“Any number from my contact list” would also be an alternative to de-activating the whitelist fully.
A new RELEASE Version 2.2-2 has landed ![]()
Changes:
- CHANGED: Moved tab bar from main page to bottom due to jolla phone notch.
- CHANGED: Weblate translation integration.
- ADDED: Mobile data can be turned automatically on and off from daemons.
- ADDED: GPS-at-Home-section to send static GPS coordinates when connected to specific wifi network.
- ADDED: Find-My Device app logo in notifications
- CHANGED: command daemon will check autoLocSwitch if location was disabled and GPS command was sent via MQTT or SMS to enable GPS by itself.
- FIX: If camera upload fails the push message on phone is now correct
- FIX: Automatic pictures upload retry if internet connection was lost on camera command upload
- FIX: GPS command via SMS will now send last gps fix if fix could not be retrieved.
- ADDED: Logging enhancement for daemon_cmd, priv_service and sms_sender
- ADDED: Notification for failed remote SMS command due to false TOTP code
- ADDED: Logging enhancement for camera_capture, daemon_cmd, priv_client, priv_service and sms_sender
- ADDED: Finnish translation provided by @rla88
You can get it on:
- CHUM:testing (CHUM release is ongoing)
- direct rpm download via git
- openrepos: Not available
- Jolla store (in QA since 05.11.2026)
ok will check how i can do it, thanks for the input.
–> Your changes will be located in the next release as this version was already finished and tested.
I think it can be both ways depending on the developer. I personally like translations more but understand also the point to have one name through translations.
Jolla has translated all the basic apps. If the app has some general meaning I think it can be translated. If the app had a name ‘Car’ I would translate that ‘Auto’ in Finnish. If the name was ‘Carfish’ I would not translate.
Nice iOS for tackers
But can you also integrate Murena e/OS (Fairphone)?
@gejeem mhm I need to Check if there are APIs or something we can Query, if so, Yes that can be integrated as well - I will put it on the List for researching, but I need someone to Test as i dont have any Fairphone Users in my Family
are You the Right Person then?
Yes, I also have a Fairphone Gen6 with Murena e/OS but are not a dev. If thats not a problem sure I can help
Is this mythical script publicly available or you are doing more work with it?
@lakeboy i will add it to the github repo as example for you guys for further use.
let me just finish the current tests and debugging: )
RADAR app version 2.2-2 is available on CHUM now.
@ric9k as requested, you can now let the app turn ON mobile data when you for example capture a picture via SMS, but mobile data was off. After app is finished, it will turn off mobile data again.
And: Switch for auto enabling GPS also works now for SMS commands.
You can turn it on in the general settings, the settings apply for MQTT and SMS commands:
Great!
As I most of the time have those off, this is much appreciated.
Thank you for the add, @DominikH
@lakeboy , @CLMA31 and all other interested guys: I added the example script for the icloud-bridge into the examples:
https://github.com/Dominik-h-hub/harbour-find-my-device/tree/main/docs/examples/icloud-bridge
Features:
- Get your icloud devices (inkl. family devices), location and battery
- generates Radar App compatible MQTT message and device-id + PIN
- accepts RING (RING_STOP is not working, as this is also not a feature of iCloud) and GPS command from Radar App or other clients from your side
–> With that you can add the icloud devices to your RADAR app and track them. You can even send RING and GPS command (already tested by me). By default the bridge will only add iPhones and iPads, but you can configuere what you want to publish.
Note: Radar App does have currently GPS command not shown in devices-view, i will add it in the next release as well to the app.
Under which topic on the MQTT does the app write? Perhaps the info/message can be reused by Home Assistant?
This is exactly what I had in mind. Just set up the MQTT broker in Home Assistant to see if the phone would just be added as a new device, but seems this requires some additional “fine tuning”. Not that I necessarily need it, I have the great Helmsman Home Assistant app to track my phone, but for remote control (and background location) this would be great!
@raketti @oriold the App Publishes the coordinates in topic /fmd/device-id
I made a technical documentation here:
I also would like to make it as much compatible as possible to have broad Integration options available.
Maybe you can give me some Details about the Home Assistant possibilities, I do use Openhab but I can help You guys maybe to integrale it into Home Assistant ![]()
I also made an example Client Application In Python where you can See how to use the payload Sent by the App and Show the Position on a map
I’m using Radar App with Homeassistant to track my phone location and run some automations when arriving/leaving home etc. I have following mqtt config in configuration.yaml to create the tracker:
mqtt:
device_tracker:
- name: JP
source_type: gps
json_attributes_topic: fmd/XXXXXXXXX
json_attributes_template: >
"latitude": {{ value_json.lat }},
"longitude": {{ value_json.lon }},
"gps_accuracy": {{ value_json.accuracy }}
{% if value_json.alt is defined and value_json.alt is not none %},
"altitude": {{ value_json.alt }}
{% endif %}
@DominikH I needed to add the check for null altitude values because the new GPS at home–setting sends null altitude and Homeassistant refuses update the location even if it received lat and lon. Otherwise I like a lot this setting to set fixed location at home, thank for implementing it! I only wanted to set more than one SSID.
To be able to ring the phone from HA, I have a pyscript script to generate token and publish mqtt RING message to fmd topic like explained in the docs. Then I call the script from some icon/picture interaction.
edit: Here is the pyscript file if someone’s interested. I only changed the topic name to XXXX… and secret/pin/seed (can’t remember how it’s called) to PINCODE:
import hashlib
import hmac
import time
import json
@service
def send_fmd_mqtt_ring():
token = hmac.new(b'PINCODE',('RING::%d'%(time.time()//30)).encode(),hashlib.sha256).hexdigest()[:16]
payload = {
"cmd": "RING",
"token": token
mqtt.publish(topic="fmd/XXXXXXXXXX/cmd", payload=json.dumps(payload))
@service
def send_fmd_mqtt_stop_ring():
token = hmac.new(b'PINCODE',('STOP_RING::%d'%(time.time()//30)).encode(),hashlib.sha256).hexdigest()[:16]
payload = {
"cmd": "STOP_RING",
"token": token
@prkl Yeah I also Found out that I Need more than one SSID for that fixed Koordinates as i do have some additional repeaters and so on at Home ![]()
I can program RADAR altitude to fixed „0“— would that be ok for Home Assistant?
am I allowed to add your example Home Assistant config to the example section in my Repo? ![]()
I can try to set alt 0 to my template and report back, I’m not at home at the moment but when I come home in few days.. (yeah it should work if it has some value…) Of course you can use the example. In HA I have also mqtt integration installed and configured to use my broker. For the script pyscript integration is needed. I think that should do it.
