Piirit - A native Sailfish OS client for Delta Chat
How does this compare to the other Delta app in development? Postivene or something.
Edit: actually is it just the final version of the app?
I can say with confidence that Piirit is much better than Postivene - because Piirit is Postivene, or at least it was, until I changed the name a day or so ago. Navigate to https://github.com/muhnschein/postivene and you will see. :slight_smile:
You can contact me via PM. Sure!
That. Some even do and never use it themselves. This really worked so well in the past it’s a more than valid recommendation and should be an option to software creators employing LLMs.
Sounds good to me! Any effort you spend on polishing the English strings will pay off in the translations. If you have the time/energy, maybe you could ask translators if they prefer reworking LLM output or translating everything themselves. Replies may be different for different languages, since LLM translation quality varies a lot by language pair.
I appreciate your work, even though I have some objections to LLM pedigree and use. Do what you need to do to keep your sanity.
No translator that I know of, would want to rework LLM output. That would probably triple the time it takes to translate from scratch.
A blank .ts file is all we need…
<translation type="unfinished"></translation>
It is already there:
https://github.com/muhnschein/piirit/tree/main/translations
I know… but there is also a whole lot of AI translated files, that makes at least me, not wanting to touch it.
If translations is unreviewed, then who knows about the rest of the code?
I can just tell, that I am not spending my limited time on checking AI-produced code, published by some developer I’ve never even heard of.
Piirit 2.0.0 is out :tada:
Release: Release Piirit 2.0.0 · muhnschein/piirit · GitHub
A few things from the To-Do list above are now done:
  • Several relays per profile. You can add more relays (transports) to a profile and see how each one is doing under “Storage and connectivity”. (Thanks to @broncheolus for testing this one!)
  • Piirit can now be the first device in a multi-device setup.
  • Quick actions on the app cover. My personal favourite. You can put one or two actions on the cover, like search or opening a certain chat.
  • Voice calls (experimental). You can place, answer and end one-to-one calls. They’re off by default. To try them, go to Settings → Advanced. They do work - but since Sailfish OS does not come with a Calls API accessible to regular Store apps, the UX is still a bit… odd and not to my liking. Hidden behind the experimental flag on purpose, lots of polishing (and nagging @Jolla) left to do.
Also new:
  • Voice messages are sent as MP3 instead of FLAC, so they’re much smaller.
  • Blocking contacts works better.
  • Attachments are saved to Downloads/Piirit by default.
  • You can select and copy part of a long message.
  • The RPM is smaller.
  • As promised, I went through the English and German strings by hand and also removed most menu subtitles. The other languages were updated from that. (Thanks to @frankps for suggestions for Bokmål!)
  • Updated Delta Chat core (deltachat-rpc-server) to 2.62.0.
To install, download harbour-piirit-2.0.0-1.aarch64.rpm from the release page and run:
devel-su pkcon install-local harbour-piirit-2.0.0-1.aarch64.rpm
Please file bugs as GitHub issues. Happy chatting! :full_moon:
How can one add a quick action to the cover? Can’t find the way. Sorry. Cheers, broncheolus.
Edit: Found it. One can not see if a text in settings is clickable. Sorry. :wink:
Voice calls work! Great! :ok_hand: :ok_hand: From DC or AC calls never work for me. My partner can hear me but I can’t hear my partner although WA calls seem to work (but the call screen does not show up) So having a working call with Piirit is really great. :+1:
Edit:
  • Calls don’t ring on my side
  • when screen is off call screen just shows for a second and then disappeares
  • It seem that both speakers are active, earpiece and loudspeaker (possible?)
Even though it’s not yet available at Storeman or Chum, I’m very happy you made a SFOS client for DeltaChat! I’m happily testing. Much appreciated and once you get it into a SFOS store…or even into Jolla store, I could donate to your efforts. I haven’t yet tried the calling feature but sending documents works which I’m very pleased with.
Hi,
first of all thanks for taking the time to create this!
Just leaving here a weird issue i had in case someone else gets it:
When i tried to link piirit as a second device (from my computer) the camera in the screen to read the QR was totally out of focus, too blurry to read anything.
The only way i could fix it was opening the camera app from sailfishOS at the same time, then the screen from Piirit refocused immediately and read the QR correctly.
Specs: Jolla phone 2026, Finlayson 5.2.0.18, piirit-2.0.0-1
Not sure if this is only me, just leaving it here in case someone else has the issue or it helps you find a bug somehow, if any.
Cheers.
(Edited to add Piirit version)
I don’t know if it was Piirit bit your discription of yoir issue sounds some kind of familiar. But as I wrote I really can’t remeber if it was woth Piirit.
Hi folks, thanks for raising this. :heart: I did not run into this myself, but had a similar issue on early builds that came without the auto-focus.
I added this to the Github issues as QR scanner out of focus when linking as second device · Issue #122 · muhnschein/piirit · GitHub. I’ll probably tackle this as part of In-app viewfinder: switch cameras, zoom · Issue #131 · muhnschein/piirit · GitHub. No ETA yet.
Piirit 2.1.0 is out: Release Piirit 2.1.0 · muhnschein/piirit · GitHub
What’s new:
  • Unread filter: the chat list now has Search and Unread pills at the top. Unread shows only chats with unread messages.
  • Any emoji as a reaction: react with any emoji, not just the quick ones. Emoji are drawn as Twemoji, in messages too.
  • Easier onboarding: a new profile picks a relay automatically and adds more in the background. If you want a specific relay, it’s under Advanced. Scanning a relay’s QR code now offers to add that relay to your profile.
  • Chat descriptions: show and edit the description of a group or channel.
Other changes:
  • Text written by the Delta Chat core itself (system messages and the like) is now translated into every language.
  • Relay list synced with chatmail.at/relays.
  • Turning on an experimental feature asks/warns first.
  • A large attachment gets a warning instead of being refused.
  • Chat-list ages keep moving instead of freezing at “now”.
  • The QR scanner no longer re-locks its focus every couple of seconds. (Should fix your issues, @corconegre, @broncheolus. Autofocus plus, if that fails, tap-to-focus.)
  • Avatars on the app cover no longer break.
To install, grab the aarch64 RPM from the release page and run:
devel-su pkcon install-local harbour-piirit-2.1.0-1.aarch64.rpm
Bugs and ideas are welcome as GitHub issues: Issues · muhnschein/piirit · GitHub
Great app, kudos! I think I found a small bug, in settings “Delete messages from device”, when I set it to to a different option it always goes back to never. I’m running the app on J2026 5.2.018.
Hi! Despite all the warnings, I installed Piirit on my X10III—and it works really well! Hats off! The only thing still missing is a background service. :wink: Oh, and is there a way to support you financially? X10III with 5.1.0.11
Since it seems Delta Chat can work with Unified Push (see Arcane Chat), have you considered integrating with Foghorn?
Picking up the thing with the “warnings” mentioned by @MarKre72 it really would be great if you could publish your project on chum. Then there would be proof that the package delivered was built by a certain source code that every one could check. The way "Piirit” was published until now always leaves a fishy smell especially because it “handles” encrypted stuff.
This shall not disencourage you but encourage you to continue you important work!
:ok_hand:
PS.: At least Openrepos with link to sources would be great.
