[Patchmanager patch] Homescreen running apps badges
You have to reinstall patchmanager after the update, i ran into the same issue.
again, another patch of yours for an issue that bothered me. Thanks :folded_hands:
Hi… New jolla user here… working on learning the system.. When working with patches (patchmanager) i keep getting the message when I try to activate a patch in SaneFish: “Patch was installed, but the active Patchmanagfer-files are incomplete” “Try again” … ?
So despite the message the patches are labeled “not installed” and trying again does not change anything…
Is this because the patchmanager is not compatible with v/ 5.2.0.22 ? And if so, when can we expect an update?
I wish i could do the icons bigger just a little bit
