naokysatoh you need to download the emojis and enable it in the settings
@htheb Could you implement the keyboard edit feature? I’m tired of editing files after every update :wink:
I’ve downloaded it and I can type them, however, I cannot see any emojis in the keyboard (I typed by tapping the area randomly)
Did you tried restarting the keyboard or phone?
Go to FUTO settings → Emoji, and select the used emoji style.
The new features work really well :heart:
As for the emoji: maybe set the downloaded pack as active right away, unless another pack has already been chosen?
@naokysatoh As stated before: you also need to SELECT it in FUTO Settings > Emoji
:smirking_face: :smirking_face: :smirking_face:
Oh I see. The default SFOS style cannot be seen but I now see them after switching another style. Thanks
I’ll check why the Sailfish OS style cannot be seen, (if it’s not a missing emoji)
FUTO Keyboard for Sailfish OS 0.9.5
New features
  • Added FUTO Layout Editor!
    • Create a keyboard or copy an existing one.
    • Add, move, and resize keys.
    • Choose letters, symbols, long-press characters and dead keys.
    • Add extra pages and empty spaces.
    • Try your keyboard before saving.
    • Import, export, and share layouts.
    • Use custom layouts with any language.
    • Added an option under Maintenance to show or hide FUTO Layout Editor in the app drawer.
Download
Thank you for this enormous amount of work; it’s incredible.
@Htheb Amazing, thank you. But where can i select my custom layout? And how do i edit the shifted long press alternatives? For me the shift lry on the preview your keyboard mode in the editor doesn’t work. Thanks for your work :+1:
Hi @HtheB! Thank you so much for adding the layout edit feature, it’s great! However, since I switched to my edited layout, the shift key doesn’t work anymore.
Additionally, I can’t access emojis by long pressing the enter key in the edited layout.
